Question about Samsung SyncMaster 930B 19" LCD Flat Panel Monitor
Samsung 931B SyncmMaster
Can not move from analogy to digital screen stuck on analogy need manual to make change.
    Genius:
  • 1,003 Answers
DO YOU MEAN WONT SWITCH FROM ANALOG TO DIGITAL!!!
THE ONLY WAY THIS WILL CHANGE IS IF YOU HAVE A DIGITAL INPUT SOURCE CONNECTED to this mointor like HDMI AS THIS MOINTOR AUTOMATICALLY SENSES ANALOG SIGNALS AND DIGITAL INPUT SIGNALS if a digital signal is available it will switch over if a digital input singal is not available you will only be able to use the analog option
Posted on Jan 16, 2008
How do I switch from anaLog to digital as Samsung TV now showing week or no signal but has been working ok for some years on digital now seem to have switched to analog
Most Samsung tv's change from analog to digital (and vice versa) by entering the same channel number you're watching at the moment, again. If that doesn't help, check the manual for detailed information.
Feb 28, 2015 | Samsung Televison & Video
Jvc hd56g786 channels stuck on digital cant get them changed to analog
Using the television's remote control, enter the user's menu. Search for video input and change from cable to antenna. If still experiencing difficulty, visit the JVC website and download the owner's manual to learn the procedure of changing the video input type and deactivate the television's digital decoder.
Dec 22, 2013 | JVC Televison & Video
My syncmaster 933 flashes on and off then frequently the digital and analog word flashes out on screen and the auto adjustment
  1. asdasdasdadadaddddasdsssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssspaotin
Jan 05, 2011 | Samsung SyncMaster 931B 19" LCD Monitor
When starting computer in the morning, the monitor display flashes analog then digital then back to analog and goes blank. Power to the monitor is on. Multiple on/off of power brings display back.
Hi, 12fixlouie here. LCD monitor may have intermittant solder joint on power supply board inside unit. May only need you to resolder it to fix. Locating it is a whole other problem in itself!!! If not into monitor "teardown" and all the other stuff that you will need to attempt a repair, then let me know right away. 12fixlouie
Sep 14, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
I am using Ubuntu 9.10 in a dual-boot config with XP. I have a Samsung Synchmaster 931B monitor in analog mode. Works fine and drivers installed under XP, but will not support extended effects under...
it's your graphics card not the monitor that often has proprietary drivers to drive compiz and other effects.
If this is not a laptop, then it is easy to interchange.
Nvidia is one such vendor that supplies special drivers for Ubuntu
Jan 29, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
No picture
Can u tell me, are u using analog signal or digital as it has two signal connector.
Ok, i can suggest you for both.
If you use digital then here it is,
Here are the complete instruction for you.
so, if you feel any trouble, ask me.
Jan 16, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Samsung 2233 stuck in analog
in your mon there will be small left arror image in box called enter button,,,,if u press that button its shows analog and digital in that have to choose digital.....
Apr 03, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
SyncNaster 931B
take a soft cloth (type used for cleaning glasses) and moisten it with a small amount of water on one corner.
gently wipe the wet portion of the cloth across the screen (if you have any weak alcohol based cleaners you can try it. I have used hand sanitizer before on my 931b w/out problems, I wouldn't use any extremely strong liquid cleaners though).
Use the dry part of the cloth to wipe the area dry, then move to another part of the monitor once you are satisfied.
Jan 12, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Lost my Digital audio signal, stuck on analog
Hi - Please check the setup of the digital inputs as per pages 11, 20. 21 & 37 in the manual.
Most important:
Are you using coax or optical connections? Even if you have not moved them you should check they are securely fitted as they can work themselves out in time.
Let me know how you get on.
Best regards,
Informatica.
Sep 06, 2008 | Audio Players & Recorders
Samsung model 931b 19
hello fixya team, i was searching thru your posting and came across a posting by grapemaster on january 11,2008. his problem was identical to mine. a "best solution",posted on 16 january stated he had to connect a digital imput sourse (such as a HDMI. i will pursue this approach and let you know the results. thans for your response! freebee
Feb 18, 2008 | Samsung Computers & Internet
Samsung SyncMaster 930B 19" LCD Flat Panel Monitor Logo
723 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
