Sony slv975hf Hi! I have a sony slv975hf that will load in a tape and then spit it out. This only happens with a few tapes which by the way load into other machines with no problem. 98 % of tapes work fine on this machine so do we have a cassett problem or a machine problem? Also on this machine I have a front flap door where the controls no longer work. Maybe you can help me with this problem also. Thanks, Bob
  • 579 Answers
Tape drive mechanisms all work using friction drives - whether by belt or by clutch. This allows for a little slip in the drive mechanism to brevent breakage. As the VCR ages the friction will of course tend to loosen until it starts having trouble like you describe. Not all cassettes are exactly the same and the tighter ones have trouble first. It needs a belt job.
Also, some of these Sonys have a defect in the capstan motor shaft sleeve that was molded a little off square and the motor will start to drag on the mounting plate eventually.
And be sure and lube the tape loading arm by the audio head.
Hope ya fix it!
Posted on Jan 12, 2008
C3210 error shows in sony dsr45 ap dvcam
C 3210 is means : LOAD direction loading motor timeout,
Main region how it happen are,
1.if there is moisture in ur TAPE or if ur tape had an slack tape during search And Video head is dirty.
Best is to clean head drum or disconnect the AC power cord.
After reconnecting it,
May 31, 2014 | Sony DSR-45 Mini DV VCR
Our Sony dual recorder has been spitting out the vhs tapes after a couple of mins being played. And no shows are being recorded.
First, make sure you got a good quality tape. Bargain tapes can destroy a recorder before its time. Run a Cleaning Tape to get rid of dust on rollers.
Feb 28, 2011 | Sony RDR-VX530 DVD Recorder/VCR
My Sony DCR-TRV33 won't accept a cassette. It will close itself up without a cassette tape in place, but not while a cassette is inserted. I have tried several different tapes, so it is not the cassette.
Hi wnwatkins3,
Have the same problem here. Bought my TVR33 in 2003, and its still
a good cam with 1 megapixel. But since 1 month the tape won't load. I can insert any tape in the cassette, but it won't close. Without a tape it closes fine.
My only option is to send it to frsbenelux to fix it for a few hundred euros. Hoping to find a solution on the net, i will share with ya.
greetz Ed
Jun 29, 2010 | Sony Handycam DCR-TRV33 Mini DV Digital...
I have a Sony handycam DRC-HC26. After placing the DV tape the tape refuse to load into the tape compartment and as such the tape door cannot be closed. Please advise.
The mechanical of tape loading compartment is misaligned and it needs readjustment which is a bit technical issue. Please contact any expert for mechanical adjustment of tape loading path assembly.
This will solve your problem.
Thanks.
Nov 24, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
Unable to load tape
according to the symptom you don't need reset, This problem is related to the loading tape path which is mechanically unstable, that's why problem arise, For your convenience please see the given below pic of SELF DIAGNOSTIC SYSTEM to understand better.
Your camera needs just mechanical adjustment by any expert, contact any expert nearby or from Sony for mechanical adjustment, this will solv the problem.
Thanks for using fixya.
Jul 01, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
Sticky 8mm sony tape
need to go to an AUTHORIZED SONY REPAIR SHOP to get it fix , these camcorders are very delicate and needs to be tune and realign by a SONY EXPERT TECHNICIAN , thanks AJ
Jun 12, 2009 | Sony Handycam CCD-TR87 Camcorder
Sony Cam DCR-PC100, "eats" tapes and when ejecting, pulls tape
The take up spool is not working upon ejecting. I would take it to a Sony Service Centre for service.
Jun 03, 2017 | Sony Handycam CCD-TRV43 Camcorder
Sony AIT2 Turbo tapes won't work in HP AIT2 tape drives
Hi Paul
It sounds like you have bought the wrong media!
The AIT2 and AIT2 Turbo drives are NOT THE SAME !
for the AIT2 drive (SDX-500C/V SDX-520C/V) you ned the SDX-50C media as the turbo tapes are NOT compatible
If you actually have a turbo drive then you may have a load mech issue in thich case try www.tape-drive-repair for more help as they are good price wise
Dec 03, 2007 | HP (Q1998A) AIT Storage Media
DCR TRV320
That is the "LOAD" error code.
However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Oct 25, 2007 | Sony Handycam DCR-TRV320 Digital Camcorder
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
