Question about Acer Aspire 3680 Laptop
Wireless router ok ive had a wireless dlink router connected for awhile now and its worked fine wirelessly with my acer 3680 laptop but my sons laptop connected to it today and now mine wont it wont tell me why so i cant fix the problem myself but has worke fine for several months untill now
No everything is the same, but its telling me my setting dont match the original configuration the only thing that was changed was the wep security key wich ive compensated for
Posted on Jan 11, 2008
  • 89 Answers
Has any security setting been enabled or configured before or after your son started connecting to it?
6ya staff
SOURCE:
I have Acer 3680 laptop ZR1 The wireless worked fine, but not anymore. Acer sent 2 CDs ($26) but not working. No support from Acer. Do I need some kind of driver?
Most Acers use an IPN2220 Wireless card. If yours does, you use XP and your router is using WPA or WPA2 (TKIP or AES) security then you'll need to update the driver by searching for it manually using the Custom button (Hardware) in Windows Update (instead of Express). This driver is not part of XP service pack 2 or 3. In my experience if you don't update to the newest common form of home wireless security (WPA2 AES) then the older formats seem to become unreliable in the way you describe
Jan 16, 2010 | Acer Aspire 3680 Laptop
My acer 3680 is not detecting my wiresless router connection and I can not get online. I know the router works. How do I set it up to get the connection.
you can configure the wireless settings of your router first by going into it's GUI. to go there just open your command prompt and type in ipconfig/all, then look for Default Gateway. open an internet exlporer or any browser and type in the numbers you found in the default gateway in the address bar. when you're done configuring the wireless settings of your router you can now try and connect to your wireless network...
hope this helps....
Nov 10, 2009 | Acer Aspire 3680 Laptop
I would like to go wireless with my system,(linksys router). Plea
HI,
You would have to proper hardware to go online wireless
1. Should have wireless cards on PC and laptops
2. Should have a wireless modem/router
3. Configure the devices and you would be able to go online
Thanks for using Fixya
proton
Sep 01, 2009 | Acer Aspire One Netbook 8.9" Notebook
I set up dlink dir300 router and pc and other
go to your adapter settings for the notebook that does not work and clear off your network connection try to re-discover your router, and enter the same code you used to log in with the notebook that works. Sounds like you have an IP from the router, but no access.
Jul 24, 2009 | D-Link AirPlus DI-524 Wireless Router
Downgraded to xp and lost wireless!
it sound like you dont have the right driver for your wireless contact the web site where you got your driver from and tell them it didnt work or go to driverguide,com see if you can get one
Jul 18, 2009 | Acer Aspire 3680 Laptop
Wireless network access: 1 laptop fine, other not so much
Check the wireless card on the PC first. Go to "My Computer" then "Device Manager" and check to se if all the hardware is ok.
Use Control panel/netconnections to check to see if you still have a wireless connection and if it works. Also check "My Network Places." Try re-installing the drivers.
As a last resort....try System Restore if it's an XP or Vista system. Remember - using system restore will return the PC to an earlier time but you could lose some stuff so decide first.
Mar 21, 2009 | Acer Computers & Internet
Lost Wireless Connection DLink G604t
So if your other 2 laptops (WinVista) is working then that means that the wireless on your Dlink is working fine. Its possible that its a problem with the settings on the winxp laptop. does your winxp laptop have a builtin wireless adpater? What does it say on your winxp laptop is you will try to view the available wireless network?
Jul 29, 2008 | D-Link DSL-G604T Wireless Router
Connecting dlink WBR-2310
hi greci6,
Does your laptop have wireless access?
You may have to buy a wireless chip for your laptop, Give me a little more information on your error you get.
Also tell me how your router is setup, and cord placement.
Dec 31, 2007 | D-Link RangeBooster G WBR-2310 Wireless...
Wireless router
Yes, you can use wireless router with the modem. I guess the actiontech DSl router that you have is also Wireless one. If so, you can use just the DSL router for wireless connection. If you really want to use Dlink router with it, Connect the ( WAN port ) of the Dlink router to the ( LAN Port ) of the Action tech modem [ modem(LAN)-->Dlink(WAN) ]. Once you do this connection, better to do power cycle ( unplug the pwr to the dlink first, then, disconnect the pwr to action tech - wait 1min and plug the pwr to modem, wait for DSL light to be solid , then put the pwr back to dlink ). Make sure DSL light on the modem solid, internet light & WLAN light on the link glowing.
- Make Hardwire connection between the computer to Dlink and check the ip address on the computer whether it acquires the ip address from Dlink and then check the internet connection on the computer, it has to work. if computer not getting ip from dlink, try restarting computer.
- If hardwire connection on the dlink works fine and check the wireless connection.
For wireless configuration or assistance you may check this link:
http://www.portforward.com/help/wirelessxp.htm
please feel free to ask, if you have any more assistance.
- Laxman
Nov 22, 2007 | Actiontec (GS204AD9-02) Router...
Acer Aspire 3680 Laptop Logo
168 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
