Question about Alpine MRP-M650 Car Audio Amplifier
NEED HELP ON AMP
Ok i got an amp installed and would most of the time not have any sound. power is on(has the light). wat am i doing wrong?? also, when it does work my amp shuts off. and when i turn power on, light comes on and fades away immediately. are all these problems related?? pretty sure all cables are connected
  • 1 more comment
  • mista808 Jan 12, 2008
    amp is brand spankin new and i understand the remote wire prob but please explain the voltages to/at amp more. THX A LOT FOR REPLYING!:)
    wat if it does turn on but no sound? wat does dat meen?
  • mista808 Jan 13, 2008
    i changed the battery fuse. ok now!!! one last thing, if the rms power on my amp is 40watts rms x 4, wat setting will i hav the gain on?? i.e. full gain means the full 40?? or half the gain is the ful 40??
  • 102 Answers
Check voltages at the main power lead to/at the amp and also
at the sense wire which switches it on when the radio is on.
Might be the wiring is too thin and is switches off when current is drawn bigger than that needed to light up the light?
That or the switching power supply inside the amp is unstable/dead.
Posted on Jan 12, 2008
  • Voltages should be about the same as measured on the car battery and
    could drop a bit when the amp switches on. They will have to be around
    12 volts for the power supply in the amp to switch on and when <10v
    there is a wiring problem. If this is the case you should run thicker
    wiring from battery to amp and *do* run both + and - wiring. Never use
    only the red + and wire the black - to the car's chassis. As a test you
    could try connecting the amp close to the battery with short cables and
    see if it will turn on.
  • In theory you should be getting the full power when the volume control is turned all the way up. In practice the output voltage of your radio is more then needed to drive the amp to it's max so somewhere near the end you will already be getting full power.
    Volume controls work logarithmic to compensate for the sensitivity curve of our ears and most of the time you will only use a few watts of power for a decent listening experience. Only the peaks in the music will drive the amp to it's max as 4x40 real watt's is enough to deafen you when driven into good speakers :)
Quantum audio qca4000d mono block amp 4000 watts cosmic series. when car is turned off amp works fine. when I start the car protection light kicks on. Whats wrong
How do u connect a quantiam audeo 4000 monoblock wats with 15s q powers I tryed it but they do not sound da way I though they were going to sound let me no som thing thanks?
Nov 09, 2011 | Quantum Car Audio & Video
Fender HRD - clean channel works fine, drive & more drive VERY low volume, like a headphone across the room w/ all 3 volumes at 10. LED works fine in drive/more drive. All same w/ footswitch,...
Wayne, There's a time to take the amp to a pro shop andf get it done right. It' saves time and headaches, and also keeps you from inadvertantly smoking other parts or yourself. Now is that time.
Apr 17, 2017 | Fender Hot Rod Deluxe Guitar Combo...
Loud beeping sound on start up , now will not start up , power ok
First remove the Ram and boot the system without it. If you hear continuous two beeps, then the problem is with the Ram, you need to replace it. If nothing happens, then your cpu or your motherboard is gone. Good luck. Thanks for using FixYa.
Jun 03, 2010 | Asrock K7S41GX Motherboard
Rockfordfosgate P6002 amp protect light goes on
are u sure u have them running at the right ohms, for not only the subs but the amp too...if you go lower than your amp is rated you can fry stuff...via protect mode......hopefully this helps
Mar 17, 2009 | Rockford Fosgate p-450.4 Car Audio...
Will this give me 400 watts on each
bignatedabal: You can't get something more out of a device than it's rating. In other words, if you have a 400W amp that's all it's going to produce. For example if you're looking to drive both sub spkrs @ 350W each then buy a sub amp with a rating of 700W @ 2ohms & connect your 4ohm spkrs in parallel to the amp. Each spkr will produce 350W of sound if everything is installed correctly.
1 thing to look for in amp mfg's. Look for those who rate their amps in RMS power. This is the true output rating. Many amps are rated in peak-to-peak which seems great but doesn't tell you the real story, unless you know how to do the math to determine the RMS. The better mfg's will take the time to test their amps & rate them properly. Also look for massive heatsinking (the cooling fins). I consider cooling fans to be a benefit as well.
If you have addtional questions, drop me a line.
peace-out
Jan 18, 2009 | Kicker ZX400.1 Car Audio Amplifier
Jonny Rafael Every time i turn on my amp it stops and says Amp Err and shuts down and wont let me turn on like in about 20 min.I dont know wats wrong but i need help please.
Says amp error on the amp? what kind of amp? Have you checked the fuses and are you properly installed ie. remote wire to a remote power source. Properly grounded? Power wire to a constant power source? Please be more specific?
Aug 31, 2008 | Pioneer Audio Players & Recorders
My amp is on but the protection light stay's on!!
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If the protect light remains on, the amp likely has blown output transistors.
Feb 28, 2008 | AudioBahn A2801Q Car Audio Amplifier
Powers on but no sound
Check the main amp fuse under the hood, even if it looks good just change it. Often times that light on the amp can come on just from the power amp tunon wire. Try a friends subwoofer box just to make sure the connectors on your box are good, and if that doesn't work then give me some more details....year/make/model of car, what kind of sub, what types of things do you see on the side of the amp....is there a green light as well as a red light?
Aug 18, 2007 | Xtant A3001 Car Audio Amplifier
Alpine MRP-M650 Car Audio Amplifier Logo
148 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
