Back to:
Tags:
Dynamode RADSLC4WG Wireless Router
Reset Router!
posted by IainM on Jan 11, 2008
Hello.
I made some changes to my router, don't know what yet, that mean I can't access it via my browser from any pcs on my home network. I can't find a reset button on the router anywhere so is there any way of resetting the router without using a browser?
I'm tearing my hair out so any help would be much appreciated!
Thanks,
Iain Martin
Comment by IainM, posted on Jan 12, 2008
Unfortunately that manual is for a different router. The reset button is nowhere to be seen on my model which is this one: http://www.ebuyer.com/product/131771
Any other ideas?
Thanks,
Iain
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 11, 2008
Helpful (85)
BggFixya
Rank:Guru Guru
Rating: 87%, 97 votes
Hi LianM,
You can download your manual here,
http://www.dynamode.co.uk/support/adsl_r-adsl-c4wg.html
It is in .pdf format, so make sure you have Adobe.
Your reset button is found between the Power pluging hole and the RJ45 port. Found on page 6
Good Luck.
Comment by BggFixya, posted on Jan 12, 2008
You might try going to start>run>Type in CMD, and press enter. . In the windows that opens, type in IPCONFIG.
That should give you your IP Addess, Subnet, and Gateway IP.
Make sure the Gateway IP matches what you are typing into your IE addreess bar.
If your IP addess for your machine, is not in the same range as your gateway, i.e. your machine is 169.xxx.xxx.xxx, and your Gateway IP is 192.168.xxx.xxx, (XXX being any numbers from 1-254), you won't be able to access the router.
If this is the case, you would have to set a static IP on you machine, and then put the Gateway IP into the IE address bar.
Basically, if the IP address of your gateway is 192.168.1.1, your machine IP would have to be 192.168.1.xxx to connect to the Gateway, using the Gateway IP in the IE addess bar.
Hope that helps some. If you need help on setting a Staci IP on your machine, click here.
http://www.answers.vt.edu/ask4help/connection/vtkb697.htm
BTW, if your machine IP is 169.xxx.xxx.xxx, there is a good chance you disabled DHCP. That 169 ip is a default one XP gives itself when there is no DHCP server avaialble.
If this gives you access to your router, you can look thru the options to reset to factory defaults. Trying to find a manual that matches your router.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Reset Router!:
I don't want to Accept this solution
Solution #2
posted on Jan 24, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hello there.
I emailed Dynamode directly and they sent me the following instructions to reset my router:
To reset the router please try the following:
Hold down the "Reset" button on the underside of the router,
HOLD IT for 10 seconds, then release.
All the L.E.D’s should go OFF, then come back ON.
When the INTERNET light is ON and SOLID, then the Router is Ready for use
Their instructions work but I've absolutely no idea how they expect somebody to work this out on their own - not exactly what I would call intuitive!!
I managed to reset the router but it's now running painfully slow when I connect bothe wirelessly and via ethernet. It's a 4 meg ADSL connection that runs very fast when I connect using my USB modem.
Any ideas?
Thanks,
Iain Martin
Thank You!
Can you Help with these Routers problems?
Routers
after u save thr running configuration at...
Routers
i tried portforwarding using portforward.com guide. but...
Routers
connecting 3 mobile internet dongle to draytek 2800vg via...
Dynamode RADSLC4WG Wireless Router...
the PPPoA llight has gone out and wont come back on so i...
How do I set up security for my network? I'm currently...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
