You may have a belt that fell off the pump that throws water to the sewer / it's down in the bottom / just follow the hoses you will see them .belt from motor goes over a small pump's pully that's the water pump. if the pump is turning freely it should pump unless the hoses are clogged with lint , my guess is the belt needs replacing and check the tension on the new 1 on install. if it's not that then it may be a bad pump /try and flush it out if it still doesnt work , buy a new pump or new machine . if it's old then might be time for a new 1 anyways .
MAKE AND MODEL NUMBER OF THE WASHER PLEASE.
