Question about Pioneer DEH-P44 CD Player
Durabrand WD810 will not accept/load cds anymore
I don't condone cheap CD players, I warned the person who I installed it for, it's been about a month, suddenly the player will not accept a cd. If you stick it in there, it's like the player sensor doesn't pick up that there's a cd being fed. so you gotta kinda shove it in there. but it won't play still. What you actually have to do to get the player to accept the cd, is hit the eject button, and kinda hold the cd to the point where the wheels are grazing the edge, then when the cycle is done, it'll suck the cd in and play fine. Any way I can just fix this for these people? I really don't like unsatisfied customers.
4 Suggested Answers
  • 91 Answers
SOURCE: CD Stuck in cd player
There should be a reset button on either the face of the player or under the faceplate if its removable (tiny black button). Otherwise to remove the cd disconnect the unit and then plug it in or remove the memory fuse or battery lead for 5 seconds.
Posted on Jul 06, 2008
  • 33 Answers
SOURCE: AUX input on Pioneer DEH P31000
There is a plug on the back called an IP-BUS. You should be able to hook the ipod directly up to that with a simple homemade adapter. I built one for mine and it works fine.
Posted on Oct 21, 2008
  • 223 Answers
SOURCE: CD is stuck and eject button doesn't work
Unplug the cd player and open the unit up by taking the top cover off..there will be screws holding it on on the underside. You should be able to retrieve the cd from inside. Your track is broken, you will need to replace it.
Posted on Jun 01, 2009
  • 188 Answers
SOURCE: CD keeps ejecting without playing.
try reformatting the cd or try a cleaning cd, the more you pay the better the cleaning cd
Posted on Nov 09, 2009
0 characters
1 Points
Cd player not playing cds
If your CD player isn't playing CDs anymore, its possible that the lens had reached its end of life. If your player is still kinda new, its possible that you need to have your lens cleaned. Get yourself a cheap cd lens cleaning kit and use it on your player.
I hope this helps. Thanks and have a nice day.
- HotRatchet
Dec 14, 2009 | Alpine CDE-9845 CD Player
Radio wd810
I don't think you can to a Durabrand WD810. Go
buy a quality unit, not Wal-Mart junk.
Aug 25, 2008 | Durabrand WD810
You need audio inputs, Durabrand is Wal-Mart ****. Buy a stereo with a front input jack.
Durabrand Car CD player
Sounds like you may have shorted the ignition lead, normally red). Also some radio manufacturers use a cheap fuse holder on thier radio harness so check the fuse holder and the fuse. Then check the radio fuse in the fuse block of the car. Finally check the wire harness where it plugs into the radio (if applicable) a wire may have pulled out.
Make sure all connections you made are insulated.
Jul 02, 2008 | Durabrand Car CD Player and AM/FM...
Durabrand DCD 630S car am/fm receiver with detachable face
Take it back and buy a Pioneer. Sony, Kenwood anything but Durabrand. This is Wal-Marts ****.
Good Luck
Jan 14, 2008 | Durabrand WD810
CD Player will not load/accept cds!
I have had mine for 3yrs and it just smoked last night(12/04-03/08). I had it in one of my demo cars to prove a point. That a properly installed and maintained budget system is possible and will outlast and out perform many Well Know brands. I have 3 show cars for my shop one budget(montero), mid level price point(dodge stealth r/t) and a full blown w/ ppi amps, mb quart speakers eclipse devices(bmw m3)
The PPI amps have smoked several times, to the point that I no longer carry PPI. My point being that no matter what you buy there is a good chance it will breakdown w/o routine cleaning and care.
Jan 11, 2008 | Durabrand WD810
Wiring diagram and manual needed for wd810
The manual can be found here: Also, here are some standard wire colors: Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Sep 02, 2007 | Durabrand WD810
Durabrand CMV-102A CD Player
Good Luck. Wal-Mart trash
Jan 07, 2007 | Durabrand WD810
CD and MP3 discs burned or otherwise do not load
First of all, you aren't going to like this solution because it's the truth. If you rate me poorly, it's because you don't understand the truth. The optical pickup is bad and needs to be replaced. Anything made by Jensen/Durabrand is poorly built. Yes, you're lucky to have even gotten four months use out of it. I've seen some that only last for two months and they die. Fortunately, that's why you didn't pay that much for it. I would suggest getting a Pioneer in the future.
Jun 15, 2006 | Durabrand WD810
In-Dash car cd player
It sounds as if you've covered about as much as you can do without pulling it out and taking to the repair shop. Something you should definitely do if all this skipping is taking place whilst the car is stationary. A lot of earlier car CD players wouldn't accept the burn it yourself type disks and perhaps the factory CD was damaged. Try a few more factory CDs before you do anything else. Just because a disk plays on the Computer or cd Player in the house doesn't mean it will behave itself in the car. If you've has the unit for a while you could have the smear of grease they put on the worm drive gummed up with dust and this is stopping the disk carriage from moving freely. Or perhaps the heads are out of alignment due to constant vibration from rough roads. Either of these problems would mean a removal and either a clean or the repair shop. BMW
May 31, 2006 | Durabrand WD810
Pioneer DEH-P44 CD Player Logo
97 people viewed this question
Top Pioneer Car Audio Receivers Experts
xxxxxx xxx
Are you a Pioneer Car Audio Receiver Expert? Answer questions, earn points and help others
