Question about Samsung HTP-1200 System
Kenwood vrs-6100 receivers optical digital
Can you help me on how to get this receivers optical digitalout audio to work.my tv is connected to my cable box via hdmi,my receiver the kenwoodvrs-6100 has no hdmi connects but it does have a optical digital out feature which i tried pluging into my tv's optical connection but it does not work. can you tell me what's the problem?
  • 20 Answers
If your solely using cable as your main set of channels. Connect the digital audio out from your cable box to the digital audio input on your reciever. Then when broadcast permit you will gey Dolby Digital sound for your TV channels
Posted on Sep 23, 2008
  • 22 Answers
You want to receive the optical signal from the TV's built in decoder / receiver to play through your Kenwood? Maybe you need to select the digital input. The manual says:
Use the INPUT SELECTOR key (or Input Selector keys)
to select DVD, VIDEO or FRONT AUX.
2 Press the INPUT MODE key.
Each press switches the setting as follows:
1 "F-AUTO": Auto detect
("AUTO DETECT" indicator lights up)
2 "D-MANUAL": Fixed to digital input
("DIGITAL" indicator lights up)
3 "ANALOG": Fixed to analog input *
("AUTO DETECT", "DIGITAL" indicator goes off)
Also check your TV to make sure it is outputting to the optical jack.
Posted on Jan 11, 2008
Hooking up Kenwood VR505 to TCL Roku T.V. All I want is audio from the T.V. for Surround sound
Use an optical cable to connect them. Optical TV out to Kenwood optical in.
Oct 22, 2016 | Kenwood VR-505 Receiver
How to connect Kenwood vr-305 receiver to Samsung plasma tv, model # PN51E450A1F. TV only has component/ composite a/v in. the only out is a digital optical connection
This is the problem when you are trying to connect a fairly new product to a relatively old one. While digital audio technology probably existed in 2004 when the Kenwood receiver was made, it was so new many devices didn't have it yet or the additional cost was not worth it since there were few, if any, devices that would use it. You are probably out of luck on this one. Consider upgrading to a newer receiver....
Oct 04, 2015 | Kenwood Audio Players & Recorders
Optical hdmi
need to see the back of both units..
Jan 11, 2014 | Kenwood VR-716 6.1 Channels Receiver
How do I connect my Kenwood VR-715 surround sound system, Dish Network receiver, and HD LCD TV together so the surround sound works? Can't figure out what goes in the input, the order of the connections or...
The best way to do this is to connect you dish network receiver is directly to the tv. Try to use the best video type possible. HDMI is the best, next is component and lastly is composite. This will take care of the video portion. Next, connect digital audio output to the Kenwood Receiver. I dont know what type of a digital audio output your dish box has, but your kenwood receiver has both optical and coaxial inputs so you should be fine there. Once you have both audio and video wired, change the inputs on both your tv and kenwood receiver to the inputs you are connected to. You might need to set up the kenwood to tell it that your running digital audio to it in the setup menus. Hopefully this helps, let me know if you need any clarification.
Good Luck
Jan 08, 2011 | Kenwood VR-715 Receiver
Got a Kenwood vr405 surround receiver, a Sanyo plasma TV, hd cable box and an insignia blu ray player. Both the cable box and the blu ray player are connected via hdmi to the TV and the TV is connected to...
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Jan 14, 2010 | Kenwood VR-405 Receiver
No surround sound from Kenwood VR-5090
please select the 5.1 option in the audio menu of the reciever.
Jan 10, 2010 | Kenwood VR-5090 5.1 Channels Receiver
Kenwood vr-405 receiver
I have the 405 as well. My TV has an optical out and I run that straight to the 405 optical input. I set the input selector to DVD/CD (not DVD)and presto! TV audio out my speakers. It all comes down to the audio connections on your TV.
Mar 23, 2009 | Kenwood VR-405 Receiver
Cant get the wiring figured out.........
TV is HD correct? Use the Y/CB/CR from the Sat to the TV. Use the Digital optical cable for sound from the sat to the receiver. Use the s-video from the dvd player to the tv and the l/r to the receiver for sound. I would suggest upgrading to another set of Y/CB/CR cables to connect your dvd to the TV and benefit from better picture. Also, buy another optical cable for dvd sound (so you can enjoy surround sound). Your receiver has two optical inputs so youre covered there.
Sep 03, 2008 | Kenwood VR-407 Receiver
Samsung HTP-1200 System Logo
506 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
