Problems playing vhs tapes
When we try to watch a vhs movie it will play then go blank & say no or weak signal . then it will play for a few seconds and do it again. It will play dvd with no problems.What do I need to do?
  • Anonymous Mar 31, 2008
    I have the same problem on my Sharp Aquos 32" HDTV. I have a DVD/VCR combo attached to the Sharp with composite cables, so that both the DVD and VHS are using the same cables. The DVD plays fine. The VHS picture flashes on and off. I tried different cables, and a different VHS player with similar results.
    Let me know if you find anything out. I'm still playing with the settings on my Aquos to see if there is a work around.
  • paseeger Dec 26, 2008
    Also have Sharp Aquos 32". My VHS is a separate component from the DVD, but the symptom is the same: DVD good, VHS flashes. It seems to show a number of frames at high speed, then wait with black screen to catch up, then another batch of frames, etc. I am using composite video, and have tried "input 1" or "input 2", and diddled everything I can find in the setup. Any more help yet?
    Master:
  • 788 Answers
Have you tried the VCR on a different TV? Could be a faulty VCR and not the TV.
With what kind of cable do you have the VCR hooked up to the tv with? Composite or Coaxial?
Posted on Jan 11, 2008
Vhs view block
It sounds to me like you have a blank tape or an SVHS tape, which won't play on a VHS machine though they look the same tape.
Jan 25, 2013 | Televison & Video
I have a Magnavox Digital Video Disc Recorder & Video Cassette Recorder. Model# ZV427MG9 A. When recording from a VHS home movie tape to DVD there is a high pitch squealing sound. When playing the DVD...
U play another movie like a Hollywood movie DVD disc play on it have no squealing noises wright?Yes,than the blank DVD discs batch u have is bad.Tries buy another batch DVD blank discs,tries recording again should solved this problems.
Mar 16, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
VHS tape created in France
If it was made with the French standard you will need a machine capable of playing SECAM formats. Your cheapest way to go is to locate a video transfer business which deals in tape transfer. They should have the equipment which can play the tape and record it in a format which you can use. Cost should not be that much.
hardrocko
Thanks for using FixYa
Jan 12, 2010 | TDK T 120HS VHS Tape
VHS won't play correctly - no picture, muffled low voices
Several things.
Check the tape, by opening the cover, to see if the tape is damaged. Look for signs of crinkling at the edges. This is often caused by the roller being worn on one of the VCR.
If it's damaged there's not a lot you can do.
If there's no damage try taking it out of the cassette box and fitting it in a new 'good make' blank tape tape box, discard the new tape in it. Still no good?
Next step, is the tape a movie/tv made by a commercial company. Or a recording on a blank tape?
Did it ever play? (if a movie) if not suspect a pirate tape report seller to FACT.
If a blank tape, try recording on a blank section. If that doesn't work and your video will record on other blank tapes. The tape has something wrong with it.
Some video recorders will play tapes with bad problems IE bad tracking, that others refuse to play, but you will either have to find one owned by a friend or buy one with that claim.
Sep 08, 2009 | Televison & Video
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Blank VHS tapes work; Movie VHS tapes don't
Hello statman_4
I have an important question; Are you watching a VHS tape you recorded of another VHS movie? In other words did You rent Ben Hur and record it and then tried to watch the recording? If you did that's your problem. VCRs in the late 1990's (1997-1999) began to employ MacroVision circuitry in all VCRs, and DTR. MacroVision Circuitry makes the VCR record tapes with MacroVision in such a way that the horizontal and vertical sync pulses are not at the proper amplitude, and the AGC (Automatic Gain Control) is tricked into over compensating thus creating the scrambled picture. There is a way around this. You need to buy a video stabilizer SIMA makes such devices and some other companies do to. You feed the signal from your VCR into the unit and it corrects the video image by readjusting the video signal.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc
Mar 25, 2009 | RCA Televison & Video
VHS-C tape jumpy when playing back
My apologies, I overlooked the "-C" in your post.
This problem is due to a type ofcopy protection built into vcr's.
"Macrovision" copy-protection is merely a weakening of a particular part of the signal that makes up the picture and was primarily intended to prevent people from copying videotapes. I imagine almost everyone's seen it but probably didn't know what they were seeing: the resulting picture is a little jittery and is in black-and-white or alternates between black-and-white and color. The reason you're seeing a blue screen is because modern televisions, in the absence of a signal or a weak signal, will just show a blue screen instead of snow or a very poor picture. As mentioned above, you can get around Macrovision by inserting into your connections a signal amplifier that specifically amplifies the portion of the signal that Macrovision diminishes.
Feb 07, 2009 | Maxell HGX-Gold (4 pack) VHS-C Tape
VHS Won't play
i had the same problem and it turned out my motor was getting realy weak from exessive use and it would cost me more to fix it then it would be for me to buy a new one
Feb 25, 2008 | Emerson EWV403 VHS VCR
Bought a new 42' flat - "No Program or Weak Signal"
Hi,you have not said weather you are using a scart lead(euro connecter)or an RF lead,if you are using the later don't,please connect the vcr to the tv via the scart to scart euro connecters,use a good quality scart lead(the thicker the better)as the thicker ones generally are 21 pins connected meaning it should be auto switching so as soon as you play a tape it will come straight on.
Feb 02, 2008 | Televison & Video
Video 8 tapes
can u play the tapes live from cam use a video caputer card on pc record them live as u play as avi clips then u can save them all on dvd movies using nero 7 vison
Jan 24, 2008 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
Televison & Video Logo
646 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
