Question about Car Audio & Video
Ecu on ford fiesta
Driving down the road my fiesta just cut out! engine would turn over but will not fire up! aa said it was crank shaft censor, so changed that but didnt work! so had it diagnosed and they said it was the ecu! changed that and its the same! no spark at plugs! its a 1996 model! please help ime running out of money!!!!
  • Robin Cox
    Robin Cox May 25, 2012
    did you get it sorted just been out to one like this it was the fuel pump fuse blown! number 31 10 amp fuse box under the bonnet near side back of engine bay. Rob.
Yea faults that are intermittent are hard to diagnose, if you are still interested just message back on here as i seen it was posted on jan 11 08.
Posted on Nov 13, 2008
1998 Ford Explorer. 4.0 liter. SOHC Good fuel pressure. & good fire on plugs. Changed crankshaft sensor . Still wont crank, No fuel is getting thru the Injectors.
check for a problem cam shaft censor as well as a crank position sensor as both are required to be operational for the ECM to start the engine
Jun 25, 2016 | 1998 Ford Explorer
Ford fiesta 1,4 why is it difficult to start and jerks when driving
hi could b a number of things need to put a code reader on it and see what codes it has stored on the ecu could b a crank sensor or throttle body or o2 sensor is your engine management light on the dash need more info thanx
Sep 26, 2014 | 2007 Ford Fiesta 1.4
Was going down the road an my truck cut off.it turns over but no fire
When it cranks over does it sound normal or does it sound like you have no compression? You may have a broken timing chain.
Jan 27, 2014 | Dodge Dakota Cars & Trucks
L have a 2003 Kia Sorento, sometimes it will just turn over but won,t crank. after a while it will start up. or l can be driving down the road and it will start poping and cut off, and won,t start.it does...
It will be a position sensor problem Check the air gap and check that the censor rotor is tight and that there is no material getting in the air gap causing a problem
Jan 06, 2014 | Kia Cars & Trucks
2003 Dodge Caravan sxt
Is the check engine light on ?
Aug 06, 2012 | 2003 Dodge Caravan
Ford 1994 Explorer. After 20-30 minutes of
yes the egr could be clogged or loosing vaccum check the valve by taking it out or looking to see if the pickup tube on the valve is bad or has a pin hole in it.
Jul 01, 2010 | 1994 Ford Explorer Limited
My ford f 150 1998 is not fireing wheres the crank shaft censor located at
you don't have crank signal to fire your plugs is that what you mean if so check for correct power going to sensor and if hall effect or magnetic generating signal sensor in order to determine the proper testing procedure
Jan 19, 2010 | 1997 Ford F150 Regular Cab
Plenty of battery power,engine turns,will not start
the best thing to do is have the cpu read for any fult codes it could be some thing like the crank shaft censor playing up or the cam shaft censor but the problem is in the cpu
Nov 15, 2009 | 2003 Dodge Dakota Club Cab
Truck cuts off while driving down the road.
Replace the TFI module. Ford back in 1986 thur 1993 had problems like the one you wrote about. TFI module gets hot and shuts car or truck off then when it cools sometmies starts and sometimes not.
Jun 14, 2009 | 1993 Ford F150 SuperCab
Cranks but wont turn over
you know. i took it to a mechanic and actually.... The timing belt cut the Crank Shaft Censor... So it was the crank shaft censor again. The wires were routed wrong from the first mechanic that "fixed" the car.
Aug 01, 2008 | 2000 Hyundai Sonata
Car Audio & Video Logo
689 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
