Address book My office has an Sharp AR-M550N, how do I add names to the local address book?
  • 62 Answers
Hi, are you talking about addresses for network scan?, if so load the scan disk on each users machine and save their profiles to the machine. regards
Andy
Posted on Jan 18, 2008
6ya staff
SOURCE:
How do I add an email address to my contacts on a sharp black and white printer?
It is easiest to do from the webpage of the machine. Type the ip address for the copier into a web browser that is in the local network. On the left you should see an option for destinations press that and then press register new.
I’m happy to help further over the phone at https://www.6ya.com/expert/ethan_e84416e0b13809d2
Oct 29, 2014 | Sharp AR-M317 Black and White Copier
Sharp AR-M257 clearing user names in scan feature
Please log in machine with you browser with machine ip address
and user name and password is admin and Sharp and go to address book and remove anything you do not want.
Dec 04, 2013 | Sharp AR-M257 Black and White Copier
Sharp AR-M550N close the upper left side cover
Close the lower left side cover error :
this problem is for under the left door
for fix this problem push the all part on left side
under the door is important
mehdi ebrahimi iran,karaj
Oct 19, 2012 | Sharp AR-M550N Copier
I have a Sharp AR-M550N; It's giving me a code Network error CE -02? How can i solve that error?
CE 02 is rarely a machine problem, It normally is an addressing problem between the machine and the network. That code indicates a communication problem, normally relating to scanning.
Often times it is a wrong character in an address.
Feb 01, 2011 | Sharp AR-M550N Copier
How to add email address to AR-BC320 copier
Hello connie_durha, Thank you for the clarification. Try the following:
  1. Type the ip address into your web browser and press enter.
  2. A printer information page will appear for your Sharp printer.
  3. There should be a section for email (it might be labeled "sender").
  4. A login box may popup- login name is admin / password is Sharp
  5. Once you are in click "add."
  6. Fill in the required boxes and optional if necessary.
  7. Once everything is filled in click "submit."
  8. Your email address should now be added to the printer.
Please post a reply with any issues. Hopefully this helps. Thank you for using FixYa! Edward
Aug 24, 2010 | Sharp AR-BC320 All-In-One Led Printer
Unable to change names/add addresses in the address book faxing
Try Googling (Kyocera)(KM-3035)(manual) without parens for instructions.
Nov 03, 2017 | Kyocera Mita KM-3035 All-In-One Laser...
I have a Sharp AR-N275 and would like to add a user for the scanner. I have "sharpdesk" installed on the pc, but how do I add the user to the address book on the machine?
go to your internet browser and type the IP address of the copier into the address bar not the search bar the browser should open the web page for the copier if you need help from there then post to me
Jan 27, 2010 | Sharp Office Equipment & Supplies
Add an address to group
Most of these settings for scanning to a destination can be done from the web interface page. Find the IP of the copier and type it into your web browser. Locate address book and make changes there.
Jun 16, 2009 | Sharp AR-M355N Copier
How do I enter phone numbers into the address book for faxes
select (custom settings) then (address control)
then (diret address) its easy from this point
Mar 05, 2009 | Sharp AR-M455N Copier
Change email address
You'll want to access the device webpage. Open web browser on your computer and type the IP address of the machine in the address bar. On the page that comes up to the left you should find admin mode. Type the user name and password, the default is
User name: admin
Password: Sharp
Case sensitive
Click the Destination link, find your name you want to change and click the edit button.
There is a checkbox to add that destination to the Frequently Used tab, if you uncheck that box it will remove you from that tab.
Nov 28, 2008 | Sharp AR-M450N Copier
Open Questions:
410 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
