Question about Keyspan (UPR-112)
Parallel port I am attempting to connect a 25 pin Iomega Zip drive to my HP pc which has no 25 pin connections. I have a Keyspan UPR-112 converter from Frys and am unable to get it to connect me up.
    Master:
  • 788 Answers
Did you install the CD that came with the Keyspan before installing? Windows version of Windows do you use?
Posted on Jan 11, 2008
6ya staff
SOURCE:
Where can I get appropriate USB cable, i.e, parallel to USB not the original parallel to parallel?
So you have an old Zip drive with a parallel port? You can't connect that using USB. Nor can you connect that to a computer running any version of Windows newer than XP.
Two options:
1) Buy a USB version of the Zip drive and use it to read your disks. Used, USB Zip drives seem to run around $35 or so.
2) Get a computer using an old version of Windows. If it doesn't have a parallel port, you should be able to buy a PCI card with a parallel port on it.
Once you're able to access the files, copy them onto a USB thumb drive. For $10, you can get a 32 GB USB drive, which should hold everything from at least 320 Zip disks.
Sep 23, 2015 | Iomega Zip 100MB (31714) External ZIP...
Www iomega com
I believe you can use a PATA drive to USB adaptor. Hopefully you have the software for the Iomega drive, or perhaps that is available from Iomega. I've never tried it with an Iomega but have with numerous other drives. I hope this helps.
May 18, 2013 | Iomega ZIP 250 - Disk drive - ZIP ( 250 MB...
How could I install my Iomega ZIP 100 driver in my laptop? The operating system is Windows XP. The ZIP 100 is already connected to the laptop through a Parallel Port to USB adaptor.
You can download drivers for the zip-drive at:
https://iomega-na-en.custhelp.com/app/answers/detail/a_id/16736
They should help.
Aug 01, 2011 | Computers & Internet
HP DESK TOP 840C PRINTER CONNECTION
They do make adater cables for such problems. Here is just one such example: Parallel to USB Cable
Make sure you get the correct 25 pin cable. They have this type also:
Parallel to USB Cable 2
You can search the web for more companies. Google parallel to usb printer cable.
After saying all that and checking your printer info, I see that the 840c has both a parallel and a USB cable port. See page 21 of the manual: HP 840c Manual
If you go that route, you will need a standard USB cable. The shorter the better, but no longer than a 6' cable. Make sure you follow the iinstallation instructions for the USB setup in the manual.
Thanks for using Fixya.
Apr 14, 2010 | HP DeskJet 840c InkJet Printer
Need a driver for macintosh
If its a really old zip drive then its SCSI and not usb. It may even be parallel for a pc. To avoid having to deal with drivers or anything like that. You could probably find a cheap external USB zip drive. You dont need drivers for this, only for the older ones.
Also, you might go to an apple store and get some kid to burn a cd from it, if its just a one time thing.
Hope this helps!
Jan 18, 2009 | Iomega Zip 100MB (31714) External ZIP...
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Windows Vista won't boot
Windows vista is not included in product min OS requirements technical details. That may be the problem.
Product Features
  • HP DC195A Serial/Parallel Multi I/O PCI Card General Features: Serial/Parallel adapter PCI interface
  • Easy to install Fast transfer rate (430 Kbps) Connectors: One (1) Serial port (9-pin D-Sub DB-9)
  • One (1) Parallel port (25-pin D-Sub DB-25) Regulatory Approvals: FCC CE
Technical Details
  • Model: DC195A
  • Item Package Quantity: 1
  • Hardware Platform: PC
  • networking_feature: Parallel/serial adapter
  • form_factor: Plug-in card
  • Network Interface Description: PCI
  • Connectivity Technology: Wired
  • Data Link Protocol: Parallel, RS-232
  • Minimum system requirements: Microsoft Windows NT, Microsoft Windows XP Home Edition, Microsoft Windows 2000 / XP Professional
  • Depth: 4.7 inches
  • Height: 3.5 inches
Jan 22, 2008 | HP (DC195A) Serial Adapter
Iomega zip drive problem
I'm trying to re-install iomegaware zip 100 & it tells me it does not support windows 2000 so I need to update drivers. Can you please help me figure this out as I rely on my zip for backups. I have version 21.1.
thanks very much
Marlene
Dec 31, 2007 | Iomega (32453) External ZIP Drive
Iomega external 100mb zip drive
Check out this site: http://www.iomega.com/europe/support/english/documents/11382e.html The pictures that have red arrows show where the cable that should connect to your coputer should go. Yours might be this one: http://www.iomega.com/support/images/iom_sup_zip_100_usb_new_rear.gif
Mar 13, 2007 | Iomega Zip 100MB (31714) External ZIP...
Keyspan (UPR-112) Logo
166 people viewed this question
Top Keyspan Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Keyspan Computer and Internet Expert? Answer questions, earn points and help others
