The list of TV programing codes and steps for activating a brand new Phillips Universal Remote are lost. The television is a 25'' JVC cathode ray tube model from the late 80's. The set works, electricity is going to the remote; but, the channels, power, volumne, etc. need to be worked manually. Can you help me?
I have a philips universal remote and i am trying to program it to a symphonic tv to it and i am having trouble can you help
Here is a link for you.
http://www.universal-remote.net/philipsmagnavox.html
hope this helps you out.
Cheers Little Dish Fitter.
11866, 10054, 10030, 10706, 11990, 11963, 11913, 11904, 11525, 11365, 11198, 10802, 10230, 10187, 10186, 10179, 10096, 10036, 10028, 10024, 10020
Philips TV codes with Comcast Universal remote control are:-
10054, 10037, 10690, 11483
1. Turn on the TV
NOTE: Please read steps 2 to 4 completely before proceeding. Highlight or write down the codes and device you wish to program before moving on to step 2.
2. Press and hold SETuntil the Red Light blinks twice, then release SET.
3. Locate the code for your device in Manufacturer's Codes on the back of this user guide. Brands are listed in alphabetical order with the most popular codes listed first.
4. Enter the first five-digit code for your TV. If you perform this procedure correctly, the Red Light will blink twice
NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 5 with a valid code.
5. Aim the remote control at your TV and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 4, trying each code listed for your brand until you find one that works. If it still does not work, try Searching For Your Code
OK.
11864, 10054, 10030, 10171, 10020, 10028, 10065, 10096, 11314, 11665, 11963
Turn on the TV
5. Aim the remote control at your TV and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 4, trying each code listed for your brand until you find one that works. If it still does not work, try Searching For Your Code.
Ok.
