Question about HP LaserJet 2420 Printer
LJ 2430 Printing Blank Pages
LJ 2430 printing Blank, Installed laser scanner, and High Voltage power supply. Still printing blank.
  • 417 Answers
HI there have you tried the toner cartridge as this could also cause this problem? Also change the transfer roller and are the bands going from left to right or from up to down. If the bands are left to right change both if up to down more likely to be the toner cartridge.
Hope this helps you
Thanks J
Posted on Jan 13, 2008
Printer only printing blank pages
scanner unit problem. open and clean the mirrors and lenses with chamois/lint free cloth. if it solved OK. if not replace the unit.
Oct 20, 2014 | HP Photosmart C5380 All-In-One Laser...
Hp lj cp1518 printer printing blank pages
you need new ink if not used it will dry up. if you are not sure go buy black ink
Jun 20, 2014 | HP Color Laserjet Cp1518ni - Printer -...
How to fix blank pager printing on hp laserjet 2420
the laser beam is block you need to open the printer and unjammed
since every time you put a toner cartridge there is a fin that moves the cover over the laser or maybe you have a faulty cartridge that the fin is broken
Apr 09, 2014 | HP LaserJet 2420 Printer
Blank and black pages
high voltage power supply(printer side card )complaint
Apr 02, 2014 | Samsung SCX Office Equipment & Supplies
Printing heavy bars or blank pages
PLEASE REPLACE PRINTER LSU OR HIGH VOLTAGE POWER SUPPLY
Feb 14, 2014 | Samsung SCX-4828FN All-In-One Laser...
I get blank pages when printing. Sometimes all pages are blank, sometimes first and last page print, with blank middle pages.
hi,check your printing setting and then print.
or....
uninstall the printer then install the printer again then printer has default setting and print the paper.
sometimes printer current pages print wich is selected by setting.you must select all the pages.
to change the setting,,,
1-open control panel then open printers and faxes then check seeting.
Apr 12, 2009 | HP DeskJet 842c InkJet Printer
OKI C5600 printer is printing Blank pages
you looking at 3 posibles one is the scanner may need to be replace or the low voltage power supply or you looking at a posible drum problem
Nov 22, 2008 | Ricoh Aficio 250 Copier
Printing blank pages
This sounds like a laser or high voltage problem. Very much technical to fix.
Nov 01, 2008 | Brother HL-2070N Laser Printer
The problem is may be scanner assembly of the printer or tonner sensor check this peripheral if possible.
Mar 01, 2008 | Brother HL-2040 Laser Printer
Printing problems
Hi, There are 3 things that can cause blank pages. The most common is the laser shutter pops off on the spring side and blocks the laser from hitting the cartridge. The shutter opens when the cartridge is inserted. The cartridge guide that sits above and behind the cartridge misteriously gets eaten by the printer. Without it, the cartridge rides too high for the toner to transfer. The high voltage power supply goes totally dead. If the first 2 are ok, then replace the high voltage power supply. (There are 2 power supplies in the printer. One the low voltage power supply supplies voltage to all the boards, fans, etc. The high voltage ps only supplies voltage to the toner cartridge.)PS-The laser/scanner shutter is found under the top cover and below and by the front of the laser/scanner assembly (black box). Control of the shutter is on the left side of the laser/scanner. Good luck
Sep 03, 2007 | HP LaserJet 4 plus Printer
HP LaserJet 2420 Printer Logo
1,093 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
