Maytag washing machine
I need to know how to remove the agitator
  • 6 more comments
  • Anonymous Mar 23, 2008
    top part of agitator does not turn but the bottom portion does.
    need to remove whole agitator.
  • Anonymous Aug 02, 2008
    how to remove agitor
  • gbcar30 Aug 10, 2008
    How do I remove the agitator for the Maytag Atlantis top load washing machine. Also, does the fabric softener dispenser unscrew from the top for cleaning?
  • Anonymous Aug 22, 2008
    I need to look under the agitator. I got the top cup out but cannot find a bolt or way to remove the agitator?
  • weingpc Sep 17, 2008
    Same problem here, but mine is a Kenmore model #110.29962891. Top cap pops off easily, but underneath is a plastic assembly with a square center. Looks like you need a special tool or something. What am I missing? Anyone have any help out there? Thanks.
  • cocostarr Oct 31, 2008
    how to remove agitator from westinghouse model 609s
  • Anonymous Nov 25, 2008
    removing top agitator
Just to clarify weingpc's response, if you pop off the cap and look in, you will see a 1/2" square socket. Take your 1/2" extension and rachet, drop it in and unscrew it counter clockwise. Pull it out and pull out the next piece underneath, which if you're having problems with the agitator being "jumpy" is the piece you need to replace.
Posted on Dec 20, 2008
THEY SAY IT JUST SNAPS OFF,
OK ,HOW DO YOU SNAP IT OFF
Posted on Mar 16, 2008
It's probably too late for all the previous posters, but for future visitors I just figured this out. You just have to use the largest size ratchet wrench and back the plastic assembly off. Then the whole assembly lifts off. Then you can lift off the agitator. It was really easy, once I realized the tool I needed was already in my toolbox. Take care!
Posted on Sep 17, 2008
Can I remove washing machine agitator to clean it. I have a Maytag Atlantis washer
Hello, Bonnie -
The instructions for cleaning the Maytag Atlantis washing machine can be found in the User's Guide for the machine.
I can only think that you do not have the User's Guide. If that is the case, you can download one (free) here:
https://www.manualslib.com/manual/294972/Maytag-Atlantis-Mav6451aww.html#manual
You will need Adobe Acrobat Reader software (free). After you download the guide, save it to your Documents folder and use a file name you can find again easily - example: Maytag Atlantis Washer Manual.
Cleaning instructions are on Page 8 of the guide.
Note: Unless you are mechanically inclined, do not remove the agitator. You may not install it again properly and then will have to pay for a service call.
Best wishes.
Mar 03, 2018 | Maytag Washing Machines
I have taken my Maytag Performa PAV 3300AGW top loader washing machine apart after grinding noises were comming from the machine. After removing the drive pully mechanism from the agitator shaft I dis
This should fix you up nicely:
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-PAV3300AGW/3048/0153200/M0604157/00004?blt=06&prst=&shdMod=
Good Luck.
Jan 04, 2013 | Maytag Washing Machines
How do you take out the agitator?
I don't know this machine but if you have removed all the fasteners, you might try this. I found that putting a mountain bike inner tube under the agitator around the edge with only the stem exposed and pumping it up with a hand pump can pop off the agitator from an old Maytag wringer washer. Maybe this will help you.
Mar 15, 2010 | Maytag PAV2300 Top Load Washer
How do you remove the agitator from a Maytag washing machine Model A407 series 02?
Loosen the 1/4 inch hex nut on the side of the agitator about 6 inches up from the bottom.
Then pull up on the agitator.
Nov 11, 2009 | Maytag Washing Machines
Could you please tell me how to remove the agitator for cleaning on a Maytag top loading performa machine heavy duty.super size 3 speeds quiet series 100 13 cycles Thank you Bob Clark bobgc@bigpond.com
The agitator on a Maytag Performa comes off by removing the center post cap and dispenser by pulling on it. Locate the agitator bolt and loosen (you may need to hold the agitator in place while loosening). With the bolt removed, the agitator will lift off.
If you still have questions, please let me know. I hope this helps you.
Sep 16, 2009 | Washing Machines
How do i remove the agitator
If this is a true Maytag, there is a 1/4 inch hex head bolt in the lower portion of the agitator, on the side. Loosen the bolt and pull the agitator off. If not a true Maytag I will need a model number.
Jul 05, 2009 | Maytag Washing Machines
Maytag washer fabric softener dispenser is yucky
There is a 1/4" machine screw in a recessed hole close to the bottom of the agitator. Remove screw. Lift agitator off agitate shaft.
Nov 28, 2007 | Washing Machines
Washing Machines Logo
1,283 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
