Question about Candy Dishwashers
Candy dfi50 dishwasher,leaking door
Hi,about half way through the cycle,when the machine is filling,when there is about 3inches of water in the machine,it starts to leak out the left hand side of the door.We have replaced the door latch and checked the door seal,but it looks fine.The machine is only 3 years old.Do you know what the problem could be.?Thanks .Sarah.
  • Anonymous Mar 04, 2009
    the same!
  • 641 Answers
SOURCE: Candy a8001 dishwasher
It sound that the problem is cause the water level switch. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you will find it easily. Clear tube first from any obstruction, In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it doesn't react, you should replace it. Good luck !
Posted on Aug 29, 2007
  • 90 Answers
SOURCE: Whirlpool DU1100XTPS dishwasher leaking from front door panel
are there soap suds coming out of the door?
Posted on Jan 06, 2008
  • 249 Answers
SOURCE: Candy cs455 m dishwasher tripping out power
check heating element
Posted on Mar 21, 2008
  • 4 Answers
SOURCE: door won't shut
Is there sufficient spring reaction? Spring weak or broken? Has latch or catch moved? Is there adjustment on either? Is there debris stopping mechanism from working? Has door dropped?
Posted on May 11, 2008
  • 489 Answers
SOURCE: Door leak in LG LDF6810ST Built-in Dishwasher
Your drying vent tube is probably leaking inside the door panel.  Remove the outer front panel and on the top left side, there is long white plastic tube connected to the dryer fan assembly.  In that connection is where the problem is.  You will need to disassemble the fan from the door, disconnect the tube from the fan, clean out the water and debris and use silicone when reassembling the tube to the fan.
Posted on Jun 08, 2008
Instructions or Manual required
Actually every dishwasher I've worked on had one water inlet and it was always for hot water. Approximately 3 gallons per cycle.
Mar 25, 2014 | Candy 24 in. CD623 Free-standing...
Candy Dishwasher leaks from front door during cycle.
Sounds like your gasket has a problem or --- are you using HE soap as you should? Maybe too many suds is causing the problem
Jan 08, 2014 | Candy Dishwashers
Wrong dishwashing liquid used created out of control suds won't finish cycle. cleaned away suds towel and wet vac but foes not work
HI- Ah yes, the suds. Your flood switch has probably been tripped. Unplug the machine or flip the breaker. Remove the lower kick panel and you'll see the white plastic bottom of the dishwasher pan. This is designed to catch the water (or suds) if there is a leak or the water (or suds) over fill it. This will take awhile but get some pliable rag and carefully put it in the space between the bottom of the dishwasher and the pan. There is a styrofoam float on the left side about halfway back, this has to be down for the dishwasher to advance the cycle and get out of drain mode. Just keep soaking the water up (you kinda have to go over the plastic lip of the pan and down wherever there is an opening large enough to get the rag into. Once it is pretty dry it should run ok. Regarding the suds. If you get the machine to run ok then start a rinse cycle and once the water is done filling open the door and add about 4 tablespoons of any cooking oil to the water. Shut the door and let the machine run for about 10 seconds, open the door check to see if there are still a lot of suds, if so cancel the cycle to drain the machine and repeat. Hope this helps, good luck.
Sep 24, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Problem with candy dishwasher model CSF 456M.
hi it may need a new inlet valve,can you hear a humming sound when its due to fill.or is it doing nothing.if its not humming change the valve,also these dishwashers are well known for overheating and sticking on cycle.
Jun 01, 2010 | Dishwashers
Water Pouring out of door, appliance stuck on wash
dishwasher leaking from the door or from the bottom of the door is common problem and yes its advisable to get it fixed.but if its having any other problem other then leaking then it has to be checked first.but leaking problem is common it can be solved.first from which part of the door area the leak is occuring that has to be checked.
Some common leaking trouble makers....
Leaks at the door:
Door gasket loose/torn
Corner gaskets or door baffle/vent gasket
Door lock/latch loose/broken
Split spray arm
Over filling with water...usually the level is just under the heating element is normal
Something leaking through the door...like the soap or rinse agent dispenser gasket, silverware basket button.
Door hinge(s) bent
Wrong soap was used...dish sink soap instead of dishwasher soap
Rinse aid being used with mechanically softened water ( makes foam or suds inside the dishwasher )
Leaks from under the unit:
Look for whiting or calcium stain on the motor and pump assembly = motor and pump assembly seal leak...access panel removal help
Hose for upper spray arm split
Fill hose split or fill hose spout air inlet is calcium covered
Drain hose is split
Rusted liner...metal liners only
Fill valve leaking or allowing water to fill all the time
Heating element ends....where they come out through the dishwasher liner
Float or float gasket
for parts you can get it from
www.repairclinic.com
Nov 21, 2009 | Candy Dishwashers
Candy nova cd112 dishwasher fills with water then stops working
nova cd112 this is a simple fix the machine has a electronic switch to add water to the machine it then has another switch to say the machine has water iin it , this switch is the one that is not working this is the one that turns on the element and heat the water .it costs around a tenner to replace u can find it as it is connected to the element via a wire conection .this a a common problem of over enginearing as this switch is not needed and is not on older machine .ie this switch can only come on when the machine has water in it in other words only after the switch to put water in the machine has been on.can this go on i hope u know what i mean lol. now u can replace this yourself or get an engineer it should take an engineer no more than 10/15 mins to fix better still have him bypass this switch and u will never haver the problem again as this switch is prone to going fixthis and the machine should last years no problem as its not a bad machine not quite a bosch but better than a zanussi or indicit etc hope this helps and may i just say that i tried everything including replacing the element ,stat and cpu non of which worked before realizing it was this .i must also say before u try this. Switch on your machine on put it on a universal cycle as u hear the water going in the machine open the door and add hot water as hot as u can close the door and the machine should do a full cycle including emptying and reheating the water this proves its not the cpu ,element or stat note the machine will not do the cycle without the hot water going in at the start if it does the cycle then its 100 % this switch hope this helps and sorry for the lond explantion bye
Feb 20, 2009 | Candy 24 in. CD622 Free-standing...
Dishwasher not washing properly
Can you provide more information on symptoms: Does machine fill? Does water come out of the spray arms a) at all and b) in convincing quantities (part way through the cycle, switch off, open the door straight away and see what is happening inside). Do you get the same problem if you run the machine without any dishes in? Can the spray arms be turned freely by hand? Knowing the answers to these should help narrow the problem down. A.
May 07, 2007 | Candy CD623X Free-standing Dishwasher
Jan 27, 2007 | Candy 24 in. CD622 Free-standing...
Dishwashers Logo
59 people viewed this question
Top Candy Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
