Question about HP LaserJet 1300n Printer
PAPER BLOCKING HELLO.....I HAVE A PROBLEM
  • 417 Answers
HI there I take it that you have a paper jam open the back door and check that there isn't any paper wrapped around the fuser roller you will be able to see it. If there is then push the little green levers down and try to remove paper from the cartridge side open front cover and remove cartridge if you can see the tail end of the paper pull slowly towards you. once removed close rear door and instll toner and start printing again. If you cannot remove paper from fuser then machine will have to be taken apart the remove paper. Also have you noticed any gray plastic film that has come out with the prints if so then the fuser film is broken and that will need a new fuser unit installed.
If the printer simply doesn't pickup the paper then remove the toner cartridge and using a soft cloth wipe clean the little gray rubber tyre that sits in the middle of the machine then test.
Hope this helps you as I didn't have a lot to go on but
Thanks J
Posted on Jan 13, 2008
Getting paper jam message but there is no paper jammed will not reset itself
Generally, when a paper jam message is displayed, there is in fact some sort of debris, dirt, or paper pieces blocking the paper jam sensor. My suggestion, take a thick piece of card stock and manually feed it through the paper path; this should hopefully clear any debris that is blocking the jam sensor in that area. Also, try spraying some canned air into the paper path, as if there is dust blocking the sensor, it will be more likely to be removed with air than card stock.
-David.
Nov 03, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Cannot free paper jammed in hp 4500 printer
you will need to be gentle because the paper will be blocking the sensors
Oct 15, 2010 | HP Designjet 4500ps InkJet Printer
How do i load the paper?!?! theres a white thing in the way helppp
Hello. I think you're referring to the paper guide that's blocking your paper. You can actually slide it to the sides and adjust it so the paper fits. For more information, you can check the User's Guide in the Lexmark website. Just click on this link: http://bit.ly/d5yAk5 . Click on Publications tab on the center of the page. Choose the User's Guide. Hope that will help you.
Mar 25, 2010 | Lexmark Z2300 InkJet Printer
The paper will not feed, it's a x3470
Try the following link http://bit.ly/9gjvRv it will guide you step by step on what you can do to fix the paper feeding problem. Also make sure there are not foreign objects blocking the paper path. This one of the most common problems.
Feb 27, 2010 | Lexmark X3470 All-In-One InkJet Printer
The paper will not ffed through the printer, it
Feb 18, 2010 | Lexmark X3470 All-In-One InkJet Printer
The paper is feeding unevenly and jamming
Agreed. Assume every time this happens something microscopic fell into that tiny pinch of an area. I have found everything from a Tostito crumb to a chip of drywall blocking my paper feed. Flip your machine over and shake it around til the little bugger falls out.
Sep 28, 2009 | Lexmark Z1300 InkJet Photo Printer
Continues to report paper jam even though no paper; reset does nothing.
Try to look for the sensor as some tiny paper shreds might be blocking it which causes the system to detect a paper jam.
Also look for tiny pieces of shredded papers that might got stuck between the rollers.
Aug 01, 2009 | Lexmark X6570 InkJet Printer
Paper jam
If it is getting crumpled in the tray, there is something blocking the paper path.
What I would suggest is taking out the toner and drum cartridge, then remove the paper tray. Tip the machine on it's back and look into the paper feed area for something blocking the paper path.
When it is crumpling the paper like that, the feeder is working fine, just something blocking the paper path.
You can take a minela folder, and gently push it through the paper path to dislodge the obstruction.
Mar 31, 2008 | Sharp AL 1631 Copier
Printer
Remove the paper - carefully examing the paper track - especially the right side to ensure there is no debris blocking. Feed in a thin piece of card. Turn off the printer Hold down service/OK/Custom btton then holding these down- switch on. If still in trouble go to www.fixyourownprinter.com
Sep 03, 2007 | Epson Stylus Photo R220 InkJet Printer
HP LaserJet 1300n Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
