I have the manual. I was already at the Belkin Web Site and they
had nothing to offer. I called Belkin Tec support and was told to go to a qualified electrician. I contacted a couple of battery supply companies but they were not much help either.
I ended up taking the thing apart and found a way to access the battery cage. To do it properly you need to take out the Transformer and other parts, but I was able to bend back the top of the metal battery cage and pull out the batteries and put in the new ones. I then bent the top of the metal cage back to its original position more or less. It is not perfect but it was better than taking the whole thing apart which is what you have to do with this bad design. I will stick to APS in the future which is my other UPS.I have the manual. I was already at the Belkin Web Site and they
You can't post conmments that contain an email address.
You should be able to go to the manufacturer's website and download your model's instruction manual--if they have no helpful information, try googling for it. Good luck
There are a couple of reasons the pony may not work but more information would help. Did the pony word before you replaced the batteries? Some times if you get a new pony (new to you), the batteries in it are old and have corroded. Because the compartment is under the pony, you should probably check and see if the relays and contacts are in good, clean order or if there is corrosion on them. Coke will remove corrosion as will white vinegar. Use a Q-tip. If the contacts are all clean, then you need to check the wiring for a short. You may have to take the fur off to make sure that nothing is broken or touching something metal. Make sure the batteries are installed in the correct order and direction.
It is really hard to get to, but really easy to change.
Unhook the battery cable so you don't blow the new one when you install it. Depending on the location, you may have to remove the oil filter to be able to access the sensor.
Unplug the wire off the end of the sensor, slip a socket onto the old sensor, and unscrew it like you would a spark plug. Before you out the new sensor in make sure it has Teflon tape on the threads. I always a little more than what comes with it.
Screw in the new sensor "hand tight" - then 1/4 to 1/2 turn past hand tight; do not over tighten. Plug the wire on the end. If you removed the oil filter, replace it with new one. Last step - replace the battery cable.
Power Wheels Toddler 6 Volt Rechargeable Replacement Battery all 6 volt batterys will do the job just make sure you get a battery and a charging system together and you may need to split the wires and use electrical tape from the new battery to the old battery system wires
Depending on when you purchased this unit, your battery needs to be replaced. Each battery has a life period to it that is affected by many factors. Heat, usage, leaving the unit attached when the power source is plugged in are just a few. If the laptop is less than a year old, it is under warranty. Contact Acer for a replacement. If it is over a year old you will need to purchase a new battery. I hope this helps and let me know if you require additional information regarding batteries.
The batteries are soldered into place. You will need a soldering iron and electrical solder to replace them. Unsolder the old batteries from the circuit board and solder in the new batteries
If you are not able to do this repair yourself, shaveroutlet.com can do it for you. See information at the link below
This document provides information about replacing the print cartridge for the HP LaserJet 1010 printer series, including life expectancy and replacement instructions.
Print cartridge life expectancy
The life of the print cartridge depends on the amount of toner that your print jobs require. When printing text on letter/A4-size paper at five percent coverage, the print cartridge lasts an average of 2,000 pages. This assumes that you set the print density to three and disable EconoMode. (These are the default settings.) See Ordering supplies for information on ordering replacement print cartridges.
Changing the print cartridge
Follow the below instructions to change the print cartridge:
Open the print cartridge door, and remove the old print cartridge. See the recycling information inside the print cartridge box.
Figure 1: Removing old print cartridge
CAUTION:
To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper.
Remove the new print cartridge from the packaging, and gently shake it from side to side to distribute the toner evenly inside the cartridge.
Figure 2: Gently shaking new print cartridge
Pull the tab until all the tape is removed from the print cartridge. Put the tab in the print cartridge box to return for recycling.
Figure 3: Removing tape from print cartridge
Insert the print cartridge in the printer, making sure that the print cartridge is in position. Close the print cartridge door.
Figure 4: Inserting new print cartridge
if there is corrosion from old batteries, you will need to neutralize the acid. take an old toothbrush and some baking soda with a little bit of water and brush the coil and convex area of the copper connector.
Leapster will also offer you a new one at 1/2 the price if you agree to ship back your old broken one.
You will need to get their phone number off the net.
