Question about Frigidaire FES367 Electric Kitchen Range
No heat in oven or on range
I have a Hot Point Electric Range. Last night while cooking dinner the burner quit heating. I proceded to check the rest of the burners and none of them worked, so I check the oven to see if it would heat up, but it also would not heat up. The power to the unit is fine as the clock works, the oven light works, and the indicator lights on each of the burner dials work, but it won't heat up i any way
  • 2 more comments
  • jen1976 Jan 11, 2008
    No, its an electric range
  • jen1976 Jan 14, 2008
    You were absolutley right, there was a power problem, we had an electrician friend take a look over the weekend and it is all fixed. Thanks so much for your help.
  • rm4767 Aug 28, 2008
    I have a Hot Surface elect. range and two of the top surfaces have gone out. Both on the left side but at different times. Is there a fuses or element that can be replaced or ??? Randy M.
  • jvargas129 Nov 10, 2008
    my cooktop an range wont come on the lightscome on but it wont come on
    President:
  • 1,314 Answers
When you turn on the top burners do you hear the ignighters clicking please hold my rating for now as i need to ask a few questions
Posted on Jan 11, 2008
  • robert samples Jan 11, 2008
    Sorry about that thought it was gas. Ok first let me explain something the eoc indicator lights every thing you said is working works off 110. It takes 220 for everything to work. We have a power problem here some where because bake, broil an the top burners are all on separate circuits. One or two may fail at the same time but not all of them. The easiest thing to do is turn the oven breaker off. Then on again sometimes they can partially trip, even though it doesn't look like its tripped. That can cause your problem. Also loose wires at the breaker can do it if that doesn't do. If those check out fine. You can pull the range out and check for 220 at the outlet. If 220 volts ac is there then unplug the range, and take the cover off the cord were the cord goes in the back. Check for bad or burned terminals. Please advise me of what you find, we will go from there but we have a power problem coming to the range hope i explained it well enough. My wife says im too technical lol please don't rate me til we have finshed. Thank you Tech17
  • robert samples Jan 14, 2008
    well im glad thanks for your rating we are all working to make this a reliable site
6ya staff
SOURCE:
Oven wont work everything else is fine
As your oven is electric there is a heating element in the oven, have a look in the oven to find it and check the little plug in caps on the end to make sure they are not loose. If they,re ok check the switch on the front panel sometimes the knob comes loose on the spindle if that's all ok it may be the switch has failed. Good luck.
Jun 16, 2014 | GE Profile JGSP44 Dual Fuel (Electric and...
Maytag Range won't heat up oven or cook top
you have melted internal wiring, probably some mice ate it. call an electrician and DO NOT USE IT!! turn off at the wall/fusebox
Nov 20, 2013 | Maytag MER8770WS 30" Freestanding Electric...
Burner is turns on but not hot enough to cook on. it is an electric range
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Aug 31, 2010 | Kenmore Kitchen Ranges
All my burners arnt working! HELP!!!
There is a cooktop PCB (power control board) which is separate from the oven. Perhaps that is the problem. That board is located behind the cooktop control membrane panel.
Oct 24, 2008 | LG LRE30755 Electric Kitchen Range
Maytag MER5870 Electric Kitchen Range
Hello ppeaches,
Are you sure that the oven isn't heating up more than 100 degrees or are you basing the problem on the ovens readback of 100 degrees? If it truly isn't heating more than 100 degrees then anything inside there should be hot but not so hot as that it can't be touched. Have you tried to cook anything in there? My intent to assist in diagnosing the problem is to determine if it is a control based or read back based issue? Try cooking something that requires at least a 350 degree temp and get back to me on what happens... We;ll get you running after that,,,,,
Sep 22, 2008 | Maytag MER5870 Electric Kitchen Range
The right front burner won't heat
The switch probably failed. Remove power. Take off the top rear cover and inspect the switch for signs of discoloration (burned or brown areas). If looks OK then maybe the element failed.
May 28, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Oct 27, 2007 | Frigidaire FEF366DC Electric Kitchen Range
Stove/oven gets hot then shuts off
Shut the breaker off! These are the exact symptoms that a tenant of ours reported for their range. I went to check the range and found that one of the power wires on the terminal block in the back of the range was burning itself up. It had actually started a small wire fire. You need to pull the range out of it's hole and unplug it. Remove the panel in the back above where the cable goes into the range. Examine the power wires and terminal block carefully, because I bet you'll find one of the wires is burning up and needs to be repaired. Please write back and let know what you find.
Aug 09, 2007 | Frigidaire FES367 Electric Kitchen Range
Frigidaire FES367 Electric Kitchen Range Logo
317 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
