Question about Canon PIXMA MP830 All-In-One InkJet Printer
Canon Pixma830 all-in-one beeps when I connect it to my phone line
As soon as I attach my extension cord from my phone line to the Canon it starts beeping and I'm unable to fax. Any suggestions?
Thanks,
Jody
  • e1ace Mar 16, 2008
    I got the exact same problem... someone pls help
  • 2,176 Answers
When you attach the phone lines, the line coming from the wall must be put in the "L" (line) jack on the machine. The extension phone can be plugged into the other jack. If you have the line coming from the wall to your phone first, and then the extension line coming to the machine, you will get the beeping. You must have two lines plugged into the machine.
Posted on Apr 18, 2008
PowerEdge 2850 server beeps as soon as it is turned on - 3-2-1 beeps format. What has failed?
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
a computer needs its connections to continue its cycle and to have and end to function
obvisously the beeps are windows searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
May 03, 2011 | Dell 3.0 GHz Second Processor for...
Printer trying to receive a fax, but it doesn't print. Does there need to be a separate phone jack into the printer itself, and not just the computer?
Hey!A fax line needs to be connected in the fax machine yes!It sound like u got a dial up modem yes?Plug the phone line into the line jack on the machine,get another cord and plug it in the extension jack on the fax and to your modem!!Hope it helps!!Good Luck!
Nov 05, 2010 | Canon MX300 Office All-In-One Printer
Phone lines are flashing making a loud beeping noise. The screen is texting funny words. Phone is ringing with ambulance style ring before the normal tone
There are 2 possibilities. You have either toasted the system, or you have bad wiring. Start by unplugging all the extensions. The model and time frame is right that this is a TA series box, which has 3 CO lines and 8 extension jacks on every card. Leave the lines plugged in and unplug all the extensions. Now take a phone and plug it into Jack 01. Does it work? If it does, keep plugging extensons in until it fails. That will give you an idea what's bad. If it failed with one phone plugged into jack 1, you probably have a dead system.
Carl
May 10, 2010 | Panasonic KX-T7730 Corded Phone
The phone doesn't like something it's sharing a line with.
First, check to see if the extension number on each phone is different. You may have two extension 11's.
Next, check that line 1 is line 1 one all of the phones, then line 2 is line 2 etc. If one phone has line line 1 showing up on line 2 then you may have wires crossed somewhere. Or if you pick up a line on phone one and line 2 goes red on one of the other phones you have wires crossed.
Last, check in the plugs to make sure the connections are straight. Sometimes when a phone plug is inserted the pins cross and short two lines together.
Mar 18, 2010 | Panasonic KX-T7730 Corded Phone
I attach my inverter with custom battery cables and it powers up. As soon as I plug in an extension cord (any cord)it starts beeping. I don't even have anything plugged into the other end.
please check the voltage of the battery may be the voltage of battery is low or use the multi meter and check DC volts before conneceting the battery and after conneceting once more check the DC volts it could slove the problem
the beeping sound is due to battery low voltage
what is the DC input of the Inverter check the battery hook up if the inverter is of example DC 24 volts please check what is the input
Nov 17, 2009 | Coleman Cable Power Inverter PMP1200
Stop ringing at main phones when outside calls come in.
Here is a link to program line ringing.
It sounds like your extension is forwarded (confirmed by the one beep you hear on an incoming call.
From any display phone, press Feature 11
then enter your extension number 2 times. So if you are extension 20, do this:
Feature11-20-20
see if that does it.
May 28, 2009 | Lucent PARTNER18 Corded Phone
Lucent Partner Mail VS - need cordless phone
Each of the modular jacks at the cabinet will accept a single line telephone. I don't think you can "bridge" a phone on 12 year old software, but if there is a spare jack, it will work with a plain old cordless phone. Plug one in, dial 10, and read what extension you have. Here's a manual for a 4.1 Partner system to help you program the ringing. Programming is done from the display phone at extension 10 or 11.
http://public.carl.airpost.net/Avaya/Partner_ACS.pdf
After you find the extension, save yourself the trouble and go to page 447 of the attached pdf. It details how to set the Automatic line preference and ringing of the cordless. The difference is that you will select your lines AFTER the intercom as in ** LIC RIC 1 2 3 4, or 4 3 2 1. This is important! You'll then be able to dial "9" to get an outside line in forward or reverse order and still call internally.
If you find you don't get an outside line when you dial "9", then keep reading the manual, you need to put your lines in groups.
Carl
Apr 08, 2009 | Avaya Lucent Partner 616 Phone
Sendin or receiving faxes
check your handset, is it placed properly
Jan 31, 2008 | Canon FAX-JX200
Canon PIXMA MP830 All-In-One InkJet Printer Logo
80 people viewed this question
old marine
old marine
