Question about Samsung HP-R5072 50 in. Plasma HDTV
V-scan voltage adjustment
How do i adjust the v-scan voltage on a hp-r5052 smasung
  • 3 more comments
  • jeff0507 Feb 11, 2008
    can you tell us HOW you fixed it? I have the same exact problem.
  • mudvayne Mar 02, 2008
    yes there are red pixels and sometimes green in dark shaded areas is the v-scan simple to adjust or should i call someone? Thanks for help
  • madowney Oct 13, 2008
    Yes, I have the same problem. Please tell us HOW you fixed it.
  • l_bautch Nov 09, 2008
    I have this problem too...do you guys have a red or green line on the left side of the TV as well?
  • Jcull Jan 23, 2009
    I have a simular issue with a Samsung HP-s5033. i get green "snow" flickering all over the screen (mostly in dark areas) and some red sonw as well. but mostly green.
    is this a voltage problem that i can try to adjust?
    if so do i need any special tools to try? I was going to give the set the toss and get a new on seeing as samung will not help fix it and i dont like the only local repair shop..
    thanks for any info
    Jeff
UPDATE: I opened the back of the set and after doing some looking around i found the adjustments for the voltages listed on the PDP sticker. Va, Ve, Vsync, Vset, and Vs, I think that are the ones. after checking this voltages with a voltmeter i found that they are out of wack.. you can set there voltages with a little screw adjuster on the board.. (if you plan on doing this make sure you dont touch anything live duh) This porcess was very simple after finding the adjustments....
This helped the picture however... i am still getting a little green show on dark areas and black show on blue... there are 2 adjustments on the TV that are not listed at all.. they do not effect the voltages of the others but seem to be the main power to the board .... they do effect the picture a great deal...
by playin guess and check with these adjustments i can get the set lamost perfect.... however it seems that i can adjust so that there is no green snow on darks but a little blue show starts to show. or i can get rid of the blue all togeher and a little green starts to show.
does anyone know if there is a spec for these adjustments and if so what they are??
hope this help...
Jeff
Posted on Jan 27, 2009
    Sergeant:
  • 261 Answers
If you adjust v-scan make sure you adjust it for the setting that is marked on the panel when you take the back off. Why do you want to adjust v-scan? are you noticing red pixels firing or green ones? This is a diffusion problem and i am familiar with the fix for that. Let me know and we can go from there. Also what is the version of the HP-R5052? Talk to you soon . Thank you Jay
Posted on Jan 31, 2008
Bad picture on Samsung HP-R5052 50 in. Plasma HDTV
Hi there!
I suggest changing the screen , it is getting worn out
peace.
May 18, 2017 | Samsung HP-R5052 50 in. Plasma HDTV
High voltage rpm power generator output
Not sure what you mean "high voltage rpm power generator out", however many people have asked how to adjust the engine for proper voltage output. On generators with~out a voltage regulator, I adjust the engine RPM by using a digital voltage meter that has a Hz setting. Adjust the governor untill the meter displays 60 Hz. With the geneator producing 60 cycles, I know that the engine is turning 3600 rpm (the engine produces max hp when it is turning 3600 rpm). At this point, read the voltage output to verify that the range is between 115 ~ 120. On generators with a voltage regulator, verify/adjust that generator is producing 60 cycles then adjust voltage by turning screw at the regulator (some regulators are sealed with potting compound and can not be adjusted). If your power demands are not that great and you appliance can operate at 50 cycles, adjust governor as needed. Lowering to 50 cycles will also reduce output voltage. Good luck
Oct 10, 2011 | Coleman Powermate Powermate 5000W...
BROKEN SCREEN CAN I REPLACE IT? IF SO WHERE DO I FIND IT
You need to contact Samsung call center or serching web site which Samsung authorized TV reparing company.
Feb 24, 2009 | Samsung HP-R5052 50 in. Plasma HDTV
Voltage adjustment?
You better to let pros doing.
Jan 22, 2009 | Samsung HP-R5052 50 in. Plasma HDTV
Red Dots
Need to adjust some voltage on Power Board & Y-Main Board
Dec 10, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Red sparkling on dark areas hp-r5052
Voltage adjustments can fix this on the power supply..
Aug 18, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung HP-R5052
This happened to me and it was a main power supply board. I found one at partsstore and replaced it.. that was the issue for me..
Aug 16, 2008 | Samsung HP-R5052 50 in. Plasma HDTV
Green and red pixel snow
you can adjust the V-scan voltages the adjustor is on the Y-main board, locate the test point and adjust down around 15 volt
Jul 02, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Gainey image on tv
You have to locate the test points and the adjustors using a voltage meter and a plastic probe, only adjust the V-scan voltage + - 15 volts.
Mar 01, 2008 | Samsung HP-S5053 Television
V scan voltage
Try to adjust the V scan voltage down about 5-10V. If still not working, also try to adjust the Vs voltage down about 5-10V.
Dec 02, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung HP-R5072 50 in. Plasma HDTV Logo
2,800 people viewed this question
Jerry Greenberg
Jerry Greenberg
