I would like to know how much to fix my grado headphones and is this a common problem.
Headphones are built to resist most drops but it depends on the force of the drop and on to what they drop.
To repaire you need to look inside the one that doesn't work, to see what is wrong. So first remove the ear cushion of the offending side. Then you should see small screws. Remove these and the top should come off. You should be able to see the problem. If it's the speaker itself, you will need to get a replacement from either the maker, or a service center for the brand. Some repair shops will order the part for you for a fee.
The ear pad should just pull off with some effort. If you find more foam underneath peal it off if glued, you can reglue it on afterwards.
