Question about Acer Aspire 3000 Notebook
Disabled Service Hi Can you help please!!! I had a high CPU usage and through FIXYA, i was directed to msiconfig, where i disabelled certain start up processes through the configuration manager. I can't seem to get my internet to work anymore. No network connections seem to exist anymore and i get the following message. Is this something that can be repaired easily? Configuration Manager: The plug and Play service or another required serivce is not available.
  • Kitty Boo Jan 12, 2008
    I can't get some services to work, some services have stopped altogether, i think thats what is stopping the internet from working.
    Genius:
  • 1,601 Answers
1. Start
2. Run
3. MSconfig
go to services and turn on everything.
Posted on Jan 11, 2008
  • Thomas Christopher
    Thomas Christopher Jan 12, 2008
    Check for viruses and malware in safe mode. then try again.
    Thomas Christopher Jan 15, 2008
    Did this work for you? If so please rerate as FIXYA. If not please let me know so I can help you further.
    Thanks
6ya staff
SOURCE:
High CPU usage from interrupts and ACPI.sys
go to bios see if the cpu cap is off or on also go to system in computer and adjust all index options can also try cpu usage controls in control panel
Feb 28, 2013 | Computers & Internet
Is high CPU usage will make battery life reduction?
Anything that requires more activity from your CPU will shorten the battery charge. It is eating power. I am not sure about "Magician".
Jan 13, 2012 | HP Computers & Internet
What's your problem?It's stuck on logging off
There are many things that might cause your PC to run slowly or restart at time and then. It could be a fragmented disk; fragmented registry; a virus, Trojan, or spy ware; high CPU and/or utilization due to too many programs running; high disk I/O; or something else.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager Button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, Google the name and you should find what the process is for.
Nov 05, 2011 | HP Compaq Presario CQ50-110US Laptop
Cpu usage runs high
1st Go on your start menu and enter the programs, if you have
Windows 7 : type - "msconfig"
Windows Vista - "run" then type "msconfig"
Windows Xp - "run" then type "msconfig"
("Run" might have diferent names depending on your language)
Here disable every thing that you dont want to start up at the start of your computer here is a short list:
- iTunes - Steam - Windows Live Messenger
- Microsoft Office - Adobe (every one of them)
- Microsoft windows sidebar
you can check where they are under "Command" find the path and stop the programs you dont want to start every time you start your computer.
Personaly i have disabled everything that isn't a windows program or a server program.
here is a guide i made for increasing Preformence:
http://www.fixya.com/support/r10219725-speed_up_computer_windows_7_vista_xp
Aug 25, 2011 | Dell Insprion 1150 (DELL1150) PC Desktop
I am not really sure if this caused by the fan performance, but I can confirm that my laptop dell inspiron 1420 is very hot after running about 1 hours.. and often my CPU usage reach 100% when I use Vista...
First, I appreciate the details provided in your question. Thanks!
The specification of your laptop are fine and enough to run and support Vista. It is true that greater number of processes and CPU usage causes, but normally the machine can handle it well if it gets proper ventilation.
Laptop heating issue generally occurs due to fan failure, which may damage the system, if not checked properly. Another cause of overheating is the dust present inside the laptop, which clogs the fan and heatsink. I suggest that you should get you laptop checked by a professional for servicing (if required). I believe immediate action is required to prevent any damage to your machine and data.
Hope it Helps! Let me know if i could be of any further assistance.
CreativeTECH
Nov 25, 2010 | Computers & Internet
Acer aspire 5100 ''high cpu usage ''
Check the add-ons of the IE or your browser.
Jan 10, 2010 | Acer Aspire 5100 Notebook
High CPU when using windows media player online. i dont think fan is working is that the problem
High CPU Temperature = Bad fan
High CPU Usage = Virus or corrupt program
If this helps please vote for my solution.
Dec 18, 2009 | HP Pavilion (PN153AAR) PC Desktop
CPU usage upto 99.99% in HP-UX (11.23 IA64). is there any patch
well. start first by minimizing your running programs,, maybe you have so much unwanted and unused programs, try removing some and check your unit again,, if not a total reformattting would help a lot ..
Nov 18, 2009 | Office Equipment & Supplies
CPU usage very high, mouse very slow man
hi,
you haven't mentioned whether your mouse started moving after you deleted the applications..
Anyway to lower your CPU usage, you can do the following...
1. Run 'msconfig' without the inverted comas in the run dialog box. ( start--> run )
2. Select the startup tab... you can disable all application at startup to load the system faster. or you can select the application that you thing is unnecessary. this needs a restart.
3. Next try to press Ctrl, Alt , Del at the ssame time to launch the task manager. First you will be seeing the application that is running. Go to the next tab that is the Processes tab. under this you will see all the processes that is running and utilsing how much resources . Below on the status bar of that window you will see the cpu usage... Now identify the processes that has the highest memory usage... right click and select end process tree. the process will be stopped. Remember not to end the explorer.exe process. Most resources is utilised by Anti-virus softwares like norton, also by web-browsing and graphics opertaions....
hope to get rated as fixya!!
regards
bzoy..
Jan 03, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
35 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
