Question about Lakewood 798240 Utility Heater
Fan blade is breaking off, - Lakewood 798240 Utility Heater
I have glued blade pieces back on, but don't use super glue if this is a heater.
Posted on Mar 22, 2008
  • 45 Answers
Replace the fan
Posted on Jan 12, 2008
How do i take the fan blade off the motor that its connected to for my gateway laptop model : M-1634u
No. replace the fan if it has been damaged otherwise clean with a dry paint brush and a vacuum cleaner.
Oct 01, 2016 | Gateway M-1634U (LX.W090X.001) PC Notebook
How do i take the fan blades off of the motor that is holding it?
the retainer is in the center of the blades ( finish trim , name plate , knob etc )
it is left hand thread so make like you are doing it up and it will screw off
Oct 01, 2016 | Dryers
I have a broken ceiling fan blade arm for Harbor Breeze Model #OM52-5B/Q1M (outdoor fan). Can I get a replacement arm or do I have to buy a whole new fan?
you will have to get 3 (4) blades as they have to be exactly the same
At this point I would advise a new fan because the settings of the blades have to be exact or it will wobble all over the place
to explain even with a new unit, the fan blades have to be measured from a fixed surface ( normally the ceiling
each tip of the blade has to be the same distance and the front and back of the blade measurements at the tip have to be the same on all blades
If you get it right the fan will spin without any movement
Mar 02, 2016 | Dryers
I can not remove the glass dome to change to bulb on my Minka Aire 3 blade ceiling fan. I believe the model number is UC7084T
Push up on the glass all around to loosen it (be careful not to break). You could also spray a little WD-40 around the top of the glass. If these don't work, you might have to break the glass. Call Minka Aire @ 1-800-307-3267 and let them know the problem and they might send a replacement at no-cost.
Jan 03, 2016 | Minka Aire Ceiling Fan
Akai air conditioner model interior fan blades are broken
Yes...you'll need to remove the blower assembly to replace the cage.
Dec 15, 2013 | Heating & Cooling
A couple years ago I bought a Hampton Bay OUTDOOR ceiling fan... and the blade arms started breaking off shortly after the warranty expired....yes the fan "motor" is guaranteed for life but not...
How outside is the fan? The blades should be a plastic type material. They should not break just because of it being outside. Go to the nearest hardware store and tell them you need some exterior fan blades. Screw them in to the metal arms that connect to the fan and make sure you have all exterior and rust proof parts (screws, fan blade arms, etc). Make sure to tighten the screws good. Then screw them into the fan motor, tightly of course. These should not break. If it continues to break after replacing the blades, then it would seem as if someone or something is breaking them. I've been an electrician for 8 years and have never heard of this happening.
May 21, 2011 | Hampton Bay 52 In. Indoor/Outdoor Tahiti...
Fan clutch is wobbly and making a noice
You should replace the fan clutch. Unbolt it from the water pump and pull cluth and fan out together. Unbolt fan blade making note of blade angles, so you install it right on new clutch. Bolt fan on new clutch and reinstall unit. When the clutch has play or wobbles it is time to replace it before it breaks off and goes thru the radiator.
Nov 08, 2009 | 2000 Dodge Dakota Quad Cab
Model 5645, inside fan blades are breaking off (3 missing). Where can I get another fan?
Take what is left of the fan blade including the broken off ears and take it to any large appliance parts house. They usually carry a large selection of blades by hub size, blade diameter, and pitch, and directional orientation. You should be able to get a close if not exact match. My parts house has never failed me in this area.
Oct 30, 2009 | Coleman Electric Cooler 40 Beverage Cooler
The fun does not move the air
Hello acaprotta96,
If you are concerned about the angle of the fan blades not positioned to move air, you can add washers to change that angle but you will need to do that to all the blades. The blades should be balanced to eliminate wobble. If I were you though, I would contact the manufacturer and state your problem and see if they offer replacement blade supports with a more aggressive angle. As for breaking the motor... highly unlikely. especially if you are installing an even distribution of washers to balance things..
Regards,
Rick
Nov 24, 2008 | Hampton Bay 24002 Ceiling Fan
Need to purchase new fan (blades only)
Part number for the fan blade is CRCFD5303-010
Aug 01, 2008 | Maytag M7DH65B2A Dehumidifier
Lakewood 798240 Utility Heater Logo
50 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
