Question about Sony KP-57WS500 57" Rear Projection Television
Sony -kp65wv600 Hello, We have blue lines concave shape noted on our screen, sony 65 inch, faint and never disappear. pls. help single mom only
    Problem Solver:
  • 5 Answers
I got this TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Posted on Jan 15, 2008
    President:
  • 4,402 Answers
Bad convergence ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 11, 2008
Sony KP-65XBR
This is the sony support page. Try this out. Click here
Jan 12, 2008 | Sony KP-65XBR10W 65" Rear Projection...
T.V. comes on show blue then goes out after 3 second and only hear sound
When it comes on with a blue screen is it rather bright and or has curved faint trace lines in the picture?
Dec 12, 2012 | Sony KP-65WV600 65" Rear Projection...
Thin blue lines across the screen.6or 8 of them 3 or 4 inches apart. everything else works great still perfect picture
You need to turn down the Blue Screen Drive control a notch, Blue tube has built up higher then R/G over Driving.
Sep 27, 2010 | Sony Grand WEGA KDP-65WS550 65" Rear...
My moms cleaning lady ruined the screen with
Hello, I found a website for Sony Parts. The screen is available for 247.00. Thank you for your help. Carolyn.
Nov 29, 2009 | Sony KP-51HW40 51" Rear Projection...
Horizontal blue lines with a slight blue wash in the screen
Its because of Over Voltage of Screen (G2) to Blue CRT.
Take off front lower cover (speaker grill) and unscrew board. There you will need to find Focus Block mounted having 6 control knobs. 3 knobs are for Focus control and 3 are for Screen volts control. Find Blue Screen control knob and turn is Counter Click Wise slightly until bluish shade disappear on screen including few blue horizontal lines.
If you select AV input to adjust that will be fine as you do not need to wait for dark-scene.
Apr 09, 2009 | Sony KP-65WS500 65" Rear Projection...
Red and blue colors go across the screen. picture looks concave.
Greetings joanne7,
The issue you are having could be caused by your television needing the convergence adjusted. During production your televison has the three picture tubes that are converged to form a single image on the screen. Over time these can come out of adjustment.
If you go to this link http://download.jazel.net/misc/filecache/b8/b89bca4c8b740315d378e8ed030461c5_1227-517SeriesOwnersGuide.pdf and check pages 57 and 58, it gives you a very detailed guide on adjusting your convergence. I am aware this model number is slightly different than yours, but I own a 47" Mitsubishi and this is the exact procedure we use to do our convergence so I am confident it is fairly universal.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 25, 2008 | Mitsubishi WS-65907 65" Rear Projection...
Sony 65 inch kp65wv600 images look bowed
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jun 21, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
KDP-65WS550
· Sony Picture tube recall
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
or try this
Sony Too green,red or blue
Feb 06, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Sony KP-57WS500 57" Rear Projection Television Logo
626 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
