Question about AudioBahn DUB Mag Audio DUB2502 Car Audio Amplifier
HOW TO INSTALL THESE SPEAKERS..
Sirs:
We ate trying to install these speakers,and we just need to know how is thencombination of the wires,you they are double coil....
,,,Thanks
Victor
  • paul tortorello May 11, 2010
    does ur amp have 4 channels
  • 4 Answers
Connect all of them in parallel : positive with positive and negative with negative.
Posted on Mar 13, 2008
Trying to install stereo in 01 impala. I need to know the stereo wiring diagram. I keep reading that the yellow is 12v constant but have no yellow wire. Any help? Factory harness was cut out -______-
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: White
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Oct 31, 2016 | Cars & Trucks
How do i install a after market radio
the after market might of had the wires crossed for the speakers.. try switching the wire speakers around to make contact one at a time. If you still cant get sound from one after doing that, you might have to bypass with an amp
Nov 24, 2012 | 2005 Chrysler Pacifica
My radio in my truck has soped working and I need to install a new radio. However I do not know which wires go to what speakers etc. Can you help me identify which color wires represent the speakers they...
I always would go to bestbuy or walmart to get a harness adapter kit and the radio bezel installation kit to install an aftermarket radio. Just plug it in, and the wires are all labeled for speakers, antenna, power, etc.
Nov 10, 2010 | 1996 Chevrolet Cavalier
I need to find out how to mount stereo MA-10D speakers to a wall. I can't see any mounting capabilities on the back, sides, top, or bottom of the speakers. Has anyone successfully mounted speakers like...
Hmmm. .U don't have option given for speakers to fix them onto the wall. You have to do the following steps.
Things U need are:
  • Masking Tape
  • Level
  • Pencil
  • Keyhole saw
  • UL Class 2 speaker wire
  • Fish tape
  1. Locate the studs closest to where you'd like to install your speaker. You'll want to install the speakers in between the studs.
  2. Tape the template that comes with the speakers in the center. Check to make sure your configuration is level and plumb. Your template will tell you exactly what size hole to drill to insert the speakers. Trace the opening you need to cut into the wall or ceiling
  3. Cut the hole using a keyhole saw or a drywall saw. Keep the section you cut open in case you can't install the speaker and need to patch the hole you just made. If the hole reveals plumbing, you need to relocate the speaker
  4. Run the speaker wire through the wall, or fish speaker wire from an existing installation.
  5. Install the brackets to support your speaker if one is included with your speakers. Some speakers use clips to secure them to the inside of the wall.
  6. Strip the protective coating from the end of the speaker wire, and insert it into the speaker jacks. Test your speakers now if the wires are attached to an audio source. If not, locate the other end of the speaker wire and hook it up. Testing now will save trouble if you run into problems.
  7. Surround the speaker with insulation to enhance the sound. Secure the speaker into place, and do any necessary patching or painting
Aug 27, 2010 | Roland MA-10D Main / Stereo Speaker
I am trying to install a after market cd player and i need to know what all the wires from the car radio go to. thank you
1998 Hyundai Elantra Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Light Green
Car Radio Ignition Switched 12V+ Wire: Brown
Car Stereo Illumination Wire: Dark Green/White
Car Stereo Dimmer Wire: Dark Green/Black
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 5 1/4′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Green/Red
Left Front Speaker Wire (-): Light Green/White
Right Front Speaker Wire (+): Red/Blue
Right Front Speaker Wire (-): Light Green/Black
Rear Speakers Size: 6′ x 9′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Yellow/White
Left Rear Speaker Wire (-): Yellow/Blue
Right Rear Speaker Wire (+): Green
Right Rear Speaker Wire (-): Green/Blue
Please rate my help.
Dec 25, 2009 | 1998 Hyundai Elantra
I ha dsome one install new radio in my truck and
I am sorry to have to say this, but what you need is to find someone who knows what they are doing to fix the wiring that the original installers messed up. There could be crossed wires, bad grounds, poor connections, etc. Under the worst case scenario, this could cause a fire.
Jul 24, 2009 | 1996 Chevrolet Blazer
My front speakers and tweeters are blown
I work at a Chrysler Jeep dealer and sell parts, and I'm sorry to tell you but this is a little problem we have run into many times with these vehicles. The factory speakers are **** and of course we have no wiring diagrams showing how to install aftermarket speakers without replacing the head unit with an aftermarket one. I just had to do this with my Mitsubishi Galant when I bought some Focal component speakers for my doors. I went with the Alpine radio and it seems very nice and I think it will do great for your speakers also. Hope this helped.
Jan 13, 2009 | 2002 Jeep Liberty
Burned amplfier ic
A very simple solution to that , if you have no service manual of your gadget,,try google and search for your model or specify the part ,,eg.. ic , (how mny pins ?) , google could even give you the pin configurations. I already tried this ,,,,, dont hesitate,,nothing will be nil anyway....Second option, try to visit RadioShacks in your area and bring your speakers for better check up or they could give you another substitute part.....good luck...
Apr 04, 2008 | Altec Lansing ACS 52 Computer Speakers
Rear deck speaker install
I'm assuming that you have left the original wiring intact? If this is the case then it's a pretty simple thing to do. There should only be 2 cables one for each speaker & each cable will have a positive & negative polarity. Once you have securely fixed the speakers into place (usually screwing into place through the mounting holes provided) you just need to attach the wires to the speakers. If your car has manufacturers plugs on & don't match the speaker ones (quite often the case now) simply cut them off & replace with spade connectors of the right type/size. The most important thing is to get the polarity the same way round for both speakers!If you get them reversed you will NOT get any bass. Also remember with any new speakers they need time to run in & sound their best....so take it easy with the volume control for the first 20hrs or so of play if you want them to sound great & last longer!
Dec 27, 2007 | Pioneer TS-A6962R Car Speaker
Car Audio & Video Logo
41 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Jerry Naidoo
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
