Question about Panasonic KX TC1731 Cordless Phone
Answering machine replay is garbled
This is a 7 year old set that seems to be working well in all aspects. However, replayed messages from the answering machine are muffled. It is very difficult to make out what the called said. What is the fix? The handset battery has never been changed and indicator shows full charge. I am not sure if the handset battery impacts the answering machine at all. Any help will be appreciated.
    Novelist:
  • 106 Answers
Your handset battery will have no effect on the answering machine audio, providing your regular audio is fine (its fine when you make a phone call right?), I will assume yes. I have seen this problem in these models, and your problem lies in your base station, and the only fix you can attempt is to go into base programming and delete as much as you can out of the memory, greetings, old messages, etc.. Power down, then power back up again. Call in and leave a message. See if it sounds better through the handset or the speaker on the base when you play it back. If its garbled both ways (reviewing through the handset or on the speaker base) , then your problem is in your base memory. If it is just garbled on your handset, then it may be a radio module problem with the base, either way it probably needs to go in for repair. I don't know if Panasonic still repairs that model, but if you google Panasonic cordless telephone repair, you will find someone. Good Luck, CG
Posted on Feb 14, 2008
6ya staff
SOURCE:
Need to change message on Vtech L#cs6329-2 but cannot figure out how to do this
Step 1:
Press MENU/SELECT when the handset is not in use
Step 2:
Press VOL/ or VOL/CID to select >ANSWERING SYS then press MENU/SELECT.
Step 3:
Press MENU/SELECT to select >ANNOUNCEMENT & press 7 to record. Record your message after the tone & then press 5 after you have finished recording your new message.
Step 4:
The answering system automatically plays back the newly recorded announcement. Press 5 to stop the playback at any time; 2 to replay the recorded announcement; or 7 to record again if desired.
Step 5:
Online user manual
Jan 23, 2013 | Lands Phones
Answering machine does not give date and time dect 6.0
Since you declined to specify the model of your Uniden DECT 6.0 system, I can only direct you to select it from the list beginning here to download the manual.
Feb 04, 2012 | Uniden DECT 6.0 Cordless Phone ID
How do I retrieve my calls from another phone
call the phone (trial test run use a cell) leave a message and call back, wait for the message to start now press * if you already set your code enter it to retrieve the msg, otherwise the default code is usually 1234 or 0000 (for you security change it)
you will have to check you manual for other commands 7 is usually delete (replay, skip and save varies)
Aug 20, 2010 | Vtech 5.8GHz Cordless Phone with Digital...
Can not replay message
If you are at the machine and know which box the message is in, press and hold the button for the mailbox. The machine will then play old messages.
Here is a link to the 1726's userguide:
http://telephones.att.com/docMgt/public/art/285/1726_manual.pdf
May 26, 2009 | AT&T 1726 Digital Answering Machine
Ttds card and action replay
You can't put an action replay with a TTDS in the same slot. The action replay cannot read all of the games the TTDS has.
May 02, 2009 | Pokemon Video Game Consoles & Games
Answering system question
I believe the procedure is supposed to be this:
Dial the phone and wait for the outgoing message.
During the message, enter your three digit security code. If you haven't changed it, the factory default code is 123. That should put you in charge of the answering machine functions through the keypad of the phone you are calling in from.
You may need to write up a "cheat sheet" to remember what buttons do what answering machine functions. I think the controls should work the same as the labeled functions on the handsets that came with the 28112EE2 phone system. That is, 1 replays the message, 2 is the play/stop button, 3 skips ahead, etc.
Jan 11, 2008 | GE 28112EE2 Cordless Phone
Erasing messages
Hi. I think you have to wait until more calls come in. If you did not save original message(s), then these will then go away FOREVER.
Aug 15, 2007 | Southwestern Bell FA-970 Digital Answering...
Panasonic KX TC1731 Cordless Phone Logo
703 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
