Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Samsung projection Tv
Can youtell me where can i get this IC STK392.010 and for how much
thanks
Green
    President:
  • 4,402 Answers
Http://www.mcmelectronics.com http://www.bdent.com
http://www.electronix.com
Posted on Jan 11, 2008
6ya staff
SOURCE:
Color has changed to green tint
    According to the system the problem in your projection is convergence and the solution is to replace the IC STK's.The part Number is CZ01341. Change the IC STK both and your TV work fine again.And for parts please see the link below.
http://jr.partsearch.com/Model/Hitachi+Ltd/Hitachi/43FDX01B.aspx?SearchTerm=True
   Thanks.
Jan 09, 2010 | Hitachi 43FDX01B TV
Green color projection is lifting from the bottom left corner of the screen. Convergence adjustment for the green projection is unresponsive
Howdy,
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The cost for this repair runs around $450.00 or more.
Replace the defective Convergence Output IC Part Number (STK392-110. When Convergence Output failure is
detected, it’s recommended that both IC’s be changed.
Thanks for choosing FixYA, Big Irish.
Dec 22, 2009 | Panasonic PT-51HX41 51" Rear Projection...
My samsung rear projection tv has a problem with its convergence ic. i think theres two ics , but how do i tell which ic need replacing??
Always replace both once your going to the trouble each IC is usually less than $30.
This link will help show you what's involved.
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 13, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
The green and magenta convergence on my tv is off. The picture is also...concave(?) I've tried unplugging the tv for 10 minutes and the solved nothing. What else can I do?
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
Nov 08, 2009 | Samsung HCM4216W 42" Rear Projection...
RCA P52731WK REAR PROJECTION NO RED ON SCREEN
The RCA model is a 3 CRT projection TV. Most probably you need a new RED CRT, or there is a problem with the R(ed) channel (the picture is made up of 3 component colors: Red, Green and Blue). No way of telling without testing of the projector. Sorry!
Jul 11, 2009 | RCA P52926 52" Rear Projection Television
Samsung sp42w4hb rear projector tv
Dave,,yes the tv is worth fixing the ic part you need is STK 392-010 and at this site i will give the link to they are 19.99 each you will need 2 if you get them at the link I posted you will also get free online tech support plus installation instructions with pictures
http://servicemanuals.vstore.ca/
Apr 09, 2008 | Televison & Video
JVC I'Art Pro, Color Fade
sounds like two separate problems. color fade ?
green gun/band = bad convergence ic
Dec 18, 2007 | JVC AV-56WP30 56" Rear Projection...
Colour alignment off
Need to replace the convergence IC in the green vertical circuit. Check the 3.9 ohm resistors located in front of the IC.
Nov 02, 2007 | Samsung HCN436W 43" Rear Projection...
RED Ghost Image on Samsung 42" Rear projection HDTV (Model - HCN4226W)
I WOULD RATHER THINK IT IS ONE OF THE CINVERGENCE AMPLIFIER & DRIVER IC,S A REAR PROJECTION TV NORMALY HAS 2 OF THEM AND THEY ARE THE SAME AND NORMALLY THE NUMBER ON THE IC STARTS WITH "STR *****" SWAPING THE TWO AROUND WOULD PROVE THAT YOU GOT A PROBLEM ON ONE OF THEM,THEN JUST GET 2 NEW IC'C THE SYMPTOM THAT YOU ARE DESCRYBING IS MOST LIKELY THE IC'S HOPE THIS HELPS IGNATIUS ,SOUTH AFRICA TV REPAIR ENGINEER
Feb 20, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
26 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
