Question about Maytag Legacy Series Top Load Washer
Maytag legacy series washer leaking
Washer is 4 1/2 years old--leaking onto the transmission from above--I aaume it is the seals. Parts store said about $66 for triple leaf seals and figure about 5 to 6 hours. Does this sound right and is it worth it. It is a stainless steel tub
    Scholar:
  • 196 Answers
Price is right. Repair time is right for an inexperienced repairman. Worth it ? If you watch what you are doing and not rush then, yes, it's worth it.
Posted on Jan 13, 2008
Transmission problem
washers do not have a transmission. Please repost with new symptoms
Mar 18, 2010 | Maytag Legacy Series Top Load Washer
Loud noise, leaking and spinning so hard the agitator spins off-bought in 2007. I have been told that it is a "bad" bearing and seal. AND that it would cost more to repair that if I bought a new washer. ...
Sanfor,
If in fact the seals and bearing have gone bad the repairs can be expensive indeed.
Maytag does have a program that gives you warranty for 5 years on the transmission itself and such repairs can be counted as such.
I would check with Maytag to see what kind of reimbursment they can give you (www.maytag.com)
Aug 18, 2009 | Maytag Legacy Series Top Load Washer
Oil leak from bottom of maytag neptune tl - about 4 years old
sounds like seal leak in tub water is leaking onto drive unit and washing over it bring and oil it can with it couls be big bucks some parts may be under warranty call service but be sure to get estimate first
Nov 27, 2008 | Maytag Neptune FAV6800AW Top Load Washer
The grinding (bearing) noise on "spin", now leaking rusty water under machine... 3 1/2 years old "Legacy" ??? NOT !
maytag has rear rollers and front drum glides when goes out sound like sand paper scratching, also inspect belt idler same noise
Aug 14, 2008 | Maytag Legacy Series Top Load Washer
Legacy leaked on floor and subsequently ruined gararge ceiling. I put a wash in yesterday, filled it shut it off and left it soaking. I returned home from my errands three hours later to an 3/4 empty SS...
Its most likely the tub seal at the bottom, check and see if the area inside is wet in the middle. You will need to remove the outer panels to do this. It doesn't sound like anything else if the water was left to sit so a replacement of the seals around the center shaft should fix this problem. Let me know if you have any questions about doing this and I would be happy to help.
Jun 04, 2008 | Maytag Legacy Series Top Load Washer
Maytag Legacy top load washer is SMOKING!
this is a bogus website that is trying to push smelly washer product....no real fixes and there are other products out there for less just use bleach first
May 05, 2008 | Maytag Legacy Series Top Load Washer
Water leak
If the main seal is leaking there will typically be a splash line around the inside of your washer cabinet. There is a special wrench available for removing the large nut that holds the inner basket in. This nut is aluminum and can be removed with a chissel if it is stuck. remove the inner basket and you will see cone shaped "NUT" that is covered in cork. There is a torx screw on the side of the cone shaped piece. once the screw is removed then the cone shaped nut can be removed using the special wrench and brute force.
Mar 10, 2007 | Maytag Legacy Series Top Load Washer
Noisy spin cycle
Hey ****, what you are hearing is the spin bearing. Maytag redesigned the bearing kit on this washer, there must of been a lot of leaks causing the bearing to go bad. They put out a service flash...TDL-0060-B. New seal and bearing kit, part number12002470. You may want to contact Maytag on this for it could be covered. I know you have 5 years warranty on the transmission and If they change that, they have to use a new seal and bearing. Catriver...post back.
Oct 06, 2006 | Maytag SAV5710 Top Load Washer
Washing Machines Logo
183 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
