Question about Whirlpool AWM5125/1 Front Load Washer
It is only washing cold never gets hot
I have a AWM 5125 A It seems to work fine but the water does not get hot. The hot water is connected and is comming through it appears to be going in to the machine but the clothes are always cold when thet come ourt.
Email RRonKirby@aol.com
    President:
  • 1,314 Answers
All washers rinse in cold only
Posted on Jan 11, 2008
Electrolux EWF1074 washer doesn't seem to be taking the water in as normal. We only have it connected for a cold wash. Could this be a solenoid problem
indicates that it is so
prove it by changing over the hose with the hot water hose and using the hot water solenoid which will activate the hot water solenoid that is now connected to the cold water tap
if that works get a new water control solenoid and replace the cold water solenoid
Jul 13, 2017 | Electrolux Washing Machines
I've had my machine for at 7 years now, does it have to have both the water hoses connected, my seems to need both, and I hate using hot water for washing, is there any way to stop the need for the hot...
Some washers require that both water sources are connected. If you are content with cold - water washing only, I would get a Y-hose connector and run both sides of the washer to the cold water line. See picture below for details.
Mar 03, 2015 | Washing Machines
Hi. I've just been loaned a Whirlpool awm 5125/4 washing machine (while mines gone for repair), but it has on the back of the machine, a hot inlet and a cold inlet. My machine only requires a cold water...
Your machine can be connected for cold fill only but, you will need to connect a "Y-Piece" for it to work:
The tail of the "Y" attaches to the cold water valve on your pipework. You then attach both hot and cold water hoses to the branches of the "Y" and connect both hot and cold water hoses to your washing machine. The wash cycles will take longer when connected this way as the machine has to heat the water internally. It will also be less energy effecient.
Please post back if you need further assistance.
Regards,
BElectric
Dec 11, 2010 | Whirlpool AWM5125/1 Front Load Washer
My whirlpool awm 5125 wont fill up at start of washing
if it has just been installed check that the water tap has been turned on and the hoses have not been bent or twisted if these are ok you may have to replace the solinde valve in you machine
Sep 22, 2009 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool washing machine...only uses hot water
Make sure the hoses are connected correctly to the water valve on the machine. The connections will be marked with an "H" and a "C".
Given they are correct, most current washing machines have and auto temp feature on the water fill. It allows even cold water settings to bring in some hot water to make sure the water temp is hot enough to efficiently disolve your laundry detergant. The preset temps are usually around 75* for cold, and 105* for warm. Hot water comes in at whatever temp your household water temp is.
Sep 12, 2009 | Washing Machines
Washing maching won't rinse in cold water
hi is this hot and cold water piped machine? ie two connections on rear of machine for hot and cold pipes ? if so are your pipes connected properly on machine and the water supplies? if cold supply is connected to hot supply then wash inlet allows water in washer then washes in cold? but when rinse is due? the elec valve that has hot water pipe connected?? is failing to open allowing water flow of hot on rinse so advise recheck pipes for flow of water from both? when disconnected from machine if flow ok then possible valve blocked/faulty hope you can understand above? if you can give more info on your machine it would help to offer a remedy?
Nov 01, 2008 | Hotpoint Washing Machines
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Whirlpool AWM 6100 wont let in water?
this may sound silly but is the hot and cold hoses around the right way
Feb 18, 2008 | Washing Machines
Whirlpool washer problem
it sounds like you cold inlet need replaced its a easy job
Jan 10, 2008 | Whirlpool AWM6100 Front Load Washer
Whirlpool AWM5125/1 Front Load Washer Logo
121 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
