Question about Refrigerators
Kenmore side by side (2003)
Wife says that the front dividing panel is getting hot to the touch. this is the panel where the doors close on the front, dividing freezer from frig from top to bottom. it seems that everything is still working but worried about it quiting in the middle of the night. please help?? RCarter5297@aol.com
  • 447 Answers
Dont mean to butt in here but your refrig probably has a ECM (electronic contolled motor) which means it has a tiny computer inside it....these motors are plastic and have a plastic blade. these are a little more energy efficient and it helps the manuf get bettter energy star ratings...however...they do from time to time decide not to start every time that the unit comes on...this cause excessive heat and freon pressure to be exerted on the compressor and its electricals... The replacement motor is just the old style shade pole (magnets) motor...not quite as quiet or efficient but wayyyy more reliable. Order a replacement blade seperately from the blade/motor kit since the blade in the kit is always destroyed by the motor inside the box.
Posted on Jan 20, 2008
    President:
  • 1,314 Answers
Don't worry vinny that's called a post loop part of the condenser coils run up through there and they keep it dry so your door gaskets don't get wet and moldy no problem dont forget my 4 boxes please thats a fixya
Posted on Jan 11, 2008
I have a side by side and the divider between the doors is hot to touch what would cause that?
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Jul 24, 2011 | Kenmore Side by Side Refrigerator
I have a KSSC48QMSO1, The center panel, that divides the freezer from the refrigerator is hot to the touch at the top end and only where the side doors close together. Also the refrigerator is not holding...
could be a problem with a dirty condenser or your condenser fan may be no good. That will cause the center panel to be hot and will prevent the refrigerator from cooling properly. Is the sides of the fridge hot to the touch as well?
Mar 18, 2011 | KitchenAid KSSC48QMS Side by Side...
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
The divider between the freezer and refrig is very hot to touch.
Normal for that strip to be warm since the cooling system is routed right behind it for heat transfer and to eliminate condensation. Will be warmer with increase in room temp, but if it is a significant change you should inspect/clean the coils behind the panel in the rear of the unit.
Jun 24, 2009 | Kenmore 57029 Side by Side Refrigerator
Freezer and refrigerator are not cold enough.
you problem check and see if your fan condeser working best call service
Mar 22, 2009 | Kenmore 53092 / 53094 Side by Side...
Kenmore elite side by side: hot divider
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
Feb 23, 2009 | Kenmore Refrigerators
The door seal contact surface is hot to the touch.
ther so pose to be a switc if none that for hummit
Jan 17, 2009 | Kenmore 53082 / 53084 Side by Side...
The middle divider heats up
Yes it is normal. Old side by sides had an electric heater through that strip known as the mullion that you could turn off with the "energy saver" switch. Not any more... it is now that last pass of the condenser that runs around the door to prevent moisture build up. The more load on the sealed system, the hotter the mullion. If it gets almost too hot to touch, clean the condenser coils as they are probably getting plugged with lint and can't evacuate heat anymore... cooling will suffer too if that's the case not to mention higher energy consumption.
Dec 18, 2008 | Kenmore Refrigerators
My frigerator
This will get warm. If very hot check and clean coils in front, underneath. Also check fan behind rear panel. It should be turning when the unit is running. Also check for door not closing properly.
Nov 12, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
393 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
