Question about Funai FDRV90E DVD Recorder/VCR
Funai drvr-b778 dvd record problems
When i try to record onto dvd it says"recording error cannot record on this disc E15 2A043E02 i have tryed differant dvd discs but get same massage can any one heip
  • 1 more comment
  • 6ft koala Feb 01, 2008
    I have the same problem. The DVD used to work but recently every time i put a recordable dvd into the machine i recieve message, "Recording Error, cannot record on disc". Also i can no longer record onto the vcr using the long play mode as i cannot watch it back for the picture is jumping everywhwere.
  • 2muchtech Mar 05, 2008
    I have the exact same problem.
    Our DVD/R/RW is a Symphonic but the Recording Error.
    Can Not Record On This Disc.
    E15 2A043E02
    Is the same message and Number as this other person.
    Does someone have any idea why 9 out of 10 attempts to record fail!
    Thank You in advance:
  • cats-tv Nov 12, 2008
    Same problem with my Combo Symphonic DVS/VHS Dubbing Machine.
    Error e15 2A043E02 Cannot Record.
    It is very Frustrating. I had it cleaned by a professional electrician who took it apart, not just a cleaning disk. I would not recommend this brand.
    Problem Solver:
  • 9 Answers
Try mr dvd-r discs from poundland they seem to work
Posted on Feb 07, 2010
Funai VCR/DVD recorder DVR 2737. My -R discs record ok but during finalising I get disc error - cannot record on this disc Error code E22. Can you help?
I was advised to try another make of blank discs. I bought Sony discs & they worked ok. I had been using supermarket own brand.
Oct 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Cannot record on 16X DVD-R
You will need to call Funai 1 800 605 8457 give them your brand / model number and expose your problem - they should be able to send you an upgrade disc but it will cost you -
If you want my advice - you DO NOT need a 16x disc inside a DVD recorder - the optical drives used on DVD recorders and even worse a Funai drive are quite bad as it is in terms of writing strats for higher speeds - you are better off recording at 8x on a 16x disc.this will provide better burns ( lower PIE/PIF errors and jitter %).
Aug 25, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Will not record all I get is Error 3-51
I had a similar problem, it turned out the first time I tried it I didn't have a DVD in the tray! Then I found I was using a DVD+R blank DVD and this machine needs DVD-R DVD's. It certainly solved my problem using the right blank disc
Jul 13, 2009 | Funai PY90DG DVD Recorder
Funai DR-B2737 DVD recorder wont record
use mr dvd discs-dvdr youcan buy at poundland they are the only discs that seem to work
Mar 25, 2009 | Sony Ericsson w580i Cellular Phone
FUNAI drvr b778s
Have you finalised your disc in your dvd? I was having problems with my pc reading discs until I did this ,although some pcs wont take dvd-r discs and will only accept dvd-+r so it could be that.
Jun 18, 2008 | Funai PY90DG DVD Recorder
Recorded DVD wont play on any other DVD Player
I lost my manual. Can you describe how to finalize it? I can't finad any buttons to press that say finalize on them.
Jun 01, 2008 | Funai TruTech DVDVCR Dual Recorder
Funai DRV-B2737 Error message
I'd had this problem with my 2737 for quite some time but haven't had the time to fix this until now.
Just for the record it has one laser unit inside which fires off two frequencies one for read the other for write. Anyway, I've been repairing Playstation 1 and 2 and Xbox for years and the most common problem seem to be disc read errors caused by seemingly failing lasers or scratched/damaged discs.
The manufacturer sets these lasers at safe usable limits but after some use they start malfunctioning.
I wanted to copy a VHS recorded disc to my PC tonight only to find I hadn't finalised it in my Funai.
Realising I couldn't because of the silly E4 54037380 error I finally took the plunge and dismantled the unit.
NOTE: the following is not for the faint hearted and please use an antistatic wrist strap to earth yourself.
The Disc tray mechanism has to be removed and a small circuit board directly to the right has too be released. There are a plethora of ribbon cables but only one needs disconnection. Carefully turn the disc drive mechanism on it's back and un clip the thick ribbon cable that attaches to the laser. Tuck the cable out of the way being careful not to damage it. Move the lens unit to the top of the tray mechanism and note there are two potetiometers Using a pot tool or fine flat bladed screwdriver adjust the lower pot by an eigth of a turn (this increases the frequency of the recording laser enough to eliminate the E4 54037380 error completely or it did in my case).Problem solved fully working recorder.
Dismantling procedure
Disconnect Funai from mains and remove the top casing (5 screws)
There are 4 screws holding disc drive mechanism in front right most tricky (use grabber tool to retrieve screw)
Top right has an earth cable connected to it
The other end of the earth cable is held in by another screw on the circuit board next to the drive mechanism this also needs removing
The screw directly below this with the metal earth case strip remove.
The board is held on by two small plastic lugs which need compressing so the board can pop up.
Remove drive mechanism carefully along with the circuit board and flip the whole lot over. Be mindful of the ribbon cables as they are fragile
Feb 06, 2008 | Funai PY90VG DVD Player/VCR
Emerson EWR10D4 DVD Recorder
try mr dvd-r discs from poundland.
They work with the funai machine.
Its worth a try.
Dec 24, 2007 | Emerson EWR10D4 DVD Recorder
Funai FDRV90E DVD Recorder/VCR Logo
595 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
