Question about Maytag Neptune MDE5500AY Electric Dryer
Open Dryer to replace belt
I need to open my Maytag electric dryer to change the belt
  • 589 Answers
Here's a pretty good tutorial on disassembly. Just scroll down to the Maytag section:
http://fixitnow.com/2003/11/appliance-tip-of-day-dryer-disassembly.htm
Posted on Jan 11, 2008
  • 314 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Also remove the screws from the lint filter.
Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Please do not forget to rate me
Thank you
Source: how to open up dryer to change belt
Posted on Jan 10, 2013
3 Suggested Answers
  • 523 Answers
SOURCE: I hae a Maytag Performa Model PDET910AYW electric
lift the top you will need a putty knife in the front there are two clips one on each side push in and lift up once up there is a screw on each side remove and the front comes off
Posted on Apr 25, 2010
hunter19_46m
  • 7482 Answers
SOURCE: how to open up dryer to change belt
Good luck,
I hope this helps
Thank you
Posted on May 30, 2010
Testimonial: "Hunter Thanks for the help. It was fairly easy to change the belt, only problem was trying to figure out the route as the old belt broke and fell off. We seem to have done it correct.The dryer is works great.Thanks"
I have a maytag neptue dc dryer & I need to know how to replace the belt
open the cabinet:
http://www.partselect.com/dryer+maytag-atlantis-open-cabinet+repair.htm
route the belt:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
May 22, 2011 | Dryers
How to open up dryer to change belt
Good luck,
I hope this helps
Thank you
May 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Change belt
Here is how to open the dryer to change the belt on the link below.
http://www.ehow.com/how_4841992_change-maytag-dryer-belt.html
Apr 27, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Need to change belt on maytag dryer but dont know how to do it on this model . any help would be great
Get the Model number and order a Dryer Maint Kit from either of these sites.
http://www.repairclinic.com/
If you have the belt already then open the dryer door and there should be a couple screws in the opening where the door normally closes at the top. Remove those and then the door should be able to completely come off then you will have access to the belt area.
Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Nov 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag Performa dryer is blowing out cold air. How can I fix it myself?
remove frt cvr,then top then remove drum belt and drum, check for open heater element, defective thermal fuse,hi-limit switch, open neutral to element if it uses the neutral connection
Oct 18, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
How do i open the dryer to replace the belt?
use a putty knife slide it between the top and dorr panal
on each side you will feel a stop thats the "dog"
push it back with the putty knife
when both have been popped, the top will pop open
onecs inside you will see two 5/16 bolts holding the front on
2 things, remember how the tumbler sits on the back of the door, for reinstall
unplug before you open
once open it should be fairly easy
Oct 15, 2009 | Maytag PYE4558A Electric Dryer
How to open up Frigidaire GLE0332CAS2???
Try this link, the first one the maytag one has the actual instructions, all dryers a pretty similar you just have to route the belt according to the diagram!! Good luck,, ps a good rating would be nice! thanks
http://fixitnow.com/wp/2004/08/19/appliance-repair-revelation-how-does-that-dryer-belt-go-back-on/
May 07, 2009 | Frigidaire GLEQ332A Electric Dryer
Maytag dryer won't rotate after blower wheel replacement
The dryer belt may have broken or come off its pulleys. Pop open top of dryer or rear vent door to look inside to see if this is your problem. Let me know if I can help, Thanks Sea Breeze
Mar 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Dryer Repair
Easy fix.
Open the top cover by insrting a putty knife in the top right and left sides where the top meets the bottom cabinet.
Lay the top to the back.
Remove 2 screws on the right and left front inside corners of the cabinet.
Remove the door.
Replace the belt around the drum and motor pulley.
Re-assemble the dryer.
Mar 10, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
645 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
