Question about Cyber Acoustics CA-3000 Computer Speakers
Speaker has sound when powered .
I tried connecting my Speakers, n as soon as I plugged in the power cable, the speakers started humming. I checked, the power cable is of teh same Voltage as required for the speakers. On plugging in to the computer, it did not transmit the sound either someone pls help!!
  • 619 Answers
Hi , open the control panel /select to classic view,select add hardware to locate some drivers cyber acoustics speaker just follow the instruction to connect the speaker.
check also the device maneger the connection of the device.
Posted on Jan 12, 2008
Tv and speakers buzzing noise
If the hum is a low note continuous hum, its at 'mains' frequency. The power cables to the unit (or inside it) are getting too close to the cables that carry sound signals to the center speaker. The mains power naturally hums and if mains wires are near to audio kit wires they pick up this sound and play it through their system/speakers. Check the wires to and from it make sure the connections are good and firm. Seperate these wires by at least one inch from any power cables, use tape to hold them down and away from each other.
Dec 15, 2013 | Bang and Olufsen Audio Players & Recorders
Lights? No?
Check power cables.
Any sound at all (click, hum)? yes?
Check audio cables.
Any sound at all (click, hum)? No?
Check speaker cables.
Check speakers.
Is head unit sending audio?
Try connecting direct to speakers. Working? Amp has fault.
Not working? Head unit has fault or is wrongly wired to amp.
Sep 02, 2011 | Dual XAF-460 Car Audio Amplifier
Have an older (6 + Yrs) VX-10A model, that's worked fine up until now. I recently moved, hooked up the same stereo and surround sound speakers, which worked fine, but the subwoofer made a loud hum as...
Disconnect the input and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
Mar 03, 2011 | Velodyne VX-10 Subwoofer
I have an Onkyo TX SR 700 receiver, Bose Acoustic Mass 10 speakers, Panasonic Viera 52" flat screen with my computer connected to the receiver. The computer uses a high end sound card. The flat screen...
Hi, what causes hums from speaker is when there is no ground shield from either the power supply or from the cable you plugged into the socket from the power supply.
So you will need to check that out and replace untrusted cables for connection..
If after doing this troubleshooting exercise, you will now need to test the speaker with another set to be sure the humming sound is not coming from there.
I guess that will Do.
Have a nice day...
Feb 18, 2011 | Bose Acoustimass 10 Series IV Home...
There is no sound. I have connected it to my new Toshiba laptop
Hello there,
When you plugged it into your laptop, turned it on and increase the volume, do you hear only a humming sound from the speakers? Try to plug the speaker to an mp3 player as well to test if it still doesnt give out any sound. If it still doesnt, then your speaker must have a wiring connection problem inside that needs resoldering. Here I supposed that your laptop's internal speakers is working and is able to work with other audio devices like a headset or an earphone.
Dec 20, 2010 | Insignia 2.0 Speaker System (2-Piece)
No sound
Hello endow1, hi, try this test, unplug you Logitech audio in plug and touch the input, you should hear a humming sound, Adjust the volume settings to high to hear it. If you cannot hear the humming sound, then there are problems you need to check. Place you speakers near your ear and adjust the volume Up and Down, you may hear a soft hum that should go up and down. Absence of the hum means that the speaker has loose connection from amplifier to speaker driver, or loss of power, check to see if there is pilot light.
Aug 19, 2010 | Logitech X-140 Speaker
Wharfedale 10inch cude subwoofer that has a feedback hum when con
Hiya, try a different input cable (from amp to sub) if you have make sure that is ok.
Failing that if there is an earth in the plug, try to disconnect that (earth loop) - unlikely but hey electronics.... anything possible :)
If still there with new cable, earth off etc, then the Yamaha could have a problem but find that difficult to swallow...
Let me know if helps, see any other possibilty
Best of luck
Jul 14, 2009 | Wharfedale PowerCube PC-10 Subwoofer
Humminf sound from subwoofer
Most humming sounds in speakers is due to electrical currents or wifi signals nearby the speakers.
Do you have any electrical cables near the speakers? Do you have any wifi device near the speakers?
If so move them out/away and see if there is any difference.
Jun 02, 2009 | Creative Labs I-Trigue 2.1 3300 Computer...
Loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Dec 16, 2008 | KLH HTA-4906 System
Cyber Acoustics CA-3000 Computer Speakers Logo
215 people viewed this question
Top Cyber Acoustics Audio Players & Recorders Experts
mukhtar21 shaikh
mukhtar21 shaikh
Carlos L. Burgos
Carlos L. Burgos
Are you a Cyber Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
