Question about Casio Exilim EX-S2 Digital Camera
Memory card problem
Tried to install a 1gb integral sandisc memory card into my EX-S2 camera but message keeps saying "card is locked" despite the lock being in the off position. Any ideas?
thanks
doherty87@aol.com
  • Anonymous Jan 28, 2008
    My card says that it is locked and I cannot get it to delete the photos to take more photos please tell me how to work on this.
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
Card Locked Samsung SL 102 Camera
there is a lock button on the memory card check it if it is SD card or camera might not support the card try 1gb card
Sep 05, 2009 | Samsung SL102 Digital Camera
Exilim memory locked
its or child lock ,check manual or firmware damage ....software in the camera check how to fix in manual..
Aug 30, 2009 | Casio Exilim EX-S500 Digital Camera
A second SD card has now corrupted !
What brand cards are you using. I've had a Sandisc 2 ultra II in mine nor for about a year and never had a problem. before that had a 1gb Kingston and again no problems. after every download I always format the card to start it freash so i'm always using that same part of the card.
If you don't format often i'd do so. You don't need to do a low level every time, i do mine about every 10th downlaod
Sep 17, 2008 | Canon PowerShot S2 IS Digital Camera
2GB memory card but only 1GB available
That is one of the problems we have seen because it isn't a model that casio recommends using with the camera. Toshiba, Panasonic, and Sandisc are the only models that they have tested and know work so that's what they recommend you use.
Sep 09, 2008 | Casio Exilim Pro EX-P600 Digital Camera
"Card Error"
You MUST FIRST format ANY memory card that you plan on using with this camera. Otherwise we can't guarantee that they will work. Also, Casio has only tested 3 brands of memory cards and can say for sure that they will work with their cameras.....those brands are Toshiba, Panasonic and Sandisc. If it is neither of the above I would recommend getting a different card and making sure that you format it WITH THE CAMERA BEFORE USING. :)
Mar 08, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
MY MEMORY CARD IS LOCKED!!
Exactly. Sometimes if you use a card reader it will automatically lock the card when you install it. Keep that in mind.
Jan 04, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Card read error
Make sure it's a Sandisc, Toshiba, or Panasonic memory card. No bigger than 2 MB unless you have done a firmware upgrade. Try formatting memory card and if that doesn't work then you will have to get a different memory card.
Nov 27, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio ex-z60 cannot read memory card
Make sure that the SD card you are using is either a SanDisc, Toshiba, or Panasonic. Those are the only cards that have been tested with Casio cameras. Also make sure that you format the card WITH THE CAMERA before you try and use it the first time. If it still doesn't work I would try resetting the camera and then you should have no problem.
May 29, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Does not read memory card
Casio only tested 3 cards with the camera. Sandisc, Toshiba, Panasonic. First: Format the internal memory of camera and then reset camera. In rec mode press menu go to setup tab go up to format press right arrow highlight format press set. Follow same steps for resetting. Then insert mem card and format mem card. If that still doesn't work I would say there is something wrong with the camera itself and would need to be sent in.
Jan 24, 2007 | Casio Exilim EX-Z57 Digital Camera
Casio Exilim EX-S2 Digital Camera Logo
119 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
