Question about Whirlpool LCR5232H Top Load Washer
Whilrpool washing machine
My washing machine won't fill this is because the drain won't close, it just keeps draining, any ideas?
    President:
  • 1,314 Answers
Yes this is a common problem your drain hose is too far down in your drain pipe if its too far in the drain spout its like siphoning gas out of a car you only need about 4or 5 inches in the drain spout now if you don't have a drain spout or one that is unuasly low contack me for further info just pull it up quickly and you will hear the syphon suction break then you will know you got it
Posted on Jan 11, 2008
Smart Drive machine on starting, water runs straight through into drain, thus not filling up
Most likely the water coming into the washer through the Water Inlet Valve could be siphoned out to the drain pump and out the drain hose because of an issue with the pump or plumbing. Is your washer overfilling?Is the washer detecting an overheat error? Observe carefully as to what part of the washing cycle the water is draining out. By watching the washer as it goes through its wash cycle, you can find out which part or error is causing the Washing Machine To Not Fill With Water and Keep Draining issue.
Washing Machine Will Not Fill With Water Keeps Draining How To Fix
Dec 03, 2017 | Washing Machines
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
WASHER WON'T FILL WATER
Check to be sure the drain line is higher that the tub of the washer. You have a siphon going on the drain.
Nov 05, 2012 | Hotpoint Washing Machines
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Whirlpool Ultimate Care II keeps taking water.
ck your drain nose/drainline, chances are you have along hose, perhaps even draining along the floor behind hte unit, into a "closed" drain system. in which cawee the wwater is syphoning out during the rinse cycle, youlll needt o raise the drain hose to above 48" and have it drain into a stand pipe to prevent siphoning effect
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer won't fill
On the drain valve there must be some dirt that does not let the valve close or the valve must be defective and needs to be replaced. By the way you did not mention the make of the washer.
May 11, 2008 | Washing Machines
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
Frontloader washes and rinses on cold all cycles but whites
drain hose maybe going down the waste pipe too far 4 inchs is about right,check it out,most machines take in extra water on a cold wash!!!close eire
Jan 31, 2007 | Frigidaire GLTF1670A Front Load Washer
Whirlpool LCR5232H Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
