Question about Hitachi C43-F500 43" Rear Projection Television
Repair no output from powersupply
    President:
  • 4,402 Answers
Ptscorp.com
Posted on Jan 11, 2008
D-link router (with 1 antenna and no modem) that has no power and no LEDs lit. the outlet still works to charge a cellphone. how do we fix the router?
Possibly the powersupply for the router is dead. Find another powersupply with same voltage output to try OR test the output tip with a meter. If the power supply does work then your router is dead. Replace it. If there is no power (5 volts or 12 volts etc) coming from the tip of the power supply adaptor then replace the adaptor / power supply.
Apr 28, 2013 | Computers & Internet
Cp3525dn prints only blank pages new black
Page is blank.
The high-voltage powersupply lower is defective (no developing bias output).
Replace the high-voltage powersupply lower.
Jul 12, 2011 | HP CP3525N Color LaserJet Printer
Not getting switching on.
Make sure that all the power cables required are connected properly to the motherboard, test the powersupply on another motherboard for example or use a powersupply tester.
Check that the power switch is connected on the right pins on the motherboard and that the switch works.
The motherboard should turn on - spin fans even if there is no memory, cpu or video card installed. So something is not connected properly, or either the powersupply or the motherboard is faulty.
Sep 20, 2010 | Intel Motherboard
What power supply is required for the Bafo 700 7 port usb hub ?
Probably the one it came with?
Anyway, if there are details about voltage and amperage on the back of it you could buy an aftermarket switching powersupply.
The voltage output of the powersupply has to be within 5-10% of what the hub needs, but the amperage can be equal or higher. (anyone who disagrees with this is wrong)
May 26, 2010 | BafoTech BAFO (BF-700) Networking Hub
I have an old SPX90 Digial Reverb with a dead powersupply. The part number on the board is VA81400. Is this part number correct? Is the part still available? We tried ordering it from the Yahama dealer,...
Any power supply will do as long as it has the same specs as the dead one, which will be:
Input : x Volts AC
Output: x Volts AC or DC
Watts: x
Amps: in millamps
Polarity: (for power supply with DC output only) Center pin = plus or Center pin = minus
You should be able to find the matching transformer/adapter/power supply at Radio Shack.
More info, let me know.
Charlie
P.S. The power supply you received may be the correct one -- check to see if the specs match the old one.
Aug 29, 2009 | Audio Players & Recorders
Sony XM1002HX keeps blowing fuse
AUDIO OUTPUT TRANSISTOR OR IC IS SHORTED
Aug 24, 2009 | Sony Car Audio & Video
I have a Medion Titanium MD 8386 processor which is very temperamental about switching on.Sometimes it will swich on ok then on other time it will not Any ideas
hi
"Medion Titanium MD 8386" is the cpu cooler isn't it? it's the pc that fails to start is it?
Give a bit more info on the pc such as processor, ram and the most important one, the powersupply. Is the computer a branded one or a clone? whats the output of the powersupply(watts)
cheers
kbh
Oct 09, 2008 | Computers & Internet
Motorola R100 uhf repeater
You can replace it with a Astron Powersupply 25 amp Or try to repair the powersupply for the repeater. it is a easy board to repair.
You will need to "outboard" the Astron.
Bill
Jun 18, 2008 | Motorola Radio Communications
The laptop does not power on
I think we have a case of fried PowerSupply, test the voltage output witha multimeter, check the output printed on the brick. if that is OK then U have a Bad Motherboard.
you will need to replace it.
Jan 29, 2008 | Acer TravelMate 2413LMi Notebook
STANDBY
Load the 110 output and disconnect pin number five of STR, now full output will be showed, pin five is controlled from system control ic, trace this route.
Jan 11, 2008 | Televison & Video
Hitachi C43-F500 43" Rear Projection Television Logo
29 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
