Question about OKI C5200n Laser Printer
Fatal error 163
Get fatal error 161 163 codes when printing color prints
  • MBDC May 01, 2008
    Fatal Error:
    01F6D09C 01F6D038 01F63A1C
    Problem Solver:
  • 11 Answers
Fatal Error 161-Toner Sensor Error, Color:Magenta
When magenta toner sensor error has occurred
Fatal Error 163-Toner Sensor Error, Color:Black
Both are Sensor errors....You would first check the lock levers that hold the toner cartridges in, if everything is fine with them then you could possible have toner dust on the sensors. First take out the cartridge that you are having problems with, then use a dust off can and carefully clean out any axcess toner that you can see where the toner sits. there is a sensor that looks like a clear plastic or glass eye that reads the cartridges and it sometimes gets dirty.
Posted on Jan 11, 2008
Just had a 161 error on our 5300 and the magenta cartridge I had just replaced is faulty. There was a horrendous clicking sound on initializing and it turned out that the cogs on the new cartirdge were seized! .. Just another possible scenario - hope that helps!
Posted on Jun 20, 2008
I had the same problem, it was a sensor in the magenta cartridge. This printer is really good, nice color, glossy. I changed the toner cartridges for compatibles, http://www.imagetoner.com/okidata-c51005150520053005400-c-31_64.html good quality, no problems so far
Posted on Feb 07, 2008
  • 32 Answers
What is your printer name and model?
Regards,
Chester
  • Chester Gould
    Chester Gould Jan 11, 2008
    Sorry the model was on the top... had a brain hiccup :)
    Those error codes mean that the printer's ink is not correctly in its place... It is recommended to restart the printer, then try again.
    If that doesn't work I would try taking the ink out and putting it back in.
    Regards,
    -Chester
What is a Fatal Error: 140 on a Xante HSE?
That error is image yellow drum up/down senser. Shut down your printer and reseat the drum make sure it is loose and not tight when placing it into the unit.
Oct 02, 2014 | Xante CL30 HSE Laser Printer
Fatal error 1a39
Fatal error 1a39 - The description says:
"Service Call Error
Code: 1A39
Category: Hardware
Error Name: Head Error
Cause:
• Connection failure of the HEAD FFC.
• Electric parts or components are damaged due to improper HEAD FFC connection such as connecting it at an angle.
• The drive circuit in the PRINT HEAD is damaged.
• The fuse of the MAIN BOARD has blown.
Check Item:
Is the HEAD FFC connected properly without being connected at an angle and any abnormalities such as peeled terminals?
Remedy:
1. Replace the HEAD FFC. (See P.127)
2. Replace the PRINT HEAD. (See P.126)
3. Replace the MAIN BOARD. (See P.111)
As a point of reference, your three manuals are here (link below), which is where I found this info. (See the first manual listed - in the chart on page 53: Table 2-2). Good luck!
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=220056&prodoid=63096219
Aug 20, 2014 | Epson SureColor T-Series T3000 Inkjet...
Fatal Error code 10H
C 0010H - Color PC drum malfunction.Check the motor for proper drive coupling and correct as necessary.Check the motor connector and the electrical board connectors and the mechanical transport drive components(gears,couple).
Apr 05, 2013 | Konica Minolta Magicolor 2530 DL Laser...
Fatal error 142
Color ID up/down error
is detected.
1) Is an Error message displayed?
Confirm that the Y, M, and C ID
units are in position, and reboot
Mar 04, 2013 | Oki Printing Solutions C9650 Led Printer
OD ERROR
Fatal error code 0D: No head error
A check of the print head thermistor circuit during power-on initialization determined that the PRINT HEAD is not installed. This error is caused by the following:
? The Print Head is not installed.
? The Print Head built-in thermistor element has failed.
? The Carrier Cable is disconnected or damaged.
? The Print Head temperature detection circuit has failed
Jun 07, 2011 | Epson DFX-9000 Matrix Printer
073 fatal error in OKI c3530
Oki ERROR 073 is a H/W Overrun detect. this occurs when the video circuit has set the overrun bit. Restart the printer and check the first print out. Try printing a different job and then reprint the same job that the error occurred. If you get the same error again, try using a different driver, ie swap from PS or PCL whichever you were using to see if that clears the error.
Dec 28, 2009 | OKI C3530N Color MFP Printer
OKI C5500 Fatal Error 177
From OKI error log:
Lower heater temp state - Low
backup roller thermistor indicates low temp
seek service if turning off/on printer does not solve problem
Apr 15, 2008 | OKI C5500n Printer
OKI C5200n Laser Printer Logo
2,593 people viewed this question
Top OKI Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Dominion Computer...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
