Question about Haier HL32BG 32 in. LCD Television
Picture The people heads are cut off. I don't know how to adjust picture. Thanks
  • 61 Answers
I believe this unit on Zoom mode.In remote there is button called ARC press this button and see what will change to Zoom,widezoom,normal.
If it is not changing check your cable box
Posted on Oct 06, 2008
Porter Cable pancake rated at 150 PSI stops at 135 PSI. It has done this since it was new.
If it's pumping up to 135 psi, shutting off and then restarts at the same pressure point since it was new, the pressure switch may have been set low at the factory. I don't know which model you have but most pressure switches have directions inside their cover as to how to adjust the cut-out and cut-in pressures. Be careful doing this, overpressuring the tank is dangerous. There is an adjustment screw or bolt that changes the pressure on the switch spring. Some pressure switches have two screws, one for cut-in and one for cut-out pressure. A few have one that adjust both pressures. If you do adjust the cut-in/cut-out levels, do it slowly and cycle the motor a couple times between each adjustment to see where it turns off and on. If the compressor is doing what you want it to, only pumping to 135 psi, it will live longer than if you adjust it up to 150 psi. Those last 15 psi of air are hard to get and will mean the motor will be running longer and more heat will be building up in the head.
Oct 01, 2012 | Porter Cable Air Tools & Compressors
Pioneer plasma tv picture is cutting off heads
Issue may be adjustable in the Tech menu with your remote---you need to see if you can find the service manual (with schematics and information about getting into that menu and how to adjust).
Try to GOOGLE MODEL NUMBER WITH service manual or contact Pioneer.
Mar 21, 2012 | Pioneer Elite PRO-151FD 60 in. Plasma TV
Requesting the valve specifications and settings for both intake and exhaust on a Harley Davidson FLHS year 2000. engine 1340cc
I'm not sure what you mean by "specifications". If you are talking about angles ground on the valve and seat and their widths and such, I'll have to send you a picture but the machine shop doing the valve job on the heads should know this. If they don't, you need to find another machine shop that knows Harley-Davidson heads. As for a valve lash adjustment, there is not a setting. You have hydraulic tappets and fixed length pushrods, nothing is adjustable. The pushrods are all of different lengths and are color coded as to where they go.
Good Luck
Jul 15, 2011 | 2000 Harley Davidson FLHR-FLHRI Road king
Returning to "streched" picture as top of heads
Remote control is needed to change aspect ratio. The button on the remote is labeled format. Standard definition sources have six picture sizes and HD has two.
Bill W
Mar 13, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Picture too large for screen
Press "wide mode" on TV remote until it is on "full". Check for same on set-top box.
May 02, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
How to adjust pitcher size
Try this setting and see if it helps: Menu>Picture>Advance Picture Settings>Scan Velocity Modulation (Check mark it) Then the TV will try to auto adjust it's picture size to the source you are using. I noticed it most on ESPN News HD. If you are using a HD cable box, you might be able to use the cable box settings to change the picture size. Sometimes the box is on "Zoom" and it takes the top of heads off.
May 25, 2009 | RCA R52WH76 Television
If the television is connected to a cable box such as Time Warner's HD box, the picture mode can be changed by pressing the '#' on the cable box's remote keypad (where the channel numbers are). This cycles the picture between zoom, normal, and stretch which could be cause of your problem.
Aug 18, 2007 | Toshiba 50H13 50" Rear Projection...
Picture cut off
No adjustment needed on these LCD projection. Your problem is in your setup menu. Your default is now is set ZOOM. That is why the bottom of the picture is cutting off. Go to Menu, setup and screen size or something close to that.
Best regards
Jul 27, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Haier HL32BG 32 in. LCD Television Logo
122 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
