Question about HP Pavillion ZV6000 Athlon 64 3500+ 15.4in WideScreen w/ 512MB/80GB/DVDRW/Flash Slot (PCLHCA6435512WWD) PC Notebook
Hp pavillion ze4900
My friend has the above laptop.
When you turn it on the HP logo apears and it gives you the option to ESC F10 F12.
However if you leave the laptop to complete it shows a cursar in the top left and then it asks you to do the following.
Windows coul not start because the following file is missing or currupt: \windows\systems32\config\system
You can attempt to repair this file by starting windows setup using the original setup cd-rom.
Select R at the first screen to start repair.
  • networkmagic May 11, 2010
    Do you have the original setup disc available?
  • 37 Answers
Is this a raid? if so :You will need to boot from your CD. When windows starts loading, at the bottom of the screen it will ask you to press F6 to install RAID/SCSI drivers. Do that. You will need to have your RAID Drivers on a floppy disk for this to work. You can get the RAID drivers from your motherboards website and/or any CD's you may have received with your motherboard from what i can remember u need to push S to choose the a drive and raid driver u need then xp will be able to get to rec console
Posted on Jan 11, 2008
  • 32 Answers
Looks like Windows is corrupted... probably got infected...
First thing... is there any important information on your friends laptop saved... like files, folders... anything he/she does not want to lose?
If so, there are a couple of options... easiest thing is to download a Live Cd linux distribution like puppy linux or damn small linux and then copying the important files to a USB stick or something, but if you don't know Linux very well this may take you a long time.
Another option is to use the Windows cd and reinstall the system... typically you can reinstall into the same directory (overwriting the previous corrupted one) or a different directory like C:/Windows2 and booting into the new one instead. Both of these solutions will work, but will probably not solve the problem that corrupted Windows in the first place.
If you choose second option, I suggest once you boot into the fixed windows to copy any important information to a USB drive, then format your hard disk and reinstall windows from scratch.
If you need any more help let me know.
Regards,
Chester
6ya staff
SOURCE:
How do I get the f12 key to work. It is controlling the airplane mode
According to the manual F12 is used for turning the wireless on or off. This is not airplane mode.
The keys can be set on or off in the Bios and the manual gives the instructions to do so.
Here is the manual
http://h10032.www1.hp.com/ctg/Manual/c03750598
To start Setup Utility (BIOS), turn on or restart the computer, quickly press esc, and then press f10.
Feb 08, 2015 | HP F9L85UAABA HP Pavillion 17-e132nr...
How to change setting in bios to boot from cd drive"?"
you usually dont have to change the boot order to boot from a cd. the bios should check the cd rom before booting from the hdd. However, if that isnt the case, you can always change the boot order.
go to the bios settings while u turn your laptop on. (It should be "esc" for HP. a message will be displayed at the bottom of the screen indicating the key. if not, try esc, f10, f11, f12. either one of them should work).
go to the boot order settings (May have a different name- boot settings/ boot priority settings/ advance boot options etc.).
Jul 13, 2014 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
How to enter bios setup
when yo turn the pc on, while the compaq logo is displayed, you should see a msg at the bottom of the screen indicating which key will get you into the bios settings. It should be esc for HP. otherwise try f10, f12 ,f2, f8. It's got to be one of these
hold that key down while you turn the laptop on, before the operating system loads.
Jul 13, 2014 | HP Compaq Evo Notebook N1020v PC Notebook
Reboot disc
please calm down,
insert the disk, restart your PC, before Windows logo appears, keep pressing F12, then click on the option to boot from CD/DVD
Jan 17, 2013 | HP Pavilion Ze4900 Notebook
Ze4610 won't boot past HP logo
The hard drive has issues, the next step is to have it tested for possible replacement.
Jun 05, 2012 | HP Pavilion ze4610 Notebook
Screen says Hp Invent, does not show desktop. Choices are esc, F10 or F12. How do I get it back to my desktop screen
I am asuming this is when it is booting up?
Press F10 to go into bios
Reset default and try again.
Sep 09, 2010 | HP Pavilion dv1000 Notebook
HP Pavillion dv6000 will not load
HP pavillion will not load
if you are able to see the HP logo that tells you that bios is loading but when it gets to the operating system on your hard drive, it can not be located. One of the reasons can be a bad hard drive if it is it needs to be replaced, turn the computer over and check that access covers, one shows you a hard drive logo and it should have 1 or 2 screws, remove those or just loose them up. You may have to stick a tiny flat screwdriver under the cover to pop it off, after you do that remove the screws that hold the hard drive; there should be a plastic or tape tab to pull the hard drive out. Go ahead and pull it out, make sure that the adapter on the hard drive (shiny box) it is properly attached. check the prongs on the computer where the hard drive goes check for dark spots (burn like) if everything looks fine, re insert hard drive (make sure that it makes proper contact) and close the lids turn it on and see if it loads. if it doesn't then you know how to replace a hard drive you just have to have your cds' to load the operating system
if it works for you don't forget to rate me
thx
Apr 27, 2010 | HP Pavilion dv6000z Notebook
I have an HP Pavillion a1250n which has a MS-7184 V1.0 that will not boot. When turned on the HP Invent logo screen appears with thw following at the bottom:(Esc=Boot Menu)(F1=Setup)(F10=System...
It sounds as though you might have a problem with BIOS.
You should remove your motherboard battery (little round silver disc) and if you can find (or Google motherboard model#) the CMOS reset jumper, you can remove the battery for 30 seconds and put it back in and reset the CMOS, then see if it boots. If it doesn't, you might need to flash the BIOS, which is not recommended unless you know what you are doing.
Nov 16, 2009 | Intel Motherboard
I got this really old HP Pavillion ZD7260us Laptop a friend left it to me with no HDD and no memory.So i went to buy a DDR PC270 512mb SO DIMM memory and an 80gig IDE Hard Drive. So i tried to install it...
try plugging a standard pc keyboard into the ps2 slot ,if it has one, if not use a usb keyboard. That should tell you if the keyboard is malfunctioning. As for using the hard drive with no caddy it should be fine as long as you pad it it securely, to stop it being knocked about etc when moving the laptop. Also you will need to enter the bios and set ideo 0(the hard drive) to auto detect. As it is more than likely detecting the old hard drive in the bios settings not the new one?
Oct 28, 2009 | Computers & Internet
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
Open Questions:
HP Pavillion ZV6000 Athlon 64 3500+ 15.4in WideScreen w/ 512MB/80GB/DVDRW/Flash Slot (PCLHCA6435512WWD) PC Notebook Logo
214 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
