Question about Samsung 793S 17" CRT Monitor
Monitor screen movement
I am using a nvidia geforce 7200s with my samsung sync master 793s and when i am using the system the task bar where the start button is moves upward and after sometime comes again back to its original position.its irritating.however it does not move too much but a slight movement also troubles me
  • 589 Answers
Do you mean the taskbar disappears and comes back if you hover the pointer where it should be?
If so, try this:
Right click on the taskbar, choose "properties", and make sure "auto-hide the taskbar" isn't checked.
If that doesn't work, try the F11 key.
Posted on Jan 11, 2008
My comp is an HP laptop with a nvidia 8400m graphics card. It's running windows vista ultimate 32. I was running with the laptop screen "disabled" and using a monitor instead. Connected through HDMI to an...
This is a very common problem with nVidia geforce 8400 and 8600 cards.
Serach google with this "Defective Nvidia geforce card" and you will see lots of user facing same problem in HP, Dell etc..
I too have an Hp laptop with nvidia geforce 8400. I have faced similar problems(screen got divided into 8 parts) in past for 3 times. Every time I have to replace my motherboard at HP service center.... It is caused by overheating of laptop that destroys the nvidia graphic card.
Go to the service Center and ask for a motherboard replacement.
hope this will help.....
Sep 25, 2010 | HP nVidia GeForce 8400 GS, DH PCI Express...
Inno3D Geforce 256MB 128bit Video card
sounds like yo had the same Problems that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the monitor cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is running with your card you can also see that from the about nvidia you must have the driver for the card installed to do all this.. hope I helped install the driver first then disable download latest drivers here http://www.nvidia.com/Download/index5.aspx?lang=en-us
Jan 15, 2010 | XFX GeForce FX 5500 Graphic Card
The i need to disconect somthing because i cant see anithing wen i conect the port to the card but wen i buthem back to normal i see my monitor
Nov 21, 2009 | SuperMicro NVIDIA GEFORCE PCI-E 5300 VGA...
Have a new 23 inch samsung monitor that requires res 1920x1080
The problem is the cable connection to the video card.
When using the DVI output of the FX 5500, the maximum screen resolution that you can select is 1280 x 1024.
But, if you use the Analog (VGA) output, the card will support resolutions up to 2048 x 1536, which should be ok.
Apr 23, 2009 | XFX GeForce FX 5500 Graphic Card
Vista media center
hello what is the screen resolution you use?
Feb 10, 2008 | Microsoft Windows Vista Ultimate Edition
Dell Nvidia 17
What browser are you using?
If you are using Internet Explorer 6.0, install IE 7.0 or Forefox
Oct 12, 2007 | Samsung 793S 17" CRT Monitor
Samsung Syncmaster 245BW sync problem
If you are plugged into a NVIDIA graphics card, use the NVIDIA control panel scaling option to "do not scale" then set the resolution to 1920x1080. This monitor is a 16:10 aspect ratio instead of 16:9 like HD TV's, so it is necessary to turn of scaling from the software and thus give black bars.
Aug 10, 2007 | Samsung SyncMaster 245BW Monitor
Samsung 793S 17" CRT Monitor Logo
56 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
