Question about Canon PIXMA iP4000 InkJet Photo Printer
Poor color Canon P4000 has very poor color, I have cleaned it many times, but still poor Print.   Is there any way to remove the print heads and clean with a cleaner?
  • 84 Answers
Mr.Musculo is very helpfull in cleaning head prints.
Posted on Jan 14, 2008
6ya staff
SOURCE:
Canon ir 1600 my copier print copy image is very poor
iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
Use GENUINE CANON DRUM UNIT and GENUINE TONER.
Jul 02, 2010 | Canon Office Equipment & Supplies
Color not printing correctly on canon i900d
Take the cartridges and print head out. Pour about a centimeter of boiling water into a saucer or shallow bowl and set the print head in it for about 30 seconds. Place it on a folded up paper kitchen towel for a minute to dry and replace print head and cartridges in printer. Run two normal cleaning cycles and a nozzle check. If the test print is still poor or has not improved at all, the print head is probably dying and it is time to find a new machine. If the print has improved but not perfect, just repeat the process a couple of times.
Dec 11, 2017 | Canon I900D InkJet Photo Printer
When copying in black only the quality is very poor in spots - in color it prints fine. I've already done every maintenance on the nozzles that is available. The poor quality is part of various lines are...
The print head is clogged.You can try unclogging manually.WARNING: next steps may lead to a defective of print head, try on your responsibility.
Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0049.
Nov 08, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Can you help? After changing the cartridges, I keep getting a message about the ink head being incorrect...I am directed to press 'OK' which does not help; then to turn printer off and on again, which...
Cleaning your head might resolve your problem. Perform the below steps to clean the head:
Print Head Cleaning / Head Refreshing If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head (Cleaning) or print head deep cleaning (Deep Cleaning). Note:
  1. Cleaning the print head consumes a small amount of ink. Cleaning too often reduces the amount of ink in the ink tanks.
  2. Print head cleaning is performed when you connect the power cord. Your machine may perform print head cleaning periodically to avoid clogging.
Overview:
Step1:
Print the Nozzle Check Pattern.
To check whether the print head nozzles are clogged, print the Nozzle Check Pattern.
downicon.gif If the print quality is poor, perform print head cleaning.
Step 2:
Perform print head cleaning.
This unclogs the print head nozzles
Print the Nozzle Check Pattern again.
If the print quality is still poor, perform two print head cleanings.
downicon.gif Print the Nozzle Check Pattern again.
Step 3:
Perform deep print head cleaning.
This is a more powerful cleaning.
Displaying the Maintenance screen
  1. Ensure that the printer is powered on.
  2. Press the <Menu> button.
  3. Press the left or right cursor to select [Maintenance/settings], then press <OK>.
  4. Press the left or right cursor to select [Maintenance], then press <OK>.
Print Nozzle Check Pattern
  1. Press the Open button to open the output tray.
  2. Load letter-sized plain paper in the auto sheet feeder (ASF) or the cassette.
  3. Display the Maintenance screen on the printer.
  4. Press the up or down cursor to select [Nozzle check], then press the <OK>.
  5. Press the up or down cursor to select [Yes], then press <OK>. (The nozzle check pattern is printed.)
  6. Confirm the nozzle check pattern.
05sj00160_03a.gif 05sj00160_03b.gif < 1 > The normal nozzle check pattern
< 2 > The abnormal nozzle check pattern
< 3 > Some black ink lines are broken.
< 4 > White lines are present in the color ink pattern.
< 5 > Both black and color inks are not present.
Note:
  1. When all patterns are printed normally, press the up / down cursor button to select "All A" and press the OK button.
  2. When any patterns are printed abnormally, press the up / down cursor button to select "Also B" and press the OK button.
Print Head Cleaning:
  1. Display the Maintenance screen on the printer.
  2. Press the up or down cursor to select [Cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head cleaning.
    Note:
    Do not do any other operations until print head cleaning is completed.
  4. Print the nozzle check pattern and check the print head status.
Deep (Print Head) cleaning:
  1. Display the Maintenance screen.
  2. Press the up or down cursor to select [Deep cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head deep cleaning.
    Note:
    Do not do any other operations until print head deep cleaning is completed.
    Note:
    If the printed result does not improve even after doing print head deep cleaning, turn off the printer. Then, after 24 hours or later, do print head deep cleaning again. (After a given time interval, ink could dissolve itself, resulting in ink unclogging.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
My Canon mp390 printer doesn't print
I had this problem several times, had to buy new print head until I found that to clean it you should use ammonia. It really worked for me. You should really try ammonia it does work.
Apr 22, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Quality of colour
hi! there, well in connection to your poor printed color there posibility that ink was insufficient to distribute to you photo to print try to visit your ink status, black color is sepated to 3 color catridge.if there's a insufficient ink in catridge,replace or refill any thing as long there is much ink in your catridge,if ok and print still not good,try to clean your printer headdont use any thing to clean your printer herad,the printer will clean your printer head,on maitenance menu,click clean,try several time,also try to align your printer head,click aligned,t check the pattern of your printer,click pattern test.if ok try toprint if the color print is balance,try to print.check the preview before you print adjust the quality color as in yout tate before printing.regards and have a nice day.
Apr 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
Installed all new ink cartridges and now poor printing results
Dear louis,
You have done right thing by cleaning the print head. If the print head still clogged after repeatedly cleaning, It seems that the print head need to be replace with new one. Make it sure by printing nozzle check pattern. Is it good or not?.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 28, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Poor color printing quality
do you have the canon print management software installed? it's located in the maintenance tab on that software.
www.canon.com has that by model number
Jun 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Poor color print quality HP Photosmart 2710 all-in-one
yes..do a clean heads and re calibrate..if you have print manager, it can be done from there.
might be able to get them through this printer driver link
Mar 09, 2008 | HP Photosmart 2710 All-In-One InkJet...
Canon PIXMA iP4000 InkJet Photo Printer Logo
148 people viewed this question
Clive
Clive
old marine
old marine
Ekse
