Question about Biostar U8668 Motherboard
Ram On the U8668 MB there are two sockets for DDR modules and the spec. shows that you can have 2GBs of ram.  I got two 1GB dimms and installed them. The computer general Info shows 2GBs of ram but when I use PhotoShop or play a Game(F1C, GTR2) my graphics processing (object and texture details) are below what I had before I installed the dimms. I cam remove one dimm and everything goes back to working at full. It dosnt matter which socket I use as long as there is only one dimm installed, for only 1GB of ram. any ideas??
  • 3 more comments
  • TomC9000 Jan 11, 2008
    Yes, that was one of the first things I tryed. I got it from the Biostar site. Do you know if you can change something in the bios to fix it?
    Yes, the dimms are the same, I got them in a two dimm package.
    I tried to update the bios and kept getting that the "Bios Check Sum Fail", I dont know what that means. I'm trying to install the U8668R33.DDR or U8668R41.DDR to see if that well fix my Ram trouble.
  • TomC9000 Jan 12, 2008
    tom19511, I have a U8668 MoBo not a U8668D. Do you know if I can use the U8668DR33.DDR update? Also when I flash the MoBo I get either "Bios Check Sum Fail" or "Bios ID not a Match"
    Thanks tom19511 thats the one I flashed a few weeks ago. It didn't seem to do anything for my problem. I guess I have to old of a MoBo and will have to start new, even Biostar wont answer my calls for help. Thanks for Trying with your knowledge.
    Genius:
  • 1,601 Answers
Are both of them 2 x 184-pin DDR SDRAM DIMM
PC2100 DDR SDRAM ..The same?
Posted on Jan 11, 2008
  • 589 Answers
I've heard of this happening on several mainboards. It has to do with memory mapping. Have you tried flashing to the latest version BIOS?
I have an IBM Netvista A30p that I am trying to upgrade the memory in. It currently has 640mb and I am trying to go to 2GB. I have 2 1GB dimms to install but it will not boot with them. It will not boot...
are the modules of the same brand and type
make sure the sockets and ram modules are dust and corrosion free and are securely seated
you might swap each module over then reboot one might be faulty
RAM
  • Installed Size 256.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM
    hope this helps
  • Nov 17, 2011 | IBM NetVista A30p PC Desktop
    I bought P3200 ddr 400 1gb memory and when i install it , it does not show up. any ideas why and if there is something i can do .
    The Intel® Server Board S875WP1-E supports both ECC and Non ECC Unbuffered PC2100 (266 MHz), PC2700 (333 MHz), or PC3200 (400 MHz) compliant Double Data Rate (DDR) memory modules. Dual channel memory functionality requires two DIMM modules installed into DIMM sockets 1A & 1B, and then DIMM sockets 2A & 2B. The DIMM module size, speed and vendor must be the same.
    You can install a single 128 MB memory module into DIMM socket 1A. The minimum supported memory size is 128 MB. The minimum main memory configuration is a single 128 MB memory module, and the maximum configurable memory size is 4GB. With only a single memory module installed, the system will only operate using a one memory channel.
    Third party memory vendors may use the same module part number with different
    DRAM vendors and die revisions. To insure proper system operation, verify that each DRAM
    vendor and die revision has been separately tested and qualified. Please notify CMTL if there is a discrepancy.
    Apr 10, 2011 | Intel Server Board S875WP1-E (S875WP1LX)...
    I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
    Hi this model sopport 2Gig Memory Ram.
    RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
    Please check in to your Bios system maybe share memory Video or capacity is setting
    Nov 03, 2010 | Dell Dimension B110 PC Desktop
    Can i use DDR 2 RAM for U8668d ver. 6.1 motherboard of 1GB
    your motherboard uses DDR1 SDRAM PC2100 max. as stated on their website:
    http://www.biostar-usa.com/mbdetails.asp?model=u8668+d
    you cannont put DDR2, but you can expand up to 2GB
    Hope this helps
    Alex
    www.CAS411.com
    Mar 17, 2009 | Biostar U8668D (802700113338) Motherboard
    Need to know mem spd...333...400 etc to add cards
    Memory Installed 512 MB (2 x 256) Maximum allowed 4 GB* (4 x 1GB) requires the replacement of the installed 256 MB DIMMs
    *Actual available memory may be less Speed supported PC3200 MB/sec Type 184 pin, DDR SDRAM DIMM slots Four Open DIMM slots Two
    Thats the sticks you need
    Good luck
    Nic
    Feb 26, 2009 | HP Compaq Presario SR1630NX PC Desktop
    2.4ghz, 128ram, P4, 40GB HD.need to upgrade the system.
    According to intel:
    1.6 System Memory
    The Desktop Boards provide the following memory features:
    • Two DIMM sockets supporting one of the following10:
     2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with goldplated
    contacts, or
     3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated
    contacts
    • Unbuffered non-ECC DIMMs only
    • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
    • Serial Presence Detect (SPD) DIMMs only
    • Suspend to RAM
    And yes, you can increase the hard disk.
    Jan 12, 2009 | Intel D845GBV (BOXD845GBVL) Motherboard
    Intel D845GBV Motherboard RAM
    You can use only DDR 266Mhz dimms maximum upto 2 GB. i.e. one DIMMS of 266Mhz of 2GB or two of 1GB each. For more details read bellow:
    System Memory Features
    • The D845GBV board provide the following memory features:
    • Two DIMM sockets supporting 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with gold-plated contacts
      Suspend to RAM
    • CAUTION:
      Do not use ECC DIMMs with the D845GBV board. Using ECC DIMMs could damage the Desktop Board.
    For more details click here.
    Thanks
    Iqbal
    Apr 01, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
    Upgrade from 512MB to 1GB
    The specs on the memory are correct, so you purchased the correct type of memory for this motherboard. If your getting no video when you power on with the 1gb stick, I would be willing to bet the 1gb stick is bad. Can you return it and try another stick?
    Mar 15, 2008 | ASUS P4B266 Motherboard
    SAMSUNG 1GB RAM 400MHZ PC3200
    RAM has to be
    Four 184-pin DDR DIMM sockets
    Supports PC3200 (400 MHz) /PC2700 (333 MHz) / PC2100 (266 MHz) DDR DIMM type
    Maximum HP/Compaq approved memory module is 1 GB
    Maximum HP/Compaq approved memory is 4 GB
    It has to be the same.
    • If you are replacing a memory module, put the
    new memory module in the same memory slot
    from which the old memory was removed.
    Or
    • If you are adding a memory module, install the
    new module into the socket nearest the
    preinstalled module, and install additional
    modules in the next available sockets
    Jan 14, 2008 | Computers & Internet
    Biostar U8668 Motherboard Logo
    188 people viewed this question
    Top Biostar Computers & Internet Experts
    Jayburt
    David
    David
    Jerry Umali
    Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
