Question about Refrigerators
Kenmore refrigerator not cooling or freezing
My refrigerator/freezer will not cool or freeze. Fan runs, however the compressor does start up or run. What are some things I should try.
Thanks
  • 10 more comments
  • Anonymous Feb 17, 2008
    I have the same problem: the fans are running, but it seems that the compressor is not working and it doesn't freeze.
  • Anonymous Feb 26, 2008
    the compresor on the fridge wont kick on
  • RiskMgr Apr 01, 2008
    My Kenmore 77179 is 14 months old and, wouldn't you know it the freezer stops working right after the warranty expires. The problem is that the compressor does not kick in. The fan runs and the freezer temp is around 50 F. The Refrigerator portion is warmer around 60F. I looked at the back of the fridge and there are no icing around the coils, no condensation, no overheated parts.
    The only thing odd that I see are: (1) an elongated, vertical test-tube looking copper thing with a cone-shaped top, at the bottom right of the fridge, that has some green flaky corrosion around its top; and (2) two thin copper tubes with closed end, one coming out of the test-tube like thing and another one coming out of the compressor (big black ball like object). In looking at the closed-end tubes, it appears that they both have been mechanically pinched off by an industrial pliers. Perhaps from the factory?
    I don't know if the pinched closed-end tubes is at fault or if the slight corroded vertical tube is at fault but I appreciate any help in solving this matter.
    Thanks
  • mannys737 Jun 28, 2008
    my freezer is defrosting and seems to not be freezing sounds like it is still working the fan that is
  • delnavy52 Jul 09, 2008
    exactly the same problem. However, I did clean the dust
    off the cooling coils before. The fan does run.
  • heeih Jul 20, 2008
    MY fan in my kenmore side by side is working but ther is no cool air. I hear the compressor trying to start but then in does not click in. I have had my regerator for 6 years. The day before it was doing great then all of the sudden one day after work I went to fix supper and my ice defrosted and my food in my freezer was thawing. Please help.....
  • juju8793 Aug 14, 2008
    i have a kenmore with the freezer on the bottom and the refrig is 72 degrees and the freezer is 32. i just noticed last night. it seems that the compressor and fan is working. model# 596.76533 500 ser# 10262777gv. i have a sears repairman coming later for $65 diag fee. i have only had the unit for 23 months. what could be the problem?
  • hqd1980 Feb 07, 2009
    No, But I have a question I need your help on.
    The fan will not run until I turn the temperature on the T-stat from off to 3/4 of the coldest range, then the fan will run, and compressor will kick on, I touch the compressor is feel very hot, and after the fan ran for a day or two and stop, I have to reset the temperature from T-stat again to make the fan run.
  • Anonymous Mar 01, 2009
    both frig and freezer will wor perfectly then it will shut down and not come on for a while. will turn off for a few hours and restart and it will work fine for a bout seven days and the routine will begin again. what is the problem
  • depict7 Jan 08, 2010
    why does my kenmore refrigerator stop cool and freeze
  • Anonymous Mar 13, 2014
    TFF 24R refrigerator cools, but the freezer is not freezing. Could it be the turbo fan not working, and where is it located?
  • Anonymous Mar 19, 2014
    its a whirlpool modelet8gtmxkq02
My refrigerator suddenly stop cooling all the fans run normal. It makes a click Noyce.
Posted on Jun 22, 2008
    New Friend:
The compressor is not running just the fan. The freezer is not cooling at all. What could the reason.
Posted on Jun 18, 2011
    President:
  • 1,314 Answers
Do you have any cooling in the freezer side at all please hold my rating till we finish if you have cooling look at the back wall of the freezer is there heavy frost there toward the bottom there is a small tube comming out of the compressor is it hot you will see in the compressor compartment a filter drier will have a tiny copper tube comming feel that see if its cold before that did you make a typo on the compressor running is it running or not
Posted on Jan 11, 2008
3 Suggested Answers
6ya staff
SOURCE:
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: fan runs freezer and fridge don't cool
Please check the model number again, I can't locate that number. The number should be like for example 194.258978 Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • I think your refrigerator has a defrost timer and this may be the problem, Let me know what you find, Thanks, Sea Breeze
Posted on Mar 29, 2009
freetek
Steve Allison
  • 5569 Answers
SOURCE: Refrigerator and Freezer Not Cooling nor Freezing
That leaves only one possible fault; the volatile component of your coolant/lubricant has escaped.
If the unit has been moved or cleaned carelessly, one of the coolant- bearing tubes has developed a leak. Any refrigeration tech will have a leak detector in his tool set so it shouldn't be difficult to find.
Depending on the area in which you live, expect the troubleshooting and recharging to run ~$150-$250 US.
If you reside in the US, check your local (area) Better Business Bureau for a trustworthy service company.
Posted on Mar 16, 2009
Refridgerator is not cooling and the freezer not freezing. The cooling fan does run but it seems the compressor does not turn on. I'm wanting to test the capacitor to see if that could be the problem...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | Kenmore Side by Side Refrigerator
My kenmore fridge model 56723 is not cooling that is the fridge side. the fan is spinning very well but the compressor is very hot. funny enough the freezer appears to be cooling okay
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Jul 23, 2011 | Kenmore 56723 Side by Side Refrigerator
Iceream is not freezing
The temperature is not set to high cooling.First check the temperature setting.But if temperature is set right and still the ice cream is not cooling then .Problem relates to weak compressor. ------------- The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that ice cream is not freezing, so that means freezer is not freezing to its required temperature.------- This indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Kenmore Side by Side Refrigerator
Freezer not freezing but cools like the refrigerator would. Refrigerator not cooling enough. the cover in the back of the refrigerator was off. I reconnected but the freezer still won't freeze
is the freezer fan running? is there frost on the rear freezer wall if so it would be a defrost issue. if no frost on freezer rear panel it would sound like a bad compressor or sealedsystem leak.
Jun 06, 2011 | Kenmore Top Freezer Refrigerator
Fridge not cooling or freezing
You can start with replacing the start capacitor and relay to see if the compressor will run again, but you have about a 50 -50 chance that the compressor has gone bad and will need to be replaced....
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 12, 2010 | Kenmore 52673 Side by Side Refrigerator
Top refrigerator not ccoling and bottom freezer
check the condenser temperature when the compressor is running by hand it must be warm or hot if it is not then that means no refrigerant left in the system.This can be a possible cause.
Sep 27, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore side by side is not getting cold or freezing
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
Is the refrigerator completely dead?
If so, see “It's stopped completely.”
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
The compressor
The Thermostat
The overload, relay, or capacitor
The defrost timer
The condenser fan motor
The freezer and the fridge are cooled by the same system, air is moved to the fridge by a fan from the freezer, either the circulation fan is defective or the fridge thermostat is defective.
Regards:
VOTIT
Don't forget to rate;
Jul 05, 2009 | Kenmore 53642 / 53644 Side by Side...
Fridge is not cooling freezer is not freezing
Your compressor is seized and is cycling on intenal overload, you will have to get someone out to get a price at replacing the compressor for your fridge.
Apr 04, 2009 | Kenmore 57029 Side by Side Refrigerator
Cooling and freezing problem
When the frig stops cooling properly, is it running at all? If the freezer fan is running and it is not cooling, you can rule out the thermostat and the defrost control. It would be a hard starting compressor or condenser fan. If the frig is not running, then it is likely the thermostat or your electronic defrost control. The defrost control is right behind the thermostat in the same housing. When you play with the Tstat, do it carefully as not to jar the defrost control. If the frig comes on, replace the thermostat.
Mar 23, 2009 | Kenmore Refrigerators
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Refrigerators Logo
12,025 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
