Question about Brother IntelliFax-2820 Laser Fax
Hiintekkifax 4100 my fax will not turn on it was working fine before then when we unplugged it to move it it would not go back on i have 4100 series
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,363 Answers
Try different outlet,
Posted on Jan 14, 2008
6ya staff
SOURCE:
Dirty printing
find the blue slider on the Drum Unit. Move back and forth 10 times..
May 19, 2010 | Brother IntelliFAX 4100 Laser Fax
MY BROTHER INTELLIFAX 4100 PRINTS LINES ON MY PRINTED PAGES.
Try moving the blue slider on the cartridge back and forth 10 times to clean the charge wire. If this doesn't work, you most likely have a bad drum.
Jan 19, 2010 | Brother IntelliFAX 4100 Laser Fax
Output coming out the back
Hi Christi_Matt !!
the brother 4100 does not have any settings for that, all you have to do is to close the rear cover just move the machine arrown and you will notice that the cover is in the up position, make sure you move it down (lock it down) and as simple as that all your faxes should go to the front.
any other questions let me know.
just use my fixya ID at yahoo.... you know the rest
thank you.
Mar 24, 2009 | Brother IntelliFAX 4100 Laser Fax
Will not let me dial.
Did you try unplugging the power cord?
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Cant receive faxes
Set your fax machine for AUTO RECEIVE. Unplug power cord and plug back in.
Sep 05, 2008 | Brother IntelliFAX 4100 Laser Fax
Fax not picking up Brother 4100
have you see the display if it was saying the word receiving...?
let me know..
Jun 26, 2008 | Brother IntelliFAX 4100 Laser Fax
Comm.error displayed
Answer to your problem is move out of Verizon service area, they stink
Jan 20, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFax 4100 sending solid black pages
There are two possible solutions. Is the machine sitting on top of metal? The machine will send black pages when there is static charge. You can put a rubber mat under the machine or use a static guard. The second solution is to put the machine in maintenance and reset the scanner. Unplug the machine, put your finger on the menu key first and then re-plug the line while holding the menu key, in about 30 seconds all the lights will flash and the display will say maintenance. Release the menu Key and press 55 and this will reset the scanner; if scanner error comes up the machine will need to be serviced. Press stop and then 99 this will exit you out of maintenance. If the machine does not have an error try making a copy of blank sheet of paper and see if there is any improvement. As a routine clean the scanner glass with soft lint free cloth and isopropyl alcohol also.
Mar 10, 2006 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
26 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
