Question about Linksys Business Series WAP4400N Pre-802.11n Wireless Access Point
WAP4400N access cannot access administaration screen on WAP4400N after setting IP to DHCP
  • wietse Jun 25, 2008
    I have the same problem, my router's DHCP server indeed gave an IP address to the WAP4400N Access Point (try to look in your router's settings, it'll be displayed somewhere around there, otherwhise, you can see it also in "Available Wireless Networks").
    The wireless internet works, but the problem is, it's unencrypted and the adminpassword is still the default one. Trying to connect to the Access Point through it's IP gives me this error:
    error '8002801c'
    Error accessing the OLE registry.
    /iisHelp/common/500-100.asp, line 17
    Perhaps IIS has something to do with it, or are my security settings faulty ?
    Thanks for helping, this issue doesn't seem to occur that often.
  • 32 Answers
Do you have a DHCP server, like on your router, or on another computer on your LAN ?
If you don't know if you have a dhcp server or not... in windows, you can go to: Start>run>cmd, then type: ipconfig /all
That will tell you what ip address your dhcp server is.
If so do you see the access point trying to get an address? Check your logs, if you have a DHCP server chances are the access point (AP) already has an address.
Another thing you can do, is hold... i think it is a red button in the back, if you hold it for 30 seconds i think.. it will reset your AP back to its default settings.
Posted on Jan 11, 2008
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
NEED HELP TO SETUP MY TRUEMOBILE 2300 ROUTER TO MY DELL LATITUDE D600 LAPTOP. I HAVE BEEN TRYING TO GET WIRELESS CONNECTION. WHAT I DO HAVE , 1300 TRUEMOBILE PC CARD PLUG IN. WHAT I DON'T HAVE IS A...
The Network Key you're probably asking for is on a sticker located, underneath the router. Can you check?
Here's a way to configure your router for your existing network (assuming you already have one) :
If you have an existing network, chances are you have already configured network services on the network. In this case, you would use the router as a pure Access Point to extend the range of your network by allowing more attachment of wireless and wired computers. You MUST also turn off the DHCP server on the router if there is a DHCP server running to avoid IP address conflict.
To configure the router as an Access Point with the DHCP server disabled:
  1. Open your web browser and go to http://my.router, (or the default address http://192.168.2.1.)
  2. Click the Basic Settings tab on the top navigation bar.
  3. Select Access Point Mode.
  4. Click the Next button.
  5. Click OK to dismiss the DHCP disabled message box (The DHCP server will be disabled in Access Point Mode by default).
  6. Click the Advanced Settings tab on the top navigation bar.
  7. Click the Advanced IP Settings tab on the left navigation bar.
  8. Assign an IP address to the Wireless Broadband Router.
    note.gif NOTE: The IP address should be reserved by the DHCP server. The Wireless Broadband Router cannot act as a DHCP client, therefore, it needs a static IP address for its LAN interface.
  9. Click the Submit button.
  10. Click the Save & Restart button.
  11. Note the status bar at the bottom of the screen.
  12. While the Wireless Broadband Router resets, the Power light on the front of the unit blinks.
  13. When your web browser returns to the main page of the Wireless Broadband Route, the device has successfully restarted with the new settings.
    note.gif NOTE: The main page may not return if you have changed IP address of the router in Step 8. To view the main page, type the new IP address of the router in the web browser to access it.
  14. Plug an Ethernet cable from the existing local network into any LAN port on the Wireless Broadband Router.
Jul 01, 2011 | Dell TrueMobile 2300 Wireless Router...
Hi all, I can not acces the web based setup of Linksys WAP4400N. please help me?
Hi lienekekuste,
If you want to access the Router Settings Page of your Linksys WAP4400N just open a Browser then enter 192.168.1.245 and the Default Username is admin and the Password is admin
Rate me if this helps so I can help others.
Thanks for using Fixya.
Feb 04, 2011 | Linksys Business Series WAP4400N...
My router can not access dhcp.Why?
A DHCP Reservation is a permanent IP address assignment. It is a specific IP address within a DHCP scope that is permanently reserved for leased use to a specific DHCP client.
You can configure a DHCP reservation in your DHCP server when you need to reserve a permanent IP address assignment. You can use these reservations for DHCP-enabled devices like print and file servers or other application servers which always have the fixed IP address on a network.
To configure a DHCP reservation, follow the steps provided below:
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the web-based setup page on a Mac computer, click here.
Step 2:
Click Setup > Basic Setup.
Step 3:
Make sure that the DHCP Server option is Enabled. Click the DHCP Reservation button if you want to assign a fixed local IP address to a MAC address.
Step 4:
When you click on DHCP Reservation, a new web browser window will pop-up. Click the Select checkbox to reserve a client's IP address. Click the Add Clients button afterwards.
kb17362-003_en.png Step 5:
If you want to manually assign an IP address, enter the client's host name in the Enter Client Name field. You can do this as well in the IP Address and MAC address fields.
Step 6:
Click the Add button.
Step 7:
A list of DHCP clients and their fixed local IP addresses will be displayed at the bottom of the screen. If you want to remove a client from this list, click the Remove button.
On this window, you can do any of the following:
• Click the kb17362-006_en.png button to save your changes.
• Click the kb17362-007_en.png button to cancel your changes.
• To view the most up-to-date information, click the kb17362-008_en.png button.
• To exit this screen, click the kb17362-009_en.png button
If you need more help come back.Post / thumbs / testimonial are welcome!.
Nov 20, 2010 | Linksys WRT160N Wireless Router
I have a dlink router of model DI-1750, i have to configure DHCP..can anyone help me regarding the configuration commands.
Step 1:
Step 2:
Step 3:
Step 4:
Step 6:
Step 7:
• To exit this screen, click the kb17362-009_en.png button.
Nov 20, 2010 | D-Link Computers & Internet
I would like to set up secrity on a WAP4400N
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
May 17, 2010 | Linksys Business Series WAP4400N...
Systems cant ping each other
can u ping ur gateway? and the router too? then make sure all the system workgroup have the same name. use the same IP for all that is automatic use automatic for all, and if manual setting use manual setting for all.
Jun 17, 2009 | Linksys Business Series WAP4400N...
Ip address for clients using autonomous cisco 1130ag witout dchp
the cisco1130ag will provide ip addresses and serve as a DHCP server for your laptops...
You still need an IP address for your 1130ag so either your ISP provides you a static ip that you can put in the 1130 or if your ISP provides dhcp then you should be able to plug and play with your 1130ag
Jan 15, 2009 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
No access to set up modem or router
you might have configured your lan settings wrongly.
If your modem was setup for DHCP then you configure your lan to receive IP address automatically, DNS automatically.
If DHCP is disabled on the modem, you have to USE static IP Address for your lan ip and default gateway should be your modem default ip.
the default IP for modem is usually 192.168.1.1
if DHCP is disabled on the modem the sys ip is 192.168.1.3
So Configure your LAN setting as follow and Type http://192.168.1.1 in the address url.
Lan Settings:
IP Address: 192.168.1.3
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.1.1
click ok.
and type the above url, press enter the modem will ask you for username and password.
Good Luck.
Dec 27, 2007 | D-Link DSL 300G+ (DSL-300G+) Modem
Linksys Business Series WAP4400N Pre-802.11n Wireless Access Point Logo
986 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
