Question about Homelite Garden
Looking to find a prime pump valve - Homelite Garden
  • 169 Answers
I have them all instock at lakeviewpower.com
Posted on Nov 20, 2009
HOW can I tell if a Goulds jet pump needs replacement?
pull the foot valve as it takes very little to allow the water to drain back out. Personally I would replace all pipes in the hole with heavy duty /high pressure plastic agricultural irrigation pipes
Aug 17, 2014 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
NO COLD WATER
"Solenoid". No, you probably don't need one. You shouldn't even HAVE one.
I suspect strongly that you need to prime the new pump. There should be a priming plug on the top of the pump. Remove the plug and pour water into it. Replace the plug quickly and turn on the pump immediately.
You may need to do this several times before the pump starts drawing water. You can hear the change in pump sound when it starts moving water.
It does help, while you're priming, to close any valve you find between the pump and the pressure tank. As soon as the pump draws water, slightly open that valve or the pump will cycle on & off very rapidly. When the pressure tank is pretty full of water (you're getting fairly significant pressure on the gauge), open that valve fully.
I always liked to have a globe valve on top of the pump with a bell reducer and cap above that for priming purposes. The globe valve permits VERY fast pump repriming, and the bell reducer acts like a funnel, making it easy to pour water in. With the globe valve closed (normal operation), the cap doesn't even have to be tight - I need no tools to prime my pump that way.
Jul 28, 2014 | Washing Machines
My titan 330 airless paint spray will not shut off while primming
Airless paint sprayers should not turn off while in prime mode. As long as the prime valve is open the motor can pump paint but the system will not build any pressure. Once the prime valve is closed the pump should pump paint into the hose until it gets to the pressure level required to turn the motor off. If the pump does not turn off with the prime valve closed, it could be that the spring in the valve is weak and won't hold the valve closed under pressure. If the hose is up to pressure and the motor just keeps trying to pump paint, you may have a bad pressure sensor or it is disconnected from the circuit board.
Jul 10, 2012 | Air Tools & Compressors
Our sewer pump loses prime, when we manually re-prime it will pump but constantly loses prime.
pumps that continually loose prime 4 sure have an air leakage problem two places that most pumps can leak air into them are (1) input shaft seal
(2) check valve
the check valve is by far the easier of the two to replace id start with that one first some waste water pumps have two check valves on them one on suction line and one on discharge line (if over 10 feet high)
Jul 31, 2011 | Monarch Pumps BE-S75 Wastewater Pump...
Had to replace shallow well pump. Bought jet pump (used to have centrifugal pump), and installed it. Had to replace inline check valve, losing well prime. Priming pump does not accomplish the job. ...
Aj, do you have a foot valve on the bottom of the pipe in the well?? The jet pump needs to have a foot valve to hold the water in while priming it... you also have to carefully design the system and prime it in such a way as to eliminate all of the air in the piping. A jet pump will not pull the water and expel the air like a centrifugal pump will...
I think the part you are missing is the foot valve...
heatman101
Jun 09, 2011 | Garden
How do you prime a sta-rite mse-6 deep well pump?
Take the pressure guage off and pour water in the hole untill it fills the pump, then screw the guage back on and cranck it up. You may have to do this a few times depending on how deep in the grownd the water is.
Jan 26, 2010 | Sta Rite Ds3hf 1.50 Hp Self Priming...
How do i prime an onga pump from repressuring to primiing
Open the priming port at the discharge pipe. Close the discharge valve and fill the priming port with water until it is full. Power up and switch on the pump. While running, slowly open the discharge valve until the water
pressure gage at the pump is 20 psi. That will be the running pressure of the pump, and the maximum opening of the discharge valve.
Sep 27, 2009 | Plumbing
My explorer ran out of gas, i filled it up to about a half a tank, now it just turns over but wont start
if it's fuel injected,look on the fuel rail for a schrader valve--looks just like a valve stem on a tire but shorter.remove cap,again just like on a tire.turn key to on-push valve stem in as if to let air out if you get air,then gasoline,you have just bled the system.replace cap,start car.if you get no gas,remove gas tank cap,turn on key,listen for ""hum'' of fuel tank.no hum,check fuel pump.modern[plastic] fuel pumps will self destruct if run dry,even for a short time.
Sep 21, 2009 | 2000 Ford Explorer
Pool pump won't prime. Impeller replaced, worked for a couple of days. I changed the filter now same as original problem won't prime. I thought perhaps it was clogged; however since it was running and...
sounds like a priming problem. look at the check valve in front of the pump in the suction line. sounds as if it is loosing its prime so you don't have enough water close enough to the pump to get it primed.
Feb 18, 2009 | Pentair 1.0 Hp Whisperflo Pump
Garden Logo
55 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
