Question about Panasonic DMR-EZ47V DVD Recorder/VCR
I CANNOT SET THE STATIONS ON MY PANASONIC DMREZ47VEB RECORDER
AS ABOVE
  • Anonymous Feb 02, 2008
    Followed instruction as per manual, several times. Unplugged everything, checked all connections, still unable to setup any stations. Am able to use the DVD to record from Sky - but not able to setup stations???
  • 979 Answers
Isn't the sky system only putting out one station at a time?...accordianman
Posted on Feb 24, 2008
6ya staff
SOURCE:
How do i record tv programs on digital stations. Only option is analogue.
On the EPG (of the DMRs channels) press OK on the remote at the program you want to record. After that you can choose HDD or DVD-RAM and the quality Ep-Xp and possible subtitles (STTL). Press OK and the recording settings are saved. Note that to record 16:9 or 4:3 aspect ratio, you have to have that setting made from setup.
Nov 09, 2013 | Televison & Video
How do you re-tune the panasonic DMR E85H DVD Recorder. I have done exactly as it says in the manual and still it does not find any channels? Is it digital?
The tuner in the DMR-58H is a NTSC tuner (analog). Unless you have a low power station in your area, you will need a digital-to-analog converter box to record OTA stations. It can record analog cable without a box as well. (Digital cable will require a box.)
The manual for the DMR-E85H is available from Panasonic here: http://service.us.panasonic.com/OPERMANPDF/DMRE85H.pdf .
I hope this helps.
(at least in my area there is only one station broadcasting an analog signal; it is a low-power transmitter and thus wasn't required to upgrade to digital with the rest of the stations.)
Mar 27, 2012 | Panasonic DMR-E85H DVD Recorder
Panasonic NV-FJ730 VHS Recorder can I use the timer to record programmes if I connect a set top box to the recorder
Yes you can. Make certain you set the channel selection you are going to record to the imput that the box is connected to. For instance if the box is on AV2 set that. Make certain the box is powered up and on the station you want to record. Also if the VCR has PDC make sure that is switched off. This will mean setting the times inbetween the TV show you want to record. For instance if you want to record a show that runs from 9pm to 10pm, you will have to set it to 8.59 and at least 10.01 or more, depending on if the station doesn't run to advertised times.
If the PDC is left on it will sit there and do nothing.
Sep 11, 2010 | Panasonic Televison & Video
Can I watch tv with the timer on the dvd recorder turned on?
Hook up the cable wire that comes directly from the wall to the dvd recorder's in connection, then get a 3 ft cable cord and connect from the out of the dvd recorder to the in on the tv. You should be able to set the dvd recorder channel and timer and leave it off. you then should be able to have your tv on and watch any station but to watch the tv with dvd recorder on, your tv should be set to either channel 3 or 4 depending on the switch on back of dvd recorder. I hope this solves your problem. Foxpaw13
Jun 15, 2009 | Panasonic DMR-EZ37VS
Record from radio to cd
i don't think this stereo has a cd burner your best bet would be to use online radio (most stations do this now) record straight to your computer and burn cd from there
Jun 12, 2009 | Panasonic RX-ES25 Cassette/CD Boombox
How to pre-set radio stations panasonic radio/cd/tape recorder
the best thing would to go to the panasonic web site and they should have the solution. they might even have the manual for it. without a picture this is the best i can do.
Mar 27, 2009 | Panasonic Audio Players & Recorders
Tuning tv stations for panasonic dvd recorder DMR ES15
Set your TV to channel 3 or 4. Then press TV/VCR which is above the button on the bottom right of the remote. Then you can tune in TV stations from the unit.
Aug 20, 2008 | Panasonic DMR-ES10 DVD Recorder
Cable box, digital service, channels not appearing
connect the RF lead from the wall to your cable box then out from that to your dvd then out from your dvd to your tv. now connect a scart lead from the cable box to AV 2 on the DVD then connect AV 1 on the DVD to your TV if you have a second scart on your tv connect that to the cable box. NOW on the DVD select AV2 now whatever is on the cable box will be recorded onto DVD/VCR. Put the DVD recorder into VCR mode and set it to auto tune all the Digital Video Broadcasts. You cannot physically tune the cable boxes own channels into the DVD via RF it has to be via a scart.
Apr 27, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
DVD Recorder Is Unable To Find Digital Channels
Try resetting it here is the procedure
1. open thr front lid
2. press and hold for 5 sec. the up and down buttons.
this will reset the clock and the channel settings
Ihope this helps
Jan 22, 2008 | Panasonic DMREZ27 DVD Recorder
DVD Timer not working
It usually means that if it doesn't record you don't have a blank DVD in the slot. Hope this helps =)
Nov 06, 2006 | Panasonic DMR-E95HS DVD Recorder
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
50 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
