Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hi I own a Hotpoint WM61 machine and water is leaking out of the soap dispenser. Can this be fixed? What part do I need?
  • Barry Coates
    Barry Coates May 11, 2010
    I do not think you require to fit any new parts.
    It is probably caused by one of two things.
    1-- remove top cover, and check the soap dispenser hose is not blocked with undesolved powder, and in the dispenser itself.
    2-- remove rear lower panel undo large black hose onto bottom of drum, and check filter inside hose.
    Please rate my solution.
    Thanks.
  • Hotpoint Master
  • 3,463 Answers
The pump filter probably requires cleaning.
Remove lower panel of washer.
Remove large black on bottom of drum.
Removw and clean filter inside hose.
Remove hose onto pump.
Check for blockage or obstruction here and in the pump.
Thanks.
Posted on Nov 21, 2009
Hotpoint soap drawer leaking, wfooo
The problem is not a leaking soap container. The problem is that it is overflowing because the line from it to the washer tub is clogged. This happens mostly when using powdered detergents. Check you operating instructions for soap dispenser cleaning procedures.
Jan 03, 2015 | Hotpoint Washing Machines
Hotpoint Aqualtis throws water out of soap draw during rinse. Have checked pressure switch & tubing. How do you get to the pressure chamber to check for blockage? Could it be anything else?
I would remove the dispenser drawer by pressing on the release button, then clean out under the drawer. The reason I say this is I have had a few do this and I found a rinse agent clogging unit it cause the water during rinse to dispense forward and leak on the floor. It not difficult to clean out, this can take up to 10 minutes or so to fix with no parts needed.
Good Luck
Aug 31, 2011 | Hotpoint Washing Machines
Water leaks from the door and from the soap dispenser
when you say leaks from the door i am not sure if this is the case or is water running from the soap tray onto the door making things look that way, Remove and clean your soap tray,it unclips in the centre to remove ,if this does not solve you could try reducing Water pressure to the machine only....Good luck
Feb 19, 2011 | Hotpoint Washing Machines
My wf541 leaks from the soap dispenser drawer when water is being put into the machine
Reduce the water pressure, I assume its too high , also make sure no partial blockage at dispenser hose ..try pouring in a jug of water and see if it goes away Freely...Good luck
Feb 04, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Water coming out of soap drawer
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) .Water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning.
Black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases you have to replace the dispenser.
Feb 05, 2010 | Hotpoint First Edition WMA22 Front Load...
Water leaking from under machine and it is not the hoses
Hi there........possible causes of leak .....(a) torn or holed door seal...(b) leaking drain pump....(c)...leaking or holed soap dispenser to tub hose...(d) hole or rupture in outer drum
regards Sir Galahad
Aug 13, 2009 | Hotpoint Washing Machines
Water leaking from soap dispenser front loading washing machine
water leaking from soap dispenser. so water pours out under the soap dispenser
Apr 19, 2008 | Whirlpool Washing Machines
Water leaks from the soap dispensing tray on Hotpoint WMA 56 model
In the sump hose there is a filter, remove the hose and clean out filter insert, water is being forced up dispenser hose because it cannot empty fast enough.
Dec 24, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Intermitant water leak.
Put a newspaper under the machine, it will help you to find out from where does the water leaks. Good luck!
Sep 06, 2007 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
171 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
