Question about IBM Computers & Internet
I need to replace a part and cannot read the part number
What is the part number of the 8-pin dip on the bottom of an IBM R51 27K9926 mainboard near the printer connector? It is marked 'Q4'. The only numbers I can make out are these 3 lines:
f p46??
FDS ?
69
I am trying to fix the MB, not replace it.
Thanks
  • 728 Answers
Hi res0m9hv,
HERE's the maintenace manual that lists all the p/n on the board.
Good Luck
Mark
Posted on Nov 24, 2009
IBM Server x3400 7975 our Mainboard crashed. How to access Data on Raid ? Does it work with a replaces Mainboard ?
What operating system does it use?
The problem is whether you're using hardware RAID or software RAID.
Hardware RAID will likely require another motherboard to read. Software RAID can be read in any other machine that can run the operating system.
Nov 25, 2013 | IBM x3400 Server
Nedd pin out for system header on m810dlu
http://www.pcchips.com.tw/PCCWebSite/Downloads/ProductsDetail_Download.aspx?CategoryID=1&Typeid=4&detailid=203&DetailName=MANUAL&DetailDesc=M810DLU%28V5.2a%29&MenuID=39&LanID=0
Manual.
Click on the country name nearest yours.
Opening 810ds52a.zip comes up on the right in a small window.
Make sure the circle to the left of Save File has a green dot in it.
If not, left-click in the circle to the left of Save File.
Now click on OK.
A small window comes up on the left. Double-click right on the file name 810ds52a.zip
In the next small window go to the left side, and click on Extract all files.
Click on Next, Next, and Finish.
Close the other two small windows, and keep the recent one.
DOUBLE-click right on -> 810Ds52a
(Microsoft Word 97-2003 Docu...
1,353 KB)
As it is a Microsoft Word document, it takes a few seconds for Microsoft Word to load, and the motherboard manual.
[If you don't have Microsoft Office, you can always use OpenOffice for free. MUCH better program than MS Office ]
Page 10 - Mainboard Components
SW1 is the Front Panel header. It is in-between the CMOS battery, and the Floppy Drive cable connector.
Motherboard installed in computer case, SW1 is parallel to the bottom edge of the motherboard, and has two rows of pins.
4 pins across the Top row, 5 pins across the Bottom row.
Pin 1 is on the Bottom row, and is all the way to the Left.
The pins on the Top row are numbered EVEN.
The pins on the Bottom row are numbered ODD.
Starting on the LEFT side going towards the Right, Top row;
Pins 2, 4, 6, and 8. There is NO pin 10.
Starting on the LEFT side going towards the Right, Bottom row;
Pins 1, 3, 5, 7, and 9.
Page 15 - 2: Mainboard Installation
A) Pins 1 and 3 are for the HarDDrive activity LED (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is reserved for the factory, and N/C. Not Connected.
D) Pins 2 and 4 are for the Power On LED (Light)
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) No Pin 10.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 08, 2012 | PC Chips M810DLU (M810DLUV75C) Motherboard
Front panel configuration
Motherboard installed in computer case;
Processor to the Top, 3 Ram Memory slots to the Right, 5 white PCI slots to the Bottom;
Down in the Bottom/Right corner, is JFP1, and JFP2.
The Front Panel header is JFP1. (Junction Front Panel 1)
The header with two rows of pins, and is positioned Horizontal. It is parallel to the bottom of the motherboard.
(The other Front Panel header is JFP2. It is positioned Vertical, and is above JFP1. You may be using it also. Read on)
There are two rows of pins for JFP1.
5 across the Top, 4 across the Bottom.
The pins on the Top row are numbered ODD.
The pins on the Bottom row are numbered EVEN.
Top row, starting from the Right side, going towards the Left;
Bottom row, starting from the Right side, going towards the Left;
A) Pins 1 and 3 are for the HarDDrive activity LED light.
If the Harddrive activity LED light is dim, when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for the Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. It is/was for the factory.
D) Pins 2 and 4 are for the Power On LED light. A Power On LED light that has 2 wires.
If the Power On LED is dim when the computer is on, switch the wires around.
Looking at JFP2. (Junction Front Panel 2)
Vertical with two columns of pins.
3 on the Right side, 4 on the Left side.
The Right side is numbered EVEN.
The Left side is numbered ODD.
Starting at the Bottom on the Right side, going Up;
Pins 1, 3, and 5.
Starting at the Bottom on the Left side, going Up:
A) Pins 1, 3, and 5, are for a Power On LED light, that has 3 wires.
Pin 1 is for the Positive wire. (Dual color LED )
B) Pins 2, 4, 6, and 8 are for a Speaker. The speaker for BIOS Beep Codes.
Pin 8 is for the Negative ( - ) wire.
Regards,
joecoolvette
Jun 24, 2012 | MSI MS-6580 Motherboard
Intel desktop board d845wn front panel powder led, power switch, hdd led, reset switch connection problem.
Hi, here you can read info and download drivers
for your mainboard:
http://www.intel.com/p/en_US/support/highlights/dsktpboards/d845wn
The pin layout look like this:
Connect: 1 and 3, 2 and 4, 5 and 7,6 and 8.
The 9 number is not in use.
Its also printed in on the mainboard with very small letters.
Sep 20, 2011 | Intel Desktop Board D845WN Motherboard
Ibm netvista x41 wont power up
measuring 12v at the psu is not enough. the psu have several voltage outputs ranging from 12volts to 3.3 volts and maybe even 2.2 volts.. firstly, check all onboard USB ports, a bent or shorted pin in a USB port will prevent the psu from operating. next, the psu has a safety connection to the mainboard, this is called the power good signal ( pwrgd) and it is a signal from the psu to the mainboard and tells the mainboard that everything in the psu is functioning correctly. If the powergood signal is lost ( drops from 5volts to zero volts) the mainboard will issue an interuppt to the cpu and the cpu will shut down, this will also shut the board down to prevent damage and data loss. mainboards all use pretty much the same connectors so your board will have either a 20 pin power connector or a 24 pin one. It may also have an additional 4 pin connector to power the cpu and northbridge functions. use a known good psu and plug this into your board along with the 4 pin connector and attempt a switch on. If the system begins to boot, replace the psu. if not, try unplugging or removing everything connected to the board, pay special attention to expansion cards and usb ports. remove the ram sticks and video cards if fitted, then attempt to boot again. if the system does not respond, replace the main board. if it now begins to boot, refit everything one item at a time and try starting the machine. turn off before refitting the next item and start the machine up again. when you get to the problem item, the machine will stop starting. If all else fails, replace the mainboard or take the machine to a reputable repairer..
Oct 30, 2009 | IBM NetVista X41 PC Desktop
Need to bypass or hack the bios password for IBM X41 PC Desktop
okay guys i found i new way to reset the pass with only a screwdriver …
will try to make a site with a tutorial to reset the tmp chip .. i think it works on every ibm notebook
here is a picture from an IBM X41 tablet i reseted the pass today
http://ug1.kw.cx/ug/0257/1549/123784929_full,r,470×470.jpg
you have to put the screwdriver between the 2 pins to contact them .. and now power on ya machine and go to the bios … you will receive a message with an security chip error or something like that
this chip was on the bottom of the mainboard … i think the T Notebooks (T40 , 42 , 43 , R50, R51 have the chip under the touchpad
will share this here for ya guys
i trade with used computers so you have to try many thigs to delete passwords ^^
The same way to delet passwords on DELL (D610, D600, and many more)
greetz Adrian
Mar 27, 2009 | IBM NetVista X41 PC Desktop
Access BIOS
what computer brand and model is it ?
Robert
Sep 01, 2008 | IBM NetVista PC Desktop
Computer won't boot
It is possible that your hard disk has some damaged files to allow booting. You will need a bootable CD to make it work, at least up to displaying the MS-DOS prompt. If the MS-DOS prompt shows (e.g. c: ) where you can see a blinking horizontal line, depending on what OS you use, you may type "scandisk" or "chkdsk" to let the software repair the problem. You may then reboot and see if it works.
Another option is to clear the CMOS (refer to your mainboard manual on how to do it). Usually, this is located near your mainboard battery.
Aug 31, 2008 | E-Machines eMachines Desktop PC
Wont boot fully
Try resetting the system BIOS.
There are three ways to do this, depending on the mainboard style.
Check for a jumper near the mainboard battery.
If there is one, and it is a three pin style, move the jumper from the side it is on to the other side, then turn the power on (generally it will spin up, but nothing will happen), and then back off. Replace the jumper as it was originally and boot the system.
If there is a two pin jumper, remove the jumper, turn the computer on (again, it will probably not do anything), then turn the computer off and replace the jumper and reboot.
If there is no jumper, remove the battery, turn the system on, then off, then replace the battery and reboot.
Feb 14, 2008 | IBM eServer xSeries 346
IBM NetVisat 02R4084 Mainboard
With the power on cross the pins with a slide on connector. When it fires on you know which one is the sw. When you cross the reset it will restart. When you try the HD the light will come on during HD activity. And the power light will work when you have the power light plugged. It isn't to hard. Just be careful.
Sep 27, 2006 | IBM (02R4084) Motherboard
Computers & Internet Logo
1,479 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
